Network
WIZnet 为什么 SPI 设备找不到呢?
发布于 2019-01-27 15:37:11 浏览:2372
* 本帖最后由 小住住 于 2019-1-29 23:07 编辑 * ![13.png](/uploads/201901/27/153534om4w4d04u4t9ymmm.png)如图:list_device 有spi2 设备,为什么报WIZnet SPI device spi20 not found. 注册设备到总线上以后,就卡死了。![14.png](/uploads/201901/28/003709ru1uuj0vbiipli6v.png) ![15.png](/uploads/201901/29/194547wqctsxthzvgsjqkq.png) 这张图上面是在CubeMX 中SPI 配置片选引脚的状态,下面是没有配置片选引脚。 挂载的代码: ```w5500_device.c 复制的野火bsp 中代码: #include "drv_spi.h" #include "board.h" #include "drv_gpio.h" int w5500_spi_device_init() { __HAL_RCC_GPIOB_CLK_ENABLE(); return rt_hw_spi_device_attach("spi2","spi20",GPIOB,GPIO_PIN_12); } INIT_DEVICE_EXPORT(w5500_spi_device_init);```配置的代码:然后就配置WIZnet 相关组件:结果就是上面的。 ```menu "Onboard Peripheral Drivers" config BSP_USING_ETH bool "Enable Ethernet Driver (spi2)" default n select PKG_USING_WIZNET select WIZNET_DEVICE_EXTERN_CONFIG select BSP_USING_SPI2 if BSP_USING_ETH if WIZNET_DEVICE_EXTERN_CONFIG config WIZ_SPI_DEVICE string default "spi20" config WIZ_RST_PIN int default 56 config WIZ_IRQ_PIN int default 57 endif config EXTERNAL_PHY_ADDRESS hex default 0x00 endif endmenu```最后按上面的配置就可以。插上网线就可以。 ![18.png](/uploads/201901/29/230658bhc1d1qdlbyojcy1.png)![18.png](/uploads/201901/29/230658bhc1d1qdlbyojcy1.png)
xdj999
2019-01-27
spi20需要关联到spi2
xdj999
2019-01-27
int wiz_init(void) { int result = RT_EOK; if (wiz_init_ok == RT_TRUE) { LOG_I("RT-Thread WIZnet package is already initialized."); return RT_EOK; } result = wiz_set_mac(WIZ_DEFAULT_MAC); if (result != RT_EOK) { goto __exit; } /*注册spi20*/ rt_hw_spi_device_attach("spi2", WIZ_SPI_DEVICE, GPIOB, GPIO_PIN_12); /* WIZnet SPI device and pin initialize */ result = wiz_device_init(WIZ_SPI_DEVICE, WIZ_RST_PIN, WIZ_IRQ_PIN); if (result != RT_EOK) { goto __exit; }
小住住
2019-01-28
>int wiz_init(void) >{ > int result = RT_EOK; --- int w5500_spi_device_init() { __HAL_RCC_GPIOB_CLK_ENABLE(); return rt_hw_spi_device_attach("spi2","spi20",GPIOB,GPIO_PIN_12); } INIT_DEVICE_EXPORT(w5500_spi_device_init); 加了这条以后,就卡死了。[I/SAL_SOC] Socket Abstraction Layer initialize success. 只执行到这里。
Cheney_Chen
2019-01-28
是不是只注册了 SPI2 总线设备,SPI20 设备没有注册,可以产考下面代码在 spi 驱动主注册 SPI20 设备 ``` /* attach cs */ { static struct rt_spi_device spi_device; static struct stm32_spi_cs spi_cs; GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; /* spi10: PA4 */ spi_cs.GPIOx = GPIOA; spi_cs.GPIO_Pin = GPIO_Pin_4; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); GPIO_InitStructure.GPIO_Pin = spi_cs.GPIO_Pin; GPIO_SetBits(spi_cs.GPIOx, spi_cs.GPIO_Pin); GPIO_Init(spi_cs.GPIOx, &GPIO_InitStructure); rt_spi_bus_attach_device(&spi_device, "spi10", "spi1", (void*)&spi_cs); } ```
xdj999
2019-01-28
>int w5500_spi_device_init() >{ > __HAL_RCC_GPIOB_CLK_ENABLE(); --- 这个是我的板子上的设置,你要根据自己的板子设置io口
misonyo
2019-01-29
源代码贴一下呢
小住住
2019-01-29
[i=s] 本帖最后由 小住住 于 2019-1-29 19:52 编辑 [/i] >源代码贴一下呢 --- 其实是不是也算挂载成功了。只要出现spi20. ``` int w5500_spi_device_init() { __HAL_RCC_GPIOB_CLK_ENABLE(); return rt_hw_spi_device_attach("spi2","spi20",GPIOB,GPIO_PIN_12); } INIT_DEVICE_EXPORT(w5500_spi_device_init); ``` ``` menu "Onboard Peripheral Drivers" config BSP_USING_ETH bool "Enable Ethernet Driver (spi2)" default n select PKG_USING_WIZNET select WIZNET_DEVICE_EXTERN_CONFIG select BSP_USING_SPI2 if BSP_USING_ETH if WIZNET_DEVICE_EXTERN_CONFIG config WIZ_SPI_DEVICE string default "spi20" config WIZ_RST_PIN int default 56 config WIZ_IRQ_PIN int default 57 endif config EXTERNAL_PHY_ADDRESS hex default 0x00 endif endmenu ```
小住住
2019-01-29
>源代码贴一下呢 --- 解决了,插上网线就可以了。在mxcube 中不用配置片选引脚。
2.4k
小住住
127
124
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
搞懂rt-thread对STM32的GPIO操作
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
zhuzhuzhu
