Network
Lwip中的DHCP服务问题请教
发布于 2016-05-23 10:38:55 浏览:3270
版本RT-Thread 1.2.1,未修改任何内容,神舟IV开发板 定义#define RT_LWIP_DHCP 开启DHCP现象如下 ``` | / - RT - Thread Operating System / | 1.2.1 build May 20 2016 2006 - 2013 Copyright by rt-thread team To initialize device:sd0 failed. The error code is 2 File System initialzation failed! lwIP-1.4.1 initialized! TCP/IP initialized! finsh>> ->:list_if() list_if() network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 34 58 55 FLAGS: DOWN LINK_UP DHCP ETHARP ip address: 0.0.0.0 gw address: 0.0.0.0 net mask : 0.0.0.0 dns server #0: 208.67.222.222 dns server #1: 0.0.0.0 23, 0x00000017 ``` 出现上面的情况是不是表示DHCP获取IP地址不成功? 再进行手动设置set_if,如下: ```finsh>>set_if("e0","192.168.1.30","192.168.1.1","255.255.255.0") 536893640, 0x200058c8 finsh>>list_if() network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 34 32 59 FLAGS: DOWN LINK_UP DHCP ETHARP ip address: 192.168.1.30 gw address: 192.168.1.1 net mask : 255.255.255.0 dns server #0: 208.67.222.222 dns server #1: 0.0.0.0 0, 0x00000000 finsh>>``` 仍是出现FLAGS: DOWN LINK_UP DHCP ETHARP,求解为何设置不成功? 屏蔽#define RT_LWIP_DHCP 关闭DHCP后现象如下 ``` | / - RT - Thread Operating System / | 1.2.1 build May 20 2016 2006 - 2013 Copyright by rt-thread team To initialize device:sd0 failed. The error code is 2 File System initialzation failed! lwIP-1.4.1 initialized! TCP/IP initialized! finsh>> ->:list_if() list_if() network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 34 58 55 FLAGS: UP LINK_UP ETHARP ip address: 192.168.1.30 gw address: 192.168.1.1 net mask : 255.255.255.0 dns server #0: 208.67.222.222 dns server #1: 0.0.0.0 23, 0x00000017 finsh>> ``` 交换机任意端口接路由器(路由器开启DHCP服务) 开启RT-Thread 1.2.1中DHCP ```network interface: e0 (Default) MTU: 1500 MAC: 00 80 e1 34 58 55 FLAGS: UP LINK_UP DHCP ETHARP ip address: 192.168.1.100 gw address: 192.168.1.1 net mask : 255.255.255.0 dns server #0: 192.168.1.1 dns server #1: 0.0.0.0 23, 0x00000017 finsh>>``` 请教一下,是不是开启DHCP接入交换机状态应该是up,ip网关等为空 还是 上面显示的down 或者是开启DHCP后接入网络自动获取失败后转为分配一默认地址
2016-05-23
当使用DHCP时,就必须等DHCP获取成功才会 UP(不是LINK_UP) 也可以手动dhcp_stop,然后设置固定IP,然后再手动 UP
3.3k
yuwentown
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
