FSMC_FMC_外扩总线
LCD
RT-Thread Studio移植TFTLCD(FSMC)
发布于 2022-07-12 22:40:19 浏览:670
移植步骤: 1、将裸板上的LCD程序复制到新建的工程文件中,与main放在一起,并修改lcd.c、lcd.h,然后编译通过。   2、然后添加cubemx生成的文件。 CUBEMX设置如图:  将cubemx生成的文件中的main.c中的MX_FSMC_Init添加到rtt生成的applications的main.c中  将cubemx生成的文件中的stm32f1xx_hal_msp.c中的HAL_FSMC_MspInit复制到rtt生成的board.c中。  将cubemx生成的文件中的Drivers\STM32F1xx_HAL_Driver\Src文件中的stm32f1xx_ll_fsmc.c文件和stm32f1xx_hal_sram.c文件复制到rtt生成的libraries\STM32F1xx_HAL_Driver\Src文件夹中,并加入编译。  3、在mian.c中添加下面代码 ```c static int lcd_display(void) { rt_uint8_t x=0; rt_uint8_t lcd_id[12]; //存放LCD ID字符串 LCD_Init(); //初始化LCD FSMC接口 POINT_COLOR=RED; //画笔颜色:红色 sprintf((char*)lcd_id,"LCD ID:%04X",lcddev.id);//将LCD ID打印到lcd_id数组。 while(1) { switch(x) { case 0:LCD_Clear(WHITE);break; case 1:LCD_Clear(BLACK);break; case 2:LCD_Clear(BLUE);break; case 3:LCD_Clear(RED);break; case 4:LCD_Clear(MAGENTA);break; case 5:LCD_Clear(GREEN);break; case 6:LCD_Clear(CYAN);break; case 7:LCD_Clear(YELLOW);break; case 8:LCD_Clear(BRRED);break; case 9:LCD_Clear(GRAY);break; case 10:LCD_Clear(LGRAY);break; case 11:LCD_Clear(BROWN);break; } POINT_COLOR=RED; LCD_ShowString(30,40,210,24,24,"Explorer STM32F4"); LCD_ShowString(30,70,200,16,16,"TFTLCD TEST"); LCD_ShowString(30,90,200,16,16,"RT-thread"); LCD_ShowString(30,110,200,16,16,lcd_id); //显示LCD ID LCD_ShowString(30,130,200,12,12,"2014/5/4"); x++; if(x==12)x=0; rt_pin_write(LED0_PIN, PIN_HIGH); rt_thread_mdelay(500); rt_pin_write(LED0_PIN, PIN_LOW); rt_thread_mdelay(500); } } MSH_CMD_EXPORT(lcd_display, lcd_display samole); ``` 以上是我的移植过程,最后编译报错: ```c ../applications/main.c: In function 'MX_FSMC_Init': ../applications/main.c:27:3: error: unknown type name 'FSMC_NORSRAM_TimingTypeDef' FSMC_NORSRAM_TimingTypeDef Timing = {0}; ^ ../applications/main.c:35:3: error: 'hsram4' undeclared (first use in this function) hsram4.Instance = FSMC_NORSRAM_DEVICE; ^ ../applications/main.c:35:3: note: each undeclared identifier is reported only once for each function it appears in ../applications/main.c:35:21: error: 'FSMC_NORSRAM_DEVICE' undeclared (first use in this function) hsram4.Instance = FSMC_NORSRAM_DEVICE; ^ ../applications/main.c:36:21: error: 'FSMC_NORSRAM_EXTENDED_DEVICE' undeclared (first use in this function) hsram4.Extended = FSMC_NORSRAM_EXTENDED_DEVICE; ^ ../applications/main.c:38:24: error: 'FSMC_NORSRAM_BANK4' undeclared (first use in this function) hsram4.Init.NSBank = FSMC_NORSRAM_BANK4; ^ ../applications/main.c:39:32: error: 'FSMC_DATA_ADDRESS_MUX_DISABLE' undeclared (first use in this function) hsram4.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE; ^ ../applications/main.c:40:28: error: 'FSMC_MEMORY_TYPE_SRAM' undeclared (first use in this function) hsram4.Init.MemoryType = FSMC_MEMORY_TYPE_SRAM; ^ ../applications/main.c:41:33: error: 'FSMC_NORSRAM_MEM_BUS_WIDTH_16' undeclared (first use in this function) hsram4.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16; ^ ../applications/main.c:42:33: error: 'FSMC_BURST_ACCESS_MODE_DISABLE' undeclared (first use in this function) hsram4.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_DISABLE; ^ ../applications/main.c:43:36: error: 'FSMC_WAIT_SIGNAL_POLARITY_LOW' undeclared (first use in this function) hsram4.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW; ^ ../applications/main.c:44:26: error: 'FSMC_WRAP_MODE_DISABLE' undeclared (first use in this function) hsram4.Init.WrapMode = FSMC_WRAP_MODE_DISABLE; ^ ../applications/main.c:45:34: error: 'FSMC_WAIT_TIMING_BEFORE_WS' undeclared (first use in this function) hsram4.