Network
TCP-sever
发布于 2016-05-25 14:41:22 浏览:1642
```void tcpserv(void *parameter) { int maxfd, tmp, nbyte, res; rt_uint32_t sin_size; char buf[BUF_SIZE]; int listenfd, connfd; /* ?¨???à??socket?è??·???????????socket?è??·? */ struct sockaddr_in server_addr, client_addr; /* ±??úIP???????????? */ fd_set global_rdfs, current_rdfs; int opt; CLIENT client[BACKLOG]; /* ????socket???????°???è???¤?????¨?????????¨SOCK_STREAM??TCP??socket */ if ((listenfd = socket(AF_INET, SOCK_STREAM, 0)) == -1) { /* ???¨?§°????í?ó???í */ rt_kprintf("TcpServ:Socket error! "); return; } opt = 1; setsockopt(listenfd, IPPROTO_TCP, TCP_NODELAY, &opt, sizeof(opt)); //×?????±¨???????????± setsockopt(listenfd, SOL_SOCKET, SO_REUSEADDR, &opt, sizeof(opt)); //???í???·???? setsockopt(listenfd, SOL_SOCKET, SO_REUSEPORT, &opt, sizeof(opt)); //???í???????? /* ??????·????????· */ server_addr.sin_family = AF_INET; /* Ipv4?ò?????ò */ server_addr.sin_port = htons(SERV_PORT); /* ·??????¤×÷?????? ????????????×????ò×???*/ server_addr.sin_addr.s_addr = INADDR_ANY; /* ±??úIP???· */ rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* ??0 */ /* °ó?¨socket??·????????· */ if (bind(listenfd, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) { /* °ó?¨?§°? */ rt_kprintf("TcpServ:Unable to bind! "); return; } /* ??sockfd???????à?? */ if (listen(listenfd, BACKLOG) == -1) { rt_kprintf("TcpServ:Listen error! "); return; } rt_sprintf(buf, "%4d", SERV_PORT); rt_kprintf(" TcpServ:TCPServer Waiting for client on port %s... ", buf); FD_ZERO(&global_rdfs); //?????à???è??·??? FD_SET(listenfd, &global_rdfs); //??listenfd?????à???è??·??? maxfd = listenfd; while (1) { current_rdfs = global_rdfs; //?ì?????è??·??????????????? res = select(maxfd + 1, ¤t_rdfs, NULL, NULL, NULL); if (res < 0) { rt_kprintf("TcpServ:fail to select!"); break; } else if (res == 0) { continue; } else { //???è??·????????é?è?????í?? for (tmp = 0; tmp <= maxfd; tmp++) { //???????×???????è??·????????é·??ú if (FD_ISSET(tmp, ¤t_rdfs)) { if (tmp == listenfd) { //???à???è??·? ?ò???????§???????? rt_kprintf("TcpServ:New connection Detected->"); sin_size = sizeof(struct sockaddr_in); if ((connfd = accept(tmp, (struct sockaddr *)&client_addr, &sin_size)) < 0) { rt_kprintf("TcpServ:!Fail to accept! "); break; } /* ?ò?????§????IP???????? */ rt_kprintf("TcpServ:Connection from (IP: %s ,PORT: %d) is Done ", inet_ntoa(client_addr.sin_addr), ntohs(client_addr.sin_port)); FD_SET(connfd, &global_rdfs); //??????connfd?????à???è??·??? maxfd = maxfd > connfd ? maxfd : connfd; //?????è??·???×??ó?? if (connfd >= 0) { client[connfd].connectfd = connfd; /* save descriptor */ client[connfd].addr = client_addr; } } else { //?????§???????é·??ú?? if ((nbyte = recv(tmp, buf, BUF_SIZE, 0)) <= 0) { //???§???????????? rt_kprintf("TcpServ: Connection from (IP: %s ,PORT: %d) is Removed ", inet_ntoa(client[tmp].addr.sin_addr), ntohs(client[tmp].addr.sin_port)); closesocket(client[tmp].connectfd); //???????ì???è??·????????? FD_CLR(tmp, &global_rdfs); client[tmp].connectfd = -1; } else { buf[nbyte] = 0; //rt_kprintf("TcpServ: RECIEVED DATA = %s from IP:%s ,PORT: %d) ", buf, // inet_ntoa(client[tmp].addr.sin_addr), ntohs(client[tmp].addr.sin_port)); //??????????????·????????§?? //send(tmp, buf, nbyte, 0); //MdTcp ???í?ó???? TcpTimeOut=60; nbyte = ReMapTcpRsp(buf,nbyte); send(tmp, buf, nbyte, 0); } } } } } } /* ??±?socket ????·??? */ closesocket(listenfd); return; }``` 大家看看这个程序哪有问题,我建立了四个连接同时通信,正常运行一段时间后程序就死在idle了,该线程无法被唤醒(除了TCPIP和shell线程,就这一个)
2016-05-25
死在idle里,idle都能死啊 -_- 看看你的服务端是否拒绝服务了吧
p517780694
2016-05-25
不是idle死了,而是说一直在跑idle,这个TCP_sever线程唤醒不了了
1.6k
p517780694
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
