Ethernet_以太网
drv_eth_以太网驱动
STM32H743 以太网驱动 问题
发布于 2020-09-14 20:15:52 浏览:5285
 STM32H系列外设驱动已经支持了,什么时候更新呢?现在的版本调用以太网还是报错呢
liuduanfei
2020-09-15
H7的以太网还不支持,我可以发给你一份。
我心永恒~
2020-09-15
昨天公众号发布文章提到了支持了,但是目前RT-Thread Studio里的包貌似还没有更新呢
Ghazi
2020-09-15
要吗 我也可以发一份给你 嘿嘿
wujialing4000
2020-09-17
你好,H7的以太网我没有移植成功,可以发一份参考一下吗?十分感谢。邮箱是wujialing3000@163.com
fovery
2020-09-22
Simple yet extraordinary
我用了上面的驱动,出现如下问题: 开启drv_eth.c中的DRV_DEBUG,才可以在插拔网线时自动获得到IP,但是ping不通网关。 不知道有没有人遇到过?
Mestic英
2020-11-23
多谢大佬的驱动,白嫖党感激不尽,嫖完后,还增加修改了两个地方: 1、board.c增加MPU的配置 ``` void MPU_Config(void) { MPU_Region_InitTypeDef MPU_InitStruct; /* Disable the MPU */ HAL_MPU_Disable(); /* Configure the MPU attributes as Device not cacheable for ETH DMA descriptors */ MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = 0x30040000; MPU_InitStruct.Size = MPU_REGION_SIZE_256B; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER0; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0; MPU_InitStruct.SubRegionDisable = 0x00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); /* Configure the MPU attributes as Normal Non Cacheable for LwIP RAM heap which contains the Tx buffers */ MPU_InitStruct.Enable = MPU_REGION_ENABLE; MPU_InitStruct.BaseAddress = 0x30044000; MPU_InitStruct.Size = MPU_REGION_SIZE_16KB; MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS; MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE; MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE; MPU_InitStruct.IsShareable = MPU_ACCESS_SHAREABLE; MPU_InitStruct.Number = MPU_REGION_NUMBER1; MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL1; MPU_InitStruct.SubRegionDisable = 0x00; MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE; HAL_MPU_ConfigRegion(&MPU_InitStruct); /* Enable the MPU */ HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT); } ``` 2、修改drv_common.c ``` void hw_board_init(char *clock_src, int32_t clock_src_freq, int32_t clock_target_freq) { extern void rt_hw_systick_init(void); extern void clk_init(char *clk_source, int source_freq, int target_freq); #ifdef SCB_EnableICache /* Enable I-Cache---------------------------------------------------------*/ SCB_EnableICache(); #endif #ifdef SCB_EnableDCache /* Enable D-Cache---------------------------------------------------------*/ SCB_EnableDCache(); #endif extern void MPU_Config(void); extern void CPU_CACHE_Enable(void); SCB->VTOR = QSPI_BASE; MPU_Config(); // 增加MPU配置函数 CPU_CACHE_Enable(); /* HAL_Init() function is called at the beginning of the program */ HAL_Init(); ``` 3、修改link.lds编译连接脚本(让DMARxDscrTab、DMATxDscrTab、Rx_Buff连接到指定内存地址上) ``` MEMORY { ROM (rx) : ORIGIN =0x90000000,LENGTH =512k RAM (rw) : ORIGIN =0x24000000,LENGTH =512k RAM_D2_SRAM3 (xrw) : ORIGIN = 0x30040000, LENGTH = 32K /* 增加MEMORY */ } ``` ``` .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(.bss.*) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; *(.bss.init) } > RAM __bss_end = .; _end = .; /* 增加连接脚本 */ .lwip_sec (NOLOAD) : { . = ALIGN(4); *(.RxDecripSection) *(.TxDecripSection) *(.RxArraySection) . = ALIGN(4); } > RAM_D2_SRAM3 /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } ``` 附上参考工程 https://github.com/MysticChan/rtt_stm32h7_eth.git
role_2099
2021-02-18
大侠们,请教一下,最新的4.0.3对H7以太网支持的怎么样?
wangfan
2022-03-07
,能给我发一下么。wangfan0020@126.com,谢谢了
5.3k
我心永恒~
以太网先上电再连网线通信
ethernet 和 use memory layout冲突
stm32h743的LAN8720A驱动编译错误, 不知道怎么改
关于在stm32F107CVT6中使用以太网芯片DM9161AEP的内存不足异常
stm32F107+DM9161AEP的PHY芯片 运行出现错误
stm32f107+dm9161的phy芯片报错eth硬件初始化失败
stm32f107+DM9161出现硬件初始化问题
基于芯片建立工程,以太网卡无法使用
SPI总线挂接2个W5500以太网芯片
以太网不能ping通 返回receive frame faild
RT-Thread studio的驱动5.1.0报错修改
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
818
