rt thread studio 启动出现问题
发布于 2020-02-25 17:49:32 浏览:1324
!SESSION 2020-02-25 17:45:26.754 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 !ENTRY org.eclipse.ui 2 0 2020-02-25 17:45:29.540 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2020-02-25 17:45:29.540 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2020-02-25 17:45:34.616 !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt". !STACK 0 java.lang.UnsatisfiedLinkError: Could not find resource chrome_elf.dll (in subdirectory: chromium-3071 ) at org.eclipse.swt.internal.chromium.ResourceExpander.findResource(ResourceExpander.java:119) at org.eclipse.swt.chromium.Chromium.loadLib(Chromium.java:1642) at org.eclipse.swt.chromium.Chromium.
(Chromium.java:103) at org.eclipse.swt.chromium.Browser.
(Browser.java:32) at org.rtthread.studio.application.login.LoginPage.createBrowserLogin(LoginPage.java:57) at org.rtthread.studio.application.login.LoginAction.login(LoginAction.java:29) at org.rtthread.studio.application.login.LoginAction.run(LoginAction.java:24) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.login(ApplicationWorkbenchWindowAdvisor.java:836) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor.postWindowCreate(ApplicationWorkbenchWindowAdvisor.java:820) at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:784) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58) at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:1001) at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:139) at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:95) at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:77) at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1487) at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1458) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:910) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:118) at org.eclipse.ui.internal.services.WorkbenchSourceProvider.lambda$2(WorkbenchSourceProvider.java:671) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1193) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1054) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064) at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1543) at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2193) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4765) at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348) at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502) at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2153) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770) at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method) at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:211) at org.eclipse.swt.widgets.Shell.open(Shell.java:1263) at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:747) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:693) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:781) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:752) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:746) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:730) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1099) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:636) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:152) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !ENTRY org.eclipse.osgi 4 0 2020-02-25 17:45:34.708 !MESSAGE 应用程序错误
rcp
2020-02-26
安装studio的时候 某些dll被杀毒软件删除了,把杀毒软件退出再安装一下试试
2020-02-26
>> Could not find resource chrome_elf.dll (in subdirectory: chromium-3071 ) 嗯,赞头像,**“我若不勇敢谁替我坚强”**
1.3k
qq_unix
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
