LAN8720
以太网phy
硬件电路设计
rt-thread LAN8720A+F407 100M连接,开机ping外网都正常, 一段时间后变成10M和半双工
发布于 2025-02-26 17:14:14 浏览:398
rt-thread LAN8720A+F407 100M连接,开机ping外网都正常, 一段时间后变成10M和半双工  然后一段时间后,可能一小时,可能半小时,会出现link down信息,网络就变成10M和半双工了,此时再ping就不行了   不知道是驱动问题还是协议栈有啥问题 下面是drv_eth.c,基本没有改动 rtt5.1.0版本 ```c /* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-11-19 SummerGift first version * 2018-12-25 zylx fix some bugs * 2019-06-10 SummerGift optimize PHY state detection process * 2019-09-03 xiaofan optimize link change detection process */ #include
#ifdef BSP_USING_ETH #include "drv_config.h" #include "drv_eth.h" #include
/* * Emac driver uses CubeMX tool to generate emac and phy's configuration, * the configuration files can be found in CubeMX_Config folder. */ /* debug option */ //#define ETH_RX_DUMP //#define ETH_TX_DUMP //#define DRV_DEBUG #define LOG_TAG "drv.emac" #include
#define MAX_ADDR_LEN 6 struct rt_stm32_eth { /* inherit from ethernet device */ struct eth_device parent; #ifndef PHY_USING_INTERRUPT_MODE rt_timer_t poll_link_timer; #endif /* interface address info, hw address */ rt_uint8_t dev_addr[MAX_ADDR_LEN]; /* ETH_Speed */ rt_uint32_t ETH_Speed; /* ETH_Duplex_Mode */ rt_uint32_t ETH_Mode; }; static ETH_DMADescTypeDef *DMARxDscrTab, *DMATxDscrTab; static rt_uint8_t *Rx_Buff, *Tx_Buff; static ETH_HandleTypeDef EthHandle; static struct rt_stm32_eth stm32_eth_device; #if defined(ETH_RX_DUMP) || defined(ETH_TX_DUMP) #define __is_print(ch) ((unsigned int)((ch) - ' ') < 127u - ' ') static void dump_hex(const rt_uint8_t *ptr, rt_size_t buflen) { unsigned char *buf = (unsigned char *)ptr; int i, j; for (i = 0; i < buflen; i += 16) { rt_kprintf("%08X: ", i); for (j = 0; j < 16; j++) if (i + j < buflen) rt_kprintf("%02X ", buf[i + j]); else rt_kprintf(" "); rt_kprintf(" "); for (j = 0; j < 16; j++) if (i + j < buflen) rt_kprintf("%c", __is_print(buf[i + j]) ? buf[i + j] : '.'); rt_kprintf("\n"); } } #endif extern void phy_reset(void); /* EMAC initialization function */ static rt_err_t rt_stm32_eth_init(rt_device_t dev) { __HAL_RCC_ETH_CLK_ENABLE(); phy_reset(); /* ETHERNET Configuration */ EthHandle.Instance = ETH; EthHandle.Init.MACAddr = (rt_uint8_t *)&stm32_eth_device.dev_addr[0]; EthHandle.Init.AutoNegotiation = ETH_AUTONEGOTIATION_DISABLE; EthHandle.Init.Speed = ETH_SPEED_100M; EthHandle.Init.DuplexMode = ETH_MODE_FULLDUPLEX; EthHandle.Init.MediaInterface = ETH_MEDIA_INTERFACE_RMII; EthHandle.Init.RxMode = ETH_RXINTERRUPT_MODE; #ifdef RT_LWIP_USING_HW_CHECKSUM EthHandle.Init.ChecksumMode = ETH_CHECKSUM_BY_HARDWARE; #else EthHandle.Init.ChecksumMode = ETH_CHECKSUM_BY_SOFTWARE; #endif HAL_ETH_DeInit(&EthHandle); /* configure ethernet peripheral (GPIOs, clocks, MAC, DMA) */ if (HAL_ETH_Init(&EthHandle) != HAL_OK) { LOG_E("eth hardware init failed"); } else { LOG_D("eth hardware init success"); } /* Initialize Tx Descriptors list: Chain Mode */ HAL_ETH_DMATxDescListInit(&EthHandle, DMATxDscrTab, Tx_Buff, ETH_TXBUFNB); /* Initialize Rx Descriptors list: Chain Mode */ HAL_ETH_DMARxDescListInit(&EthHandle, DMARxDscrTab, Rx_Buff, ETH_RXBUFNB); /* ETH interrupt Init */ HAL_NVIC_SetPriority(ETH_IRQn, 0x07, 0); HAL_NVIC_EnableIRQ(ETH_IRQn); /* Enable MAC and DMA transmission and reception */ if (HAL_ETH_Start(&EthHandle) == HAL_OK) { LOG_D("emac hardware start"); } else { LOG_E("emac hardware start faild"); return -RT_ERROR; } return RT_EOK; } static rt_err_t rt_stm32_eth_open(rt_device_t dev, rt_uint16_t oflag) { LOG_D("emac open"); return RT_EOK; } static rt_err_t rt_stm32_eth_close(rt_device_t dev) { LOG_D("emac close"); return RT_EOK; } static rt_size_t rt_stm32_eth_read(rt_device_t dev, rt_off_t pos, void *buffer, rt_size_t size) { LOG_D("emac read"); rt_set_errno(-RT_ENOSYS); return 0; } static rt_size_t rt_stm32_eth_write(rt_device_t dev, rt_off_t pos, const void *buffer, rt_size_t size) { LOG_D("emac write"); rt_set_errno(-RT_ENOSYS); return 0; } static rt_err_t rt_stm32_eth_control(rt_device_t dev, int cmd, void *args) { switch (cmd) { case NIOCTL_GADDR: /* get mac address */ if (args) { SMEMCPY(args, stm32_eth_device.dev_addr, 6); } else { return -RT_ERROR; } break; default : break; } return RT_EOK; } /* ethernet device interface */ /* transmit data*/ rt_err_t rt_stm32_eth_tx(rt_device_t dev, struct pbuf *p) { rt_err_t ret = RT_ERROR; HAL_StatusTypeDef state; struct pbuf *q; uint8_t *buffer = (uint8_t *)(EthHandle.TxDesc->Buffer1Addr); __IO ETH_DMADescTypeDef *DmaTxDesc; uint32_t framelength = 0; uint32_t bufferoffset = 0; uint32_t byteslefttocopy = 0; uint32_t payloadoffset = 0; DmaTxDesc = EthHandle.TxDesc; bufferoffset = 0; /* copy frame from pbufs to driver buffers */ for (q = p; q != NULL; q = q->next) { /* Is this buffer available? If not, goto error */ if ((DmaTxDesc->Status & ETH_DMATXDESC_OWN) != (uint32_t)RESET) { LOG_D("buffer not valid"); ret = ERR_USE; goto error; } /* Get bytes in current lwIP buffer */ byteslefttocopy = q->len; payloadoffset = 0; /* Check if the length of data to copy is bigger than Tx buffer size*/ while ((byteslefttocopy + bufferoffset) > ETH_TX_BUF_SIZE) { /* Copy data to Tx buffer*/ SMEMCPY((uint8_t *)((uint8_t *)buffer + bufferoffset), (uint8_t *)((uint8_t *)q->payload + payloadoffset), (ETH_TX_BUF_SIZE - bufferoffset)); /* Point to next descriptor */ DmaTxDesc = (ETH_DMADescTypeDef *)(DmaTxDesc->Buffer2NextDescAddr); /* Check if the buffer is available */ if ((DmaTxDesc->Status & ETH_DMATXDESC_OWN) != (uint32_t)RESET) { LOG_E("dma