littlefs
文件系统挂载
断电重启
nor挂载一个littlefs文件系统之后,再把装置断电重启,重启后装置没有运行进行?
发布于 2025-05-08 16:54:02 浏览:134
```c struct fal_flash_dev nor_flash0 = { .name = NOR_FLASH_DEV_NAME, /* If porting this code to the device with FLASH connected to XPI1, the address must be changed to 0x90000000 */ .addr = NOR_FLASH_MEM_BASE, .len = 8 * 1024 * 1024, .blk_size = 4096, .ops = { .init = init, .read = read, .write = write, .erase = erase }, .write_gran = 1 }; #define NOR_FLASH_DEV_NAME "norflash0" #define NOR_FLASH_MEM_BASE 0x80000000UL #define NOR_FLASH_SIZE_IN_BYTES 0x800000UL #define FAL_PART_TABLE \ { \ {FAL_PART_MAGIC_WORD, "app", NOR_FLASH_DEV_NAME, 0, 8*1024*1024, 0},\ } int littlefsfilesystem(void) { int result; result = fal_init(); if(result <= 0) { rt_kprintf("fal_init failed\r\n"); } // 创建 FAL MTD NOR 设备 struct rt_device *flash_dev = fal_mtd_nor_device_create("app"); if (flash_dev == NULL) { rt_kprintf("Can't create a block device on '%s' partition.", "app"); } if (dfs_mount(flash_dev->parent.name, "/", "lfs", 0, 0) == 0) { rt_kprintf("Filesystem %s is mounted directly! mount point name is %s\r\n","lfs",flash_dev->parent.name); } else { rt_kprintf("Directly mount lfs failed, formatting...\n"); // 检查是否为 MTD 设备 if (flash_dev->type != RT_Device_Class_MTD) { rt_kprintf("Error: %s is not an MTD device!\n", flash_dev->parent.name); result = -RT_ERROR; goto __exit; } // 格式化 result = dfs_mkfs("lfs", "app"); if(result) { rt_kprintf("dfs_mkfs app on the block device result:%d!\r\n",result); goto __exit; } //挂载 spi flash 中名为 "app" 的分区上的文件系统 if (dfs_mount(flash_dev->parent.name, "/", "lfs", 0, 0) == 0) { rt_kprintf("Filesystem %s is mounted! mount point name is %s\r\n","lfs",flash_dev->parent.name); } else { rt_kprintf("Failed to initialize %s!\r\n",flash_dev->parent.name); } } DIR* dir_tmp = opendir("/nor"); if(dir_tmp == RT_NULL) { result = mkdir("/nor", 0777); if(result) { rt_kprintf("mkdir %s failed\r\n","/nor"); return result; } } else { closedir(dir_tmp); } result = RT_EOK; __exit: return result; } int main(void) { printf("go into main ! world\r\n"); static uint32_t led_thread_arg = 0; int ret; app_init_led_pins(); rt_thread_t led_thread = rt_thread_create("led_th", thread_entry, &led_thread_arg, 1024, 30, 10); rt_thread_startup(led_thread); init_gpio_pins(); // rt_kprintf("RT_HW_HEAP_BEGIN=%02x RT_HW_HEAP_END=%02x\r\n",RT_HW_HEAP_BEGIN,RT_HW_HEAP_END); // ret = sdram_test(); ret = littlefsfilesystem(); rt_kprintf("littlefs_test ret=%d\r\n",ret); ret = Yaffs2filesystem(); rt_kprintf("Yaffs2filesystem ret=%d\r\n",ret); return 0; } ``` 装置再main中挂载一个littlefs文件系统,并再这个文件系统中创建一个文件夹,然后断电重启装置,装置没有再次正常启动程序,从串口看到得信息如下:  如果想要再次正常启动,就需要重新烧录程序,很奇怪,但是如果把文件系统挂载屏蔽掉,装置就能正常断电重启,有没有大佬能帮忙看一下?
qilian
2025-06-03
是不是因为littlefs掉电之后开启掉电保护了? 参考:https://rui-docs.readthedocs.io/zh-cn/latest/%E6%9C%80%E4%BD%B3%E6%9E%B6%E6%9E%84%E6%9E%84%E5%BB%BA/%E5%86%85%E6%A0%B8%E5%B1%82/littlefs%E6%96%87%E4%BB%B6%E7%B3%BB%E7%BB%9F.html
134
guangxinzhao
romfs无法执行df命令
w25q128挂载littlefs出现assert failed?
使用littlefs出现Corrupted dir pair at 1 0
使用片上flash的 littlefs 无法创建多个目录
littlefs挂载总是在lfs.c文件中 LFS_ASSERT
littlefs文件系统卡顿问题
需要littlefs 挂载在片上flash
日志存储是使用fat如何做磨损平衡?
挂载littlefs文件系统的flash寿命计算方式?
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
Ryan_CW
D1sguIse_
