/* Configure the MPU attributes as WB for SDRAM */
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.BaseAddress = 0xC0000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_8MB;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.SubRegionDisable = 0x00;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
/* Configure the MPU attributes as none-cache for 1MB SDRAM */
MPU_InitStruct.BaseAddress = 0xC0100000;
MPU_InitStruct.Size = MPU_REGION_SIZE_1MB;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER2;
#ifdef RT_USING_EXT_SDRAM
rt_system_heap_init((void*)EXT_SDRAM_BEGIN, (void*)EXT_SDRAM_END);
sram_init();
#else
rt_system_heap_init((void*)HEAP_BEGIN, (void*)HEAP_END);
#endif
1. 尽量使用cache,这样才能加速代码执行效率;不管是静态还是heap,都全开cache;
2. cache一致性问题在于多硬件访问的情况,例如cpu访问(其他cpu访问),dma访问(通用dma、外设专用dma)。这个时候就要考虑一致性的问题,该flush就flush,或者invalid等等。
3. mpu,很早就有了,可以查看相关的arm芯片说明文档.
4. 注意下cache line大小的问题,这部分有的时候最好是做cache line对齐的
按理说,OS层面应该要考虑cache line大小的。至于说cache与否与任务切换等的关系,那么这部分能加速尽量加速,特别是最好有TCM,能够让OS内核部分代码和CPU主频跑在一致频率上
int mpu_init(void)
MPU_Region_InitTypeDef MPU_InitStruct;
/* Disable the MPU */
HAL_MPU_Disable();
/* Configure the MPU attributes as WT for SRAM */
MPU_InitStruct.BaseAddress = 0x20010000;
MPU_InitStruct.Size = MPU_REGION_SIZE_256KB;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
/* Enable the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
return 0;
none-cache适合做dma,只是说cpu访问效率变低了些,,,所以最终情况还是看实际需求