tx desc buffer is not valid"); ret = ERR_USE; goto error; } buffer = (uint8_t *)(DmaTxDesc->Buffer1Addr); byteslefttocopy = byteslefttocopy - (ETH_TX_BUF_SIZE - bufferoffset); payloadoffset = payloadoffset + (ETH_TX_BUF_SIZE - bufferoffset); framelength = framelength + (ETH_TX_BUF_SIZE - bufferoffset); bufferoffset = 0; } /* Copy the remaining bytes */ SMEMCPY((uint8_t *)((uint8_t *)buffer + bufferoffset), (uint8_t *)((uint8_t *)q->payload + payloadoffset), byteslefttocopy); bufferoffset = bufferoffset + byteslefttocopy; framelength = framelength + byteslefttocopy; } #ifdef ETH_TX_DUMP dump_hex(buffer, p->tot_len); #endif /* Prepare transmit descriptors to give to DMA */ /* TODO Optimize data send speed*/ LOG_D("transmit frame length :%d", framelength); /* wait for unlocked */ while (EthHandle.Lock == HAL_LOCKED); state = HAL_ETH_TransmitFrame(&EthHandle, framelength); if (state != HAL_OK) { LOG_E("eth transmit frame faild: %d", state); } ret = ERR_OK; error: /* When Transmit Underflow flag is set, clear it and issue a Transmit Poll Demand to resume transmission */ if ((EthHandle.Instance->DMASR & ETH_DMASR_TUS) != (uint32_t)RESET) { /* Clear TUS ETHERNET DMA flag */ EthHandle.Instance->DMASR = ETH_DMASR_TUS; /* Resume DMA transmission*/ EthHandle.Instance->DMATPDR = 0; } return ret; } /* receive data*/ struct pbuf *rt_stm32_eth_rx(rt_device_t dev) { struct pbuf *p = NULL; struct pbuf *q = NULL; HAL_StatusTypeDef state; uint16_t len = 0; uint8_t *buffer; __IO ETH_DMADescTypeDef *dmarxdesc; uint32_t bufferoffset = 0; uint32_t payloadoffset = 0; uint32_t byteslefttocopy = 0; uint32_t i = 0; /* Get received frame */ state = HAL_ETH_GetReceivedFrame_IT(&EthHandle); if (state != HAL_OK) { LOG_D("receive frame faild"); return NULL; } /* Obtain the size of the packet and put it into the "len" variable. */ len = EthHandle.RxFrameInfos.length; buffer = (uint8_t *)EthHandle.RxFrameInfos.buffer; LOG_D("receive frame len : %d", len); if (len > 0) { /* We allocate a pbuf chain of pbufs from the Lwip buffer pool */ p = pbuf_alloc(PBUF_RAW, len, PBUF_POOL); } #ifdef ETH_RX_DUMP dump_hex(buffer, p->tot_len); #endif if (p != NULL) { dmarxdesc = EthHandle.RxFrameInfos.FSRxDesc; bufferoffset = 0; for (q = p; q != NULL; q = q->next) { byteslefttocopy = q->len; payloadoffset = 0; /* Check if the length of bytes to copy in current pbuf is bigger than Rx buffer size*/ while ((byteslefttocopy + bufferoffset) > ETH_RX_BUF_SIZE) { /* Copy data to pbuf */ SMEMCPY((uint8_t *)((uint8_t *)q->payload + payloadoffset), (uint8_t *)((uint8_t *)buffer + bufferoffset), (ETH_RX_BUF_SIZE - bufferoffset)); /* Point to next descriptor */ dmarxdesc = (ETH_DMADescTypeDef *)(dmarxdesc->Buffer2NextDescAddr); buffer = (uint8_t *)(dmarxdesc->Buffer1Addr); byteslefttocopy = byteslefttocopy - (ETH_RX_BUF_SIZE - bufferoffset); payloadoffset = payloadoffset + (ETH_RX_BUF_SIZE - bufferoffset); bufferoffset = 0; } /* Copy remaining data in pbuf */ SMEMCPY((uint8_t *)((uint8_t *)q->payload + payloadoffset), (uint8_t *)((uint8_t *)buffer + bufferoffset), byteslefttocopy); bufferoffset = bufferoffset + byteslefttocopy; } } /* Release descriptors to DMA */ /* Point to first descriptor */ dmarxdesc = EthHandle.RxFrameInfos.FSRxDesc; /* Set Own bit in Rx descriptors: gives the buffers back to DMA */ for (i = 0; i < EthHandle.RxFrameInfos.SegCount; i++) { dmarxdesc->Status |= ETH_DMARXDESC_OWN; dmarxdesc = (ETH_DMADescTypeDef *)(dmarxdesc->Buffer2NextDescAddr); } /* Clear Segment_Count */ EthHandle.RxFrameInfos.SegCount = 0; /* When Rx Buffer unavailable flag is set: clear it and resume reception */ if ((EthHandle.Instance->DMASR & ETH_DMASR_RBUS) != (uint32_t)RESET) { /* Clear RBUS ETHERNET DMA flag */ EthHandle.Instance->DMASR = ETH_DMASR_RBUS; /* Resume DMA reception */ EthHandle.Instance->DMARPDR = 0; } return p; } /* interrupt service routine */ void ETH_IRQHandler(void) { /* enter interrupt */ rt_interrupt_enter(); HAL_ETH_IRQHandler(&EthHandle); /* leave interrupt */ rt_interrupt_leave(); } void HAL_ETH_RxCpltCallback(ETH_HandleTypeDef *heth) { rt_err_t result; result = eth_device_ready(&(stm32_eth_device.parent)); if (result != RT_EOK) { LOG_I("RxCpltCallback err = %d", result); } } void HAL_ETH_ErrorCallback(ETH_HandleTypeDef *heth) { LOG_E("eth err"); } enum { PHY_LINK = (1 << 0), PHY_100M = (1 << 1), PHY_FULL_DUPLEX = (1 << 2), }; static void phy_linkchange() { static rt_uint8_t phy_speed = 0; rt_uint8_t phy_speed_new = 0; rt_uint32_t status; HAL_ETH_ReadPHYRegister(&EthHandle, PHY_BASIC_STATUS_REG, (uint32_t *)&status); LOG_D("phy basic status reg is 0x%X", status); if (status & (PHY_AUTONEGO_COMPLETE_MASK | PHY_LINKED_STATUS_MASK)) { rt_uint32_t SR = 0; phy_speed_new |= PHY_LINK; HAL_ETH_ReadPHYRegister(&EthHandle, PHY_Status_REG, (uint32_t *)&SR); LOG_D("phy control status reg is 0x%X", SR); if (PHY_Status_SPEED_100M(SR)) { phy_speed_new |= PHY_100M; } if (PHY_Status_FULL_DUPLEX(SR)) { phy_speed_new |= PHY_FULL_DUPLEX; } } if (phy_speed != phy_speed_new) { phy_speed = phy_speed_new; if (phy_speed & PHY_LINK) { LOG_I("link up"); if (phy_speed & PHY_100M) { LOG_I("100Mbps"); stm32_eth_device.ETH_Speed = ETH_SPEED_100M; } else { stm32_eth_device.ETH_Speed = ETH_SPEED_10M; LOG_I("10Mbps"); } if (phy_speed & PHY_FULL_DUPLEX) { LOG_I("full-duplex"); stm32_eth_device.ETH_Mode = ETH_MODE_FULLDUPLEX; } else { LOG_I("half-duplex"); stm32_eth_device.ETH_Mode = ETH_MODE_HALFDUPLEX; } /* send link up. */ eth_device_linkchange(&stm32_eth_device.parent, RT_TRUE); } else { LOG_I("link down"); eth_device_linkchange(&stm32_eth_device.parent, RT_FALSE); } } } #ifdef PHY_USING_INTERRUPT_MODE static void eth_phy_isr(void *args) { rt_uint32_t status = 0; HAL_ETH_ReadPHYRegister(&EthHandle, PHY_INTERRUPT_FLAG_REG, (uint32_t *)&status); LOG_D("phy interrupt status reg is 0x%X", status); phy_linkchange(); } #endif /* PHY_USING_INTERRUPT_MODE */ static void phy_monitor_thread_entry(void *parameter) { uint8_t phy_addr = 0xFF; uint8_t detected_count = 0; while(phy_addr == 0xFF) { /* phy search */ rt_uint32_t i, temp; for (i = 0; i <= 0x1F; i++) { EthHandle.Init.PhyAddress = i; HAL_ETH_ReadPHYRegister(&EthHandle, PHY_ID1_REG, (uint32_t *)&temp); if (temp != 0xFFFF && temp != 0x00) { phy_addr = i; break; } } detected_count++; rt_thread_mdelay(1000); if (detected_count > 10) { LOG_E("No PHY device was detected, please check hardware!"); } } LOG_D("Found a phy, address:0x%02X", phy_addr); /* RESET PHY */ LOG_D("RESET PHY!"); HAL_ETH_WritePHYRegister(&EthHandle, PHY_BASIC_CONTROL_REG, PHY_RESET_MASK); rt_thread_mdelay(2000); HAL_ETH_WritePHYRegister(&EthHandle, PHY_BASIC_CONTROL_REG, PHY_AUTO_NEGOTIATION_MASK); phy_linkchange(); #ifdef PHY_USING_INTERRUPT_MODE /* configuration intterrupt pin */ rt_pin_mode(PHY_INT_PIN, PIN_MODE_INPUT_PULLUP); rt_pin_attach_irq(PHY_INT_PIN, PIN_IRQ_MODE_FALLING, eth_phy_isr, (void *)"callbackargs"); rt_pin_irq_enable(PHY_INT_PIN, PIN_IRQ_ENABLE); /* enable phy interrupt */ HAL_ETH_WritePHYRegister(&EthHandle, PHY_INTERRUPT_MASK_REG, PHY_INT_MASK); #if defined(PHY_INTERRUPT_CTRL_REG) HAL_ETH_WritePHYRegister(&EthHandle, PHY_INTERRUPT_CTRL_REG, PHY_INTERRUPT_EN); #endif #else /* PHY_USING_INTERRUPT_MODE */ stm32_eth_device.poll_link_timer = rt_timer_create("phylnk", (void (*)(void*))phy_linkchange, NULL, RT_TICK_PER_SECOND, RT_TIMER_FLAG_PERIODIC); if (!stm32_eth_device.poll_link_timer || rt_timer_start(stm32_eth_device.poll_link_timer) != RT_EOK) { LOG_E("Start link change detection timer failed"); } #endif /* PHY_USING_INTERRUPT_MODE */ } /* Register the EMAC device */ static int rt_hw_stm32_eth_init(void) { rt_err_t state = RT_EOK; /* Prepare receive and send buffers */ Rx_Buff = (rt_uint8_t *)rt_calloc(ETH_RXBUFNB, ETH_MAX_PACKET_SIZE); if (Rx_Buff == RT_NULL) { LOG_E("No memory"); state = -RT_ENOMEM; goto __exit; } Tx_Buff = (rt_uint8_t *)rt_calloc(ETH_TXBUFNB, ETH_MAX_PACKET_SIZE); if (Tx_Buff == RT_NULL) { LOG_E("No memory"); state = -RT_ENOMEM; goto __exit; } DMARxDscrTab = (ETH_DMADescTypeDef *)rt_calloc(ETH_RXBUFNB, sizeof(ETH_DMADescTypeDef)); if (DMARxDscrTab == RT_NULL) { LOG_E("No memory"); state = -RT_ENOMEM; goto __exit; } DMATxDscrTab = (ETH_DMADescTypeDef *)rt_calloc(ETH_TXBUFNB, sizeof(ETH_DMADescTypeDef)); if (DMATxDscrTab == RT_NULL) { LOG_E("No memory"); state = -RT_ENOMEM; goto __exit; } stm32_eth_device.ETH_Speed = ETH_SPEED_100M; stm32_eth_device.ETH_Mode = ETH_MODE_FULLDUPLEX; /* OUI 00-80-E1 STMICROELECTRONICS. */ stm32_eth_device.dev_addr[0] = 0x00; stm32_eth_device.dev_addr[1] = 0x80; stm32_eth_device.dev_addr[2] = 0xE1; /* generate MAC addr from 96bit unique ID (only for test). */ stm32_eth_device.dev_addr[3] = *(rt_uint8_t *)(UID_BASE + 4); stm32_eth_device.dev_addr[4] = *(rt_uint8_t *)(UID_BASE + 2); stm32_eth_device.dev_addr[5] = *(rt_uint8_t *)(UID_BASE + 0); stm32_eth_device.parent.parent.init = rt_stm32_eth_init; stm32_eth_device.parent.parent.open = rt_stm32_eth_open; stm32_eth_device.parent.parent.close = rt_stm32_eth_close; stm32_eth_device.parent.parent.read = rt_stm32_eth_read; stm32_eth_device.parent.parent.write = rt_stm32_eth_write; stm32_eth_device.parent.parent.control = rt_stm32_eth_control; stm32_eth_device.parent.parent.user_data = RT_NULL; stm32_eth_device.parent.eth_rx = rt_stm32_eth_rx; stm32_eth_device.parent.eth_tx = rt_stm32_eth_tx; /* register eth device */ state = eth_device_init(&(stm32_eth_device.parent), "e0"); if (RT_EOK == state) { LOG_D("emac device init success"); } else { LOG_E("emac device init faild: %d", state); state = -RT_ERROR; goto __exit; } /* start phy monitor */ rt_thread_t tid; tid = rt_thread_create("phy", phy_monitor_thread_entry, RT_NULL, 1024, RT_THREAD_PRIORITY_MAX - 2, 2); if (tid != RT_NULL) { rt_thread_startup(tid); } else { state = -RT_ERROR; } __exit: if (state != RT_EOK) { if (Rx_Buff) { rt_free(Rx_Buff); } if (Tx_Buff) { rt_free(Tx_Buff); } if (DMARxDscrTab) { rt_free(DMARxDscrTab); } if (DMATxDscrTab) { rt_free(DMATxDscrTab); } } return state; } INIT_DEVICE_EXPORT(rt_hw_stm32_eth_init); #endif ```
2025-02-26
LINK变成10M是硬件电路问题,也可能是外部网线,座子接触不良等。 变成10M后,通信不正常的话,应该是驱动程序里面没有把EMAC的状态切成10M。
YZRD
2025-02-27
会不会是电压不稳定?
arthurly888
2025-02-28
后来将ulog的时间信息打开后重新编译就没有出现问题,问题点没有明确 **欢迎分享下在网络连接出现问题后如何重新配置网络重试连接服务器,目前建立socket后连接服务器,出错后有时就无法再次连接,总是返回失败,不知道应该如何重新配置网络,目前的做法是重启系统**
mark301600
2025-02-28
这个问题同事遇到过,就是8720异常,再深层次得原因没查到。解决办法是,固定间隔检测phy8720的连接状态,异常后复位phy然后重新初始化emac
2025-03-03
开自动协商了吗,试下强制100M或强制10M是否有问题 速率协商是phy完成的,驱动只能控制是否自动协商速率,或强制指定速率/是否全双工 也可以从对端设备或网线找找问题
398
arthurly888
stm32f107+dm9161的phy芯片报错eth硬件初始化失败
stm32f107+DM9161出现硬件初始化问题
新手求助:关于配置PHY寄存器相关定义
关于在drv_eth.c中如何强制PHY工作
stm32f429+DM9162 ping丢包率特别高 可能是哪里有问题呢
rt-smart网络驱动问题
rt studio移植lwIP的前段增加PHY时编译报错?
急!急!急!求救,rtthread + phy +lwIP,快没信心了
rtthread使用官网TCPSERVER例程问题
STM32F407+LAN8720+LWIP2.0.2不稳定
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
Ryan_CW
D1sguIse_
