使用软件包dht11,读取数据为0,怎么回事?
发布于 2020-01-24 12:45:19 浏览:3706
  代码我参考了事例:[https://github.com/murphyzhao/dht11_rtt/blob/master/dht11_sample.c](https://github.com/murphyzhao/dht11_rtt/blob/master/dht11_sample.c) 我只是引脚修改成了:#define DHT11_DATA_PIN GET_PIN(A, 8) 如何修改才能读取到数值? 如下main全部代码: ```c /* * Copyright (c) 2006-2019, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2019-09-09 RT-Thread first version */ #include
#define DBG_TAG "main" #define DBG_LVL DBG_LOG #include "sensor.h" #include "sensor_dallas_dht11.h" /* PLEASE DEFINE the LED0 pin for your board, such as: PA5 */ //#define LED0_PIN GET_PIN(C, 13) //#define OUT11_PIN GET_PIN(A, 11) #define DHT11_DATA_PIN GET_PIN(A, 8) int main(void) { //int count = 1; /* set LED0 pin mode to output */ //rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); //rt_pin_mode(OUT11_PIN,PIN_MODE_INPUT); /* while (count++) { rt_thread_delay(1000); LOG_D("thread run count : %d_%d
", count,rt_pin_read(OUT11_PIN)); rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_delay(1000); rt_pin_write(LED0_PIN, PIN_LOW); } */ return RT_EOK; } static void read_temp_entry(void *parameter) { rt_device_t dev = RT_NULL; struct rt_sensor_data sensor_data; rt_size_t res; rt_uint8_t get_data_freq = 1; /* 1Hz */ dev = rt_device_find("temp_dht11"); if (dev == RT_NULL) { return; } if (rt_device_open(dev, RT_DEVICE_FLAG_RDWR) != RT_EOK) { rt_kprintf("open device failed!
"); return; } rt_device_control(dev, RT_SENSOR_CTRL_SET_ODR, (void *)(&get_data_freq)); while (1) { res = rt_device_read(dev, 0, &sensor_data, 1); if (res != 1) { rt_kprintf("read data failed! result is %d
", res); rt_device_close(dev); return; } else { if (sensor_data.data.temp >= 0) { uint8_t temp = (sensor_data.data.temp & 0xffff) >> 0; // get temp uint8_t humi = (sensor_data.data.temp & 0xffff0000) >> 16; // get humi rt_kprintf("temp:%d, humi:%d
" ,temp, humi); } } rt_thread_delay(1000); } } static int dht11_read_temp_sample(void) { rt_thread_t dht11_thread; dht11_thread = rt_thread_create("dht_tem", read_temp_entry, RT_NULL, 1024, RT_THREAD_PRIORITY_MAX / 2, 20); if (dht11_thread != RT_NULL) { rt_thread_startup(dht11_thread); } return RT_EOK; } INIT_APP_EXPORT(dht11_read_temp_sample); static int rt_hw_dht11_port(void) { struct rt_sensor_config cfg; cfg.intf.user_data = (void *)DHT11_DATA_PIN; rt_hw_dht11_init("dht11", &cfg); return RT_EOK; } INIT_COMPONENT_EXPORT(rt_hw_dht11_port); ```
StackYuan
2020-01-25
最直接的方法是 (如果手头有示波器)看单总线有无数据交互,借此排除硬件问题与上拉问题
qiaowei361
2020-02-01
学习中...
>最直接的方法是 (如果手头有示波器)看单总线有无数据交互,借此排除硬件问题与上拉问题 ... --- 没有此工具{:3_61:}
Easadon
2020-03-26
你main函数里没有调用进程吧?
qiaowei361
2020-04-23
学习中...
>你main函数里没有调用进程吧? --- 代码在上面,帮我看看
qiaowei361
2020-04-26
学习中...
已经解决,把配置事例关掉就可以了
3.7k
qiaowei361
学习中...
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
STM32内存扩展,SRAM-RMC
