非模态窗口中的模态窗口显示有问题
发布于 2010-11-02 23:01:37 浏览:4441
如图所示.另外在模态窗口的情况下,单击右上角的关闭按钮会在rtgui_type_destructors_call函数里出现异常. -----非模态ok ![window1.jpg](/uploads/2209_22329a8756e7d157876f1ead4fbf4d43.jpg) -----模态有问题 ![window.jpg](/uploads/2209_0abd1cf40b8230c75382bcb98892c4b6.jpg) ``` /* * 程序清单:窗口演示 * * 这个例子会先创建出一个演示用的view,当点击上面的按钮时会不同的模式创建窗口 */ #include
#include "demo_view.h" #include
static struct rtgui_timer *timer; static struct rtgui_label* label; static struct rtgui_win* msgbox = RT_NULL; static rt_uint8_t label_text[80]; static rt_uint8_t cnt = 5; rtgui_win_t *win1; /* 获取一个递增的窗口标题 */ static char* get_win_title() { static rt_uint8_t win_no = 0; static char win_title[16]; rt_sprintf(win_title, "窗口 %d", ++win_no); return win_title; } void demo_show_onbutton(struct rtgui_widget* widget, rtgui_event_t *even) { rtgui_win_show(win1,RT_FALSE); } void demo_hide_onbutton(struct rtgui_widget* widget, rtgui_event_t *even) { rtgui_win_hiden(win1); } /* 窗口关闭时的事件处理 */ void window_demo_close(struct rtgui_widget* widget, rtgui_event_t *even) { rtgui_win_t* win; /* 获得最顶层控件 */ win = RTGUI_WIN(rtgui_widget_get_toplevel(widget)); /* 销毁窗口 */ rtgui_win_destroy(win); } /* 关闭对话框时的回调函数 */ void diag_close(struct rtgui_timer* timer, void* parameter) { cnt --; rt_sprintf(label_text, "closed then %d second!", cnt); /* 设置标签文本并更新控件 */ rtgui_label_set_text(label, label_text); rtgui_widget_update(RTGUI_WIDGET(label)); if (cnt == 0) { /* 超时,关闭对话框 */ rtgui_win_destroy(msgbox); /* 停止并删除定时器 */ rtgui_timer_stop(timer); rtgui_timer_destory(timer); } } static rt_uint16_t delta_x = 20; static rt_uint16_t delta_y = 40; /* 触发无标题窗口显示 */ static void demo_ntitlewin_onbutton(struct rtgui_widget* widget, rtgui_event_t* event) { rtgui_label_t *label; rtgui_button_t *button; rtgui_toplevel_t *parent; rtgui_rect_t widget_rect, rect = {30, 80, 150, 150}; parent = RTGUI_TOPLEVEL(rtgui_widget_get_toplevel(widget)); /* 创建一个窗口,风格为无标题及无边框 */ win1 = rtgui_win_create(parent, "no title", &rect, RTGUI_WIN_STYLE_DEFAULT); RTGUI_WIDGET_BACKGROUND(RTGUI_WIDGET(win1)) = white; /* 创建一个文本标签 */ label = rtgui_label_create("窗口2"); rtgui_font_get_metrics(RTGUI_WIDGET_FONT(RTGUI_WIDGET(label)), "窗口2", &widget_rect); rtgui_rect_moveto_align(&rect, &widget_rect, RTGUI_ALIGN_CENTER_HORIZONTAL); widget_rect.x1 = 50; widget_rect.x2 = 80; widget_rect.y1 = 100; widget_rect.y2 = widget_rect.y1+20; rtgui_widget_set_rect(RTGUI_WIDGET(label), &widget_rect); rtgui_container_add_child(RTGUI_CONTAINER(win1), RTGUI_WIDGET(label)); RTGUI_WIDGET_BACKGROUND(RTGUI_WIDGET(label)) = white; /* 创建一个关闭按钮 */ widget_rect.x1 = 50; widget_rect.y1 = widget_rect.y2+2; widget_rect.x2 = 80; widget_rect.y2 = widget_rect.y1+20; button = rtgui_button_create("关闭"); rtgui_widget_set_rect(RTGUI_WIDGET(button), &widget_rect); rtgui_container_add_child(RTGUI_CONTAINER(win1), RTGUI_WIDGET(button)); rtgui_button_set_onbutton(button, window_demo_close); /* 非模态显示窗口 */ rtgui_win_show(win1, RT_FALSE); } /* 触发正常窗口显示 */ static void demo_win_onbutton(struct rtgui_widget* widget, rtgui_event_t* event) { rtgui_win_t *win; rtgui_button_t *button; rtgui_toplevel_t *parent; rtgui_rect_t rect = {0, 0, 210, 150}; parent = RTGUI_TOPLEVEL(rtgui_widget_get_toplevel(widget)); rtgui_rect_moveto(&rect, delta_x, delta_y); delta_x += 20; delta_y += 20; /* 创建一个窗口 */ win = rtgui_win_create(parent, get_win_title(), &rect, RTGUI_WIN_STYLE_DEFAULT); rect.x1 = 20; rect.x2 = 70; rect.y1 += 5; rect.y2 = rect.y1 + 20; /* 创建按钮用于触发一个不包含标题的窗口 */ button = rtgui_button_create("创建窗口"); rtgui_widget_set_rect(RTGUI_WIDGET(button), &rect); rtgui_container_add_child(RTGUI_CONTAINER(win), RTGUI_WIDGET(button)); /* 设置onbutton为demo_ntitlewin_onbutton函数 */ rtgui_button_set_onbutton(button, demo_ntitlewin_onbutton); rect.x1 = rect.x2+5; rect.x2 = rect.x1+50; /* 创建按钮用于触发一个不包含标题的窗口 */ button = rtgui_button_create("显示"); rtgui_widget_set_rect(RTGUI_WIDGET(button), &rect); rtgui_container_add_child(RTGUI_CONTAINER(win), RTGUI_WIDGET(button)); /* 设置onbutton为demo_ntitlewin_onbutton函数 */ rtgui_button_set_onbutton(button, demo_show_onbutton); rect.x1 = rect.x2+5; rect.x2 = rect.x1+50; /* 创建按钮用于触发一个不包含标题的窗口 */ button = rtgui_button_create("隐藏"); rtgui_widget_set_rect(RTGUI_WIDGET(button), &rect); rtgui_container_add_child(RTGUI_CONTAINER(win), RTGUI_WIDGET(button)); /* 设置onbutton为demo_ntitlewin_onbutton函数 */ rtgui_button_set_onbutton(button, demo_hide_onbutton); /* 非模态显示窗口 */ rtgui_win_show(win, RT_FALSE); } rtgui_view_t* demo_view_window(rtgui_workbench_t* workbench) { rtgui_rect_t rect; rtgui_view_t* view; rtgui_button_t *button; /* 创建一个演示用的视图 */ view = demo_view(workbench, "Window Demo"); demo_view_get_rect(view, &rect); rect.x1 += 5; rect.x2 = rect.x1 + 200; rect.y1 = 200; rect.y2 = 220; /* 创建按钮用于显示正常窗口 */ button = rtgui_button_create("测试非模态窗口中的模态窗口"); rtgui_widget_set_rect(RTGUI_WIDGET(button), &rect); rtgui_container_add_child(RTGUI_CONTAINER(view), RTGUI_WIDGET(button)); /* 设置onbutton为demo_win_onbutton函数 */ rtgui_button_set_onbutton(button, demo_win_onbutton); return view; } ``` 估计是剪切部分有问题了,但是剪切的代码目前还是看不懂.惭愧.请版主指教.
2010-11-03
是非模式窗口下,显示模式窗口,却变成了非模式窗口显示吗?另外,关闭模式窗口没见到异常啊
2010-11-03
好像不对啊,你的代码中并没有模态显示的代码,怎么回事? 请给我邮件吧,网站切换这段时间,上论坛不多呢。
Gavin_Li
2010-11-03
哦,我测试的时候把它关掉了。其实 就是rtgui_win_show(win1, RT_FALSE); 改为rtgui_win_show(win1, RT_TRUE); 就发现问题了吧。
Gavin_Li
2010-11-03
bernard帮我解决问题了.由衷感谢. 无法显示问题是创建窗口时,要求第一个参数toplevel是当前的workbench. 关闭窗口问题是我漏掉rtgui_win_destroy(win1);了.因为模态的窗口关闭后第一次只是去掉模态. 第二次才真正的destory它.
4.4k
Gavin_Li
28
74
