关于rtt-studio下的串口和GPIO
发布于 2020-04-22 09:15:40 浏览:1240
我使用rtt-studio基于芯片创建了工程,按照官网给的例子控制uart和GPIO,代码如下**Uart部分代码:** ```rt_err_t uart3_input(rt_device_t dev, rt_size_t size) { /* 串口接收到数据后产生中断,调用此回调函数,然后发送接收信号量 */ if (size > 0) { rt_kprintf("uart3:msg is coming
"); rt_sem_release(&rx3_sem); } return RT_EOK; } char uart3_recieve(void) { char ch; while (rt_device_read(serial3, 0, &ch, 1) == 0) { rt_sem_control(&rx3_sem, RT_IPC_CMD_RESET, RT_NULL); rt_sem_take(&rx3_sem, RT_WAITING_FOREVER); } return ch; } void serial3_thread_entry(void *parameter) { char ch; while (1) { ch = uart3_recieve(); rt_device_write(serial3, 0, &ch, 1); } } rt_device_t uart3_thread(void) { char uart_name[RT_NAME_MAX]; char str[] = "open uart3_thread!
"; /* 查找串口设备 */ rt_strncpy(uart_name, UART3, RT_NAME_MAX); serial3 = rt_device_find(uart_name); if (!serial3) { rt_kprintf("find %s failed!
", uart_name); return serial3; } /* 初始化信号量 */ rt_sem_init(&rx3_sem, "rx3_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收方式打开串口设备 */ rt_device_open(serial3,RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX); /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial3, uart3_input); /* 发送字符串 */ rt_device_write(serial3, 0, str, (sizeof(str) - 1)); /* 创建 serial 线程 */ rt_thread_t thread = rt_thread_create("serial3", serial3_thread_entry, RT_NULL, 2048, 25, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { rt_kprintf("%s thread start failed!
", uart_name); return serial3; } rt_kprintf("%s start!
", uart_name); return serial3; }```**GPIO部分代码:** ```#define LED 37 #define XFS5152CE_RST 39 #define M5310A_RST 38 #define PC10 51 #define PC11 52 #define PC12 53 void gpio_init(void) { /* 设置PIN脚模式为输出 */ rt_pin_mode(LED, PIN_MODE_OUTPUT); rt_pin_mode(XFS5152CE_RST, PIN_MODE_OUTPUT); rt_pin_mode(M5310A_RST, PIN_MODE_OUTPUT); rt_pin_mode(PC10, PIN_MODE_OUTPUT); rt_pin_mode(PC11, PIN_MODE_OUTPUT); rt_pin_mode(PC12, PIN_MODE_OUTPUT); rt_pin_write(LED, PIN_LOW); rt_pin_write(XFS5152CE_RST, PIN_LOW); rt_pin_write(M5310A_RST, PIN_LOW); rt_pin_write(PC10, PIN_LOW); rt_pin_write(PC11, PIN_LOW); rt_pin_write(PC12, PIN_LOW); } void io_test(void *parameter) { int level = 0; while(1) { rt_thread_delay(1000); if(level==1) { rt_pin_write(LED,1); rt_kprintf("LED is on
"); level = 0; } else { rt_pin_write(LED,0); rt_kprintf("LED is off
"); level = 1; } } }```Uart问题是我无论发多少字节,总是只收到前两个字节,我断电跟踪也发现收到两字节后信号量就不释放了.譬如串口发abcd,程序只收到ab GPIO就是根据drv_gpio里面的管教号分配后,没效果 我的芯片是STM32F103RBT6
wx_gbq@163.com
2020-04-22
uart我通过改低波特率就可以读取到完整信息
wx_gbq@163.com
2020-04-22
问题解决,我将uart3_input函数内if判断下的rt_kprintf("uart3:msg is coming\n");删除就正常了
1.2k
wx_gbq@163.com
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
浅谈国产加密芯片的选择
[Vision Board创客营] PWM模块实践
FRDM-MCXN947 I2C(软件)使用
1506
339
1423
281
741
540
157
1218
146