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS; ^ ../applications/main.c:46:32: error: 'FSMC_WRITE_OPERATION_ENABLE' undeclared (first use in this function) hsram4.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE; ^ ../applications/main.c:47:28: error: 'FSMC_WAIT_SIGNAL_DISABLE' undeclared (first use in this function) hsram4.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE; ^ ../applications/main.c:48:30: error: 'FSMC_EXTENDED_MODE_DISABLE' undeclared (first use in this function) hsram4.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE; ^ ../applications/main.c:49:34: error: 'FSMC_ASYNCHRONOUS_WAIT_DISABLE' undeclared (first use in this function) hsram4.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE; ^ ../applications/main.c:50:28: error: 'FSMC_WRITE_BURST_DISABLE' undeclared (first use in this function) hsram4.Init.WriteBurst = FSMC_WRITE_BURST_DISABLE; ^ ../applications/main.c:52:9: error: request for member 'AddressSetupTime' in something not a structure or union Timing.AddressSetupTime = 15; ^ ../applications/main.c:53:9: error: request for member 'AddressHoldTime' in something not a structure or union Timing.AddressHoldTime = 15; ^ ../applications/main.c:54:9: error: request for member 'DataSetupTime' in something not a structure or union Timing.DataSetupTime = 255; ^ ../applications/main.c:55:9: error: request for member 'BusTurnAroundDuration' in something not a structure or union Timing.BusTurnAroundDuration = 15; ^ ../applications/main.c:56:9: error: request for member 'CLKDivision' in something not a structure or union Timing.CLKDivision = 16; ^ ../applications/main.c:57:9: error: request for member 'DataLatency' in something not a structure or union Timing.DataLatency = 17; ^ ../applications/main.c:58:9: error: request for member 'AccessMode' in something not a structure or union Timing.AccessMode = FSMC_ACCESS_MODE_A; ^ ../applications/main.c:58:23: error: 'FSMC_ACCESS_MODE_A' undeclared (first use in this function) Timing.AccessMode = FSMC_ACCESS_MODE_A; ^ ../applications/main.c:61:7: warning: implicit declaration of function 'HAL_SRAM_Init' [-Wimplicit-function-declaration] if (HAL_SRAM_Init(&hsram4, &Timing, NULL) != HAL_OK) ^ ../applications/main.c:61:48: error: 'HAL_OK' undeclared (first use in this function) if (HAL_SRAM_Init(&hsram4, &Timing, NULL) != HAL_OK) ^ ../applications/main.c:63:5: warning: implicit declaration of function 'Error_Handler' [-Wimplicit-function-declaration] Error_Handler( ); ^ ../applications/main.c: In function 'lcd_display': ../applications/main.c:80:5: warning: implicit declaration of function 'LCD_Init' [-Wimplicit-function-declaration] LCD_Init(); //鍒濆鍖朙CD FSMC鎺ュ彛 ^ ../applications/main.c:81:5: error: 'POINT_COLOR' undeclared (first use in this function) POINT_COLOR=RED; //鐢荤瑪棰滆壊锛氱孩鑹? ^ ../applications/main.c:81:17: error: 'RED' undeclared (first use in this function) POINT_COLOR=RED; //鐢荤瑪棰滆壊锛氱孩鑹? ^ ../applications/main.c:82:5: warning: implicit declaration of function 'sprintf' [-Wimplicit-function-declaration] sprintf((char*)lcd_id,"LCD ID:%04X",lcddev.id);//灏哃CD ID鎵撳嵃鍒發cd_id鏁扮粍銆? ^ ../applications/main.c:82:5: warning: incompatible implicit declaration of built-in function 'sprintf' ../applications/main.c:82:5: note: include '
