Dragonfly BSD 2.0似乎快要发布了
发布于 2008-07-17 20:30:27 浏览:4042
比较重要的更新应该是它的HAMMER文件系统,全64位结构设计,Matthew Dillon真是天才! 呵呵,决定订一份Dragonfly BSD的kernel maillist多关注一下。 另外一个,netgraph是一个什么东西?wikipedia上的解释 netgraph is the graph based kernel networking subsystem of FreeBSD. Netgraph provides support for L2TP, PPTP, ATM, bluetooth using a modular set of nodes that are the graph. Netgraph has also been ported on other Operating Systems: * NetBSD, * Linux kernel 2.4 and 2.6 by 6WIND (Commercial closed source port)
2008-07-22
DragonFly 2.0 Release Notes HAMMER filesystem released! * Crash recovery on-mount, no fsck. * Fine-grained snapshots, snapshot management, snapshot-support for filesystem-wide data integrity checks. * Historically accessible by default. * Mirroring: Queueless incremental mirroring, master to multi-slave. * Undo and rollback. * Reblocking. * Multi-volume, maximum storage capacity of 1-Exabyte. Kernel changes * Add a sysctl jail.allow_raw_sockets (default to disabled) which allows jails to use raw sockets. * Enhance the firmware loading support. * Improved random number operation. * Add native fairq-queue implementation using ALTQ, for PF * Add native connection state recovery to PF - so router reboots do not drop active TCP connections. New 'pickups' directives, and a 'set' directive to set default keep policy. * Incorporate the 'probability' keyword into PDF from NetBSD. * Miscellanious bug fixes to the LWP (Light Weight Process) code. Fixes issues with kill -9 on vkernels. * Significant work on the buffer cache and VM system relating to system operation under heavy loads and with low amounts of free memory. * Major cleanup of the LWKT token code. This code works very well now and is here to stay. * Implement a cothread API and abstraction for vkernel drivers. This allows a vkernel driver to use a real thread as an I/O co-processor, outside of the ncpus abstraction, improving vkernel performance for both UP and SMP bulids. * Revamp and clean-up a good chunk of the low level pmap code in both the vkernel and i386 builds. This fixes a number of access safety issues and races which could occur under heavy loads. * Fix issues related to gdb'ing a vkernel. * Add a feature which allows boot0 and boot1 to accept commands over the serial port (instead of just boot2). * Fix an issue with the use of O_CREAT on read-only NFS mounts. * proc structure now allocated with kmalloc instead of zalloc. * Add support for local SOCK_SEQPACKET ... a connection oriented protocol over unix domain sockets which retains packetization boundaries for read() and write(). * Improve network polling support. * TCP keepalives are now turned on by default. * Fix ktrace support for threaded processes. * kern.trap_mpsafe and kern.syscall_mpsafe are now enabled by default, pushing the MP lock deeper into the kernel. * Fix a memory corruption issue related to the kernel losing track of the kernel's own use of the FP unit for bcopy operations. * Jails can now use raw sockets if jail.allow_raw_sockets is set. * CAM sync w/ FreeBSD, plus additional CAM work to fix disconnect races and panics. * Bring in bug fixes for UFS from FreeBSD related to when the filesystem becomes full. * getsockopt() and setsockopt() now copyin/copyout data early, so the rest of the kernel can just access a kernel buffer. * Experimental MPLS over ethernet support added. * Adjust NATA queueing to not allow I/O requests to languish forever due to sequential writes keeping the elevator going in one direction only. Hardware changes * Add cmx(4) from FreeBSD, the driver for Omnikey CardMan 4040 smartcard readers. * Sync NATA from FreeBSD. * Sync DRM from FreeBSD. Hardware changes (Networking) * A double-ton of work on wireless drivers (by Sephe) * A double-ton of work on ethernet drivers (by Sephe) * Good progress made on removing the BGL from the network paths. The BGL is still being left in-place for this release. * Some significant Bluetooth stack work has been done. * Greatly imrpoved packet routing on SMP systems. * Greatly improved polling support. * Greatly improved interrupt moderation support with certain drivers. Hardware changes (USB) * Better survivability when pulling mass storage devices without unmounting. * Add many more device IDs across the board. * Recognize when a device is pulled out of a firewire port (sbp). * Numerous fixes made to ugen(4), including using interrupt endpoints to increase responsiveness. * A few fixes made to firewire (fwohic). * Defer bus exploration to allow ehci to initialize. Add a boot loader tunable hw.usb.hack_defer_exploration which defaults to 1 and can be set to 0 to rever to the old behavior. Userland changes * Add blacklist feature for weak Debian-generated SSH keys. * Miscellanious additions to help with pkgsrc compatibility. O_SYNC, O_FSYNC. * Improved ktrdump. * Unique mode history feature added to /bin/sh (from NetBSD). * Many improvements to manual pages and documentation. * mount_nfs no longer gets confused by domain names which start with a digit. * Improved pkg_search * Removal of remaining (x)ntpd bits. dntpd is the official NTP client for DragonFly. * Lots of adjustments to libthread_xu to enhance pkgsrc compatibility and thread support. * Installer moved to contrib / direct-compile, instead of using pkgsrc. * Properly clear the direction flag (DF) on entry to a signal handler. * cpdup enhanced to support a verification mode, better remote operation, and parallelization. * Add vknet and vknetd ... a simple userland virtual ether switch, making user-run vkernel execution possible. * Add lsearch(3) and lfind(3) to libc. * Bug fixes to strcspn() and strspn() from FreeBSD. * Add a new utility 'notty', which runs a program detached from the terminal. * du now collects information with a 64 bit quantity instead of a 32 bit quantity. ls now displays inode numbers as 64 bit integers. * Add objc support to gcc. * Build the installer as part of normal build-/installworld if WANT_INSTALLER is set. Removals * Fortran was removed from the base. * libreadline (and its incompatible license) removed. * Numerous old device drivers have been removed. Contributed Software * Sync zoneinfo database with tzdata2008d from elsie. * BIND was updated to version 9.3.5-P1 fixing a security issue. * bzip was updated to version 1.0.5. * less was updated to version 418. * libarchive was updated to version 2.5.5. * OpenSSH was updated to version 5.0p1. * OpenSSH now has a blacklist feature for weak Debian-generated ssh keys. * tnftpd was synced with NetBSD as of May 2008. * Sync Citrus iconv support from NetBSD. * BIND updated to 9.3.5P1 w/ port randomization security fixes. * GCC updated to 4.1.2.
4k
414
5914
70
