udp
AT设备udp组播问题
发布于 2022-12-27 16:47:54 浏览:841
请问AT设备,支持通过SAL使用组播功能吗?逛了一圈论坛实现好像底层都是lwip的。 使用esp8266模块,setsockopt时报错显示不支持操作,看了一下好像是atsocket没实现相关操作? 日志如下所示 ```c msh />bing_test esp0 socket bind network interface device(esp0) success! [E/at.skt] AT socket (0) not support option level : 0. setsockopt failed ! msh /> ``` 测试代码如下: ```c #include
#define SERVER_PORT 8888 static int bing_test(int argc, char **argv) { struct sockaddr_in client_addr; struct sockaddr_in server_addr; struct netdev *netdev = RT_NULL; int sockfd = -1; if (argc != 2) { rt_kprintf("bind_test [netdev_name] --bind network interface device by name.\n"); return -RT_ERROR; } /* 通过名称获取 netdev 网卡对象 */ netdev = netdev_get_by_name(argv[1]); if (netdev == RT_NULL) { rt_kprintf("get network interface device(%s) failed.\n", argv[1]); return -RT_ERROR; } // 多播 IP 地址 char muticast_addr[16] = "239.255.0.1"; if ((sockfd = socket(AF_INET, SOCK_DGRAM, 0)) < 0) { rt_kprintf("Socket create failed.\n"); return -RT_ERROR; } /* 初始化需要绑定的客户端地址 */ client_addr.sin_family = AF_INET; client_addr.sin_port = htons(SERVER_PORT);//change /* 获取网卡对象中 IP 地址信息 */ client_addr.sin_addr.s_addr = netdev->ip_addr.addr; rt_memset(&(client_addr.sin_zero), 0, sizeof(client_addr.sin_zero)); if (bind(sockfd, (struct sockaddr *)&client_addr, sizeof(struct sockaddr)) < 0) { rt_kprintf("socket bind failed.\n"); closesocket(sockfd); return -RT_ERROR; } rt_kprintf("socket bind network interface device(%s) success!\n", netdev->name); // 多播地址结构体 struct ip_mreq mreq; mreq.imr_multiaddr.s_addr=inet_addr(muticast_addr); /* MSH_CMD_EXPORT(bing_test, bind network interface device test); #endif /* FINSH_USING_MSH */ ``` at ```c int at_getsockopt(int socket, int level, int optname, void *optval, socklen_t *optlen) { struct at_socket *sock; int32_t timeout; if (optval == RT_NULL || optlen == RT_NULL) { LOG_E("AT getsocketopt input option value or option length error!"); return -1; } sock = at_get_socket(socket); if (sock == RT_NULL) { return -1; } switch (level) { case SOL_SOCKET: switch (optname) { case SO_RCVTIMEO: timeout = sock->recv_timeout; ((struct timeval *)(optval))->tv_sec = (timeout) / 1000U; ((struct timeval *)(optval))->tv_usec = (timeout % 1000U) * 1000U; break; case SO_SNDTIMEO: timeout = sock->send_timeout; ((struct timeval *) optval)->tv_sec = timeout / 1000U; ((struct timeval *) optval)->tv_usec = (timeout % 1000U) * 1000U; break; default: LOG_E("AT socket (%d) not support option name : %d.", socket, optname); return -1; } break; default: LOG_E("AT socket (%d) not support option level : %d.", socket, level); return -1; } return 0; } ```
841
kuxiaogua999
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
STM32内存扩展,SRAM-RMC