' or provide a declaration of 'sprintf' ../applications/main.c:82:41: error: 'lcddev' undeclared (first use in this function) sprintf((char*)lcd_id,"LCD ID:%04X",lcddev.id);//灏哃CD ID鎵撳嵃鍒發cd_id鏁扮粍銆? ^ ../applications/main.c:87:20: warning: implicit declaration of function 'LCD_Clear' [-Wimplicit-function-declaration] case 0:LCD_Clear(WHITE);break; ^ ../applications/main.c:87:30: error: 'WHITE' undeclared (first use in this function) case 0:LCD_Clear(WHITE);break; ^ ../applications/main.c:88:30: error: 'BLACK' undeclared (first use in this function) case 1:LCD_Clear(BLACK);break; ^ ../applications/main.c:89:30: error: 'BLUE' undeclared (first use in this function) case 2:LCD_Clear(BLUE);break; ^ ../applications/main.c:91:30: error: 'MAGENTA' undeclared (first use in this function) case 4:LCD_Clear(MAGENTA);break; ^ ../applications/main.c:92:30: error: 'GREEN' undeclared (first use in this function) case 5:LCD_Clear(GREEN);break; ^ ../applications/main.c:93:30: error: 'CYAN' undeclared (first use in this function) case 6:LCD_Clear(CYAN);break; ^ ../applications/main.c:94:30: error: 'YELLOW' undeclared (first use in this function) case 7:LCD_Clear(YELLOW);break; ^ ../applications/main.c:95:30: error: 'BRRED' undeclared (first use in this function) case 8:LCD_Clear(BRRED);break; ^ ../applications/main.c:96:30: error: 'GRAY' undeclared (first use in this function) case 9:LCD_Clear(GRAY);break; ^ ../applications/main.c:97:31: error: 'LGRAY' undeclared (first use in this function) case 10:LCD_Clear(LGRAY);break; ^ ../applications/main.c:98:31: error: 'BROWN' undeclared (first use in this function) case 11:LCD_Clear(BROWN);break; ^ ../applications/main.c:101:9: warning: implicit declaration of function 'LCD_ShowString' [-Wimplicit-function-declaration] LCD_ShowString(30,40,210,24,24,"Explorer STM32F4"); ^ ../applications/main.c:108:9: warning: implicit declaration of function 'rt_pin_write' [-Wimplicit-function-declaration] rt_pin_write(LED0_PIN, PIN_HIGH); ^ ../applications/main.c:108:22: error: 'LED0_PIN' undeclared (first use in this function) rt_pin_write(LED0_PIN, PIN_HIGH); ^ ../applications/main.c:108:32: error: 'PIN_HIGH' undeclared (first use in this function) rt_pin_write(LED0_PIN, PIN_HIGH); ^ ../applications/main.c:110:32: error: 'PIN_LOW' undeclared (first use in this function) rt_pin_write(LED0_PIN, PIN_LOW); ^ ../applications/main.c:113:1: warning: no return statement in function returning non-void [-Wreturn-type] } ^ ../applications/main.c: At top level: ../applications/main.c:20:13: warning: 'MX_FSMC_Init' defined but not used [-Wunused-function] static void MX_FSMC_Init(void) ^ make: *** [applications/subdir.mk:21: applications/main.o] Error 1 make: *** Waiting for unfinished jobs.... "make -j12 all" terminated with exit code 2. Build might be incomplete. ``` 请问是哪些地方有问题?希望大佬给看一下。
2022-07-13
未定义的是一些类型,说明有头文件没加,main.c 里 include rtdevice.h 试试
670
小李_
RT-Thread Setings没有BSP_USING_LCD选项?
晶联讯19264液晶屏字库,可以读取字母、字符和数字,但是汉字读取显示错误
rtt studio裸机例程在调取头文件时编译会报错
使用littlevgl2rtt软件包实例运行不成功,emwin正常
qemu的LCD可以显示1920*720的分辨率?
移植潘多拉板子的lcd驱动到芯片上
缺少常用的LCD驱动软件包
h750XBH6 LCD rt_malloc 分配内存失败
rtthread fsmc驱动LCD代码无错误,且背光显示,但是无现象
stm32h743 lcd 驱动出现hardfault 问题
github高阶加速,速度可达带宽峰值,测试到146Mbit/s
英飞凌携手RT-Thread举办嵌入式网络应用开发沙龙,带你从0到1搭建智能数据网关
BL808 RT-Thread Wi-Fi 驱动适配
rt-thread 系统运行期改变网卡配置
简单的步进电机驱动调试
SDIO
AB32VG1
QEMU
1500
338
1389
276
714
157
522
153
1216
146
