cpu:rt1052
fm24cl16的读写时序如下:
读写数据的函数如下
rt_err_t fm24clxx_write_page( struct rt_i2c_bus_device *dev,
uint8_t page_addr_7bit,
uint8_t wirteAddr, //fm24cl16内部存储地址
uint8_t *pBuffer,
uint16_t NumByteToWrite)
struct rt_i2c_msg msgs[2];
msgs[0].addr = page_addr_7bit ;
msgs[0].flags = RT_I2C_WR ;
msgs[0].buf = &wirteAddr;
msgs[0].len = 1;
msgs[1].addr = page_addr_7bit;
msgs[1].flags = RT_I2C_WR | RT_I2C_NO_START;
msgs[1].buf = pBuffer;
msgs[1].len = NumByteToWrite;
if(rt_i2c_transfer(dev, msgs, 2) != 2)
LOG_E("i2c write data failed!");
return RT_ERROR;
return RT_EOK;
rt_err_t fm24clxx_read_page(struct rt_i2c_bus_device *dev,
uint8_t readAddr, //fm24cl16内部存储地址
uint8_t *pBuffer,
uint16_t NumByteToRead)
msgs[0].addr = page_addr_7bit;
msgs[0].buf = &readAddr;
msgs[0].len = 1;
msgs[1].flags = RT_I2C_RD;
msgs[1].len = NumByteToRead;
LOG_E("i2c read data failed!");
return RT_ERROR;
return RT_EOK;
实验测试:
#define FM24CLXX_ADDR_7BIT (0xA0 >> 1)
int fm24cl16_test(void)
uint8_t writebuf[]="welcome to rtt!";
struct rt_i2c_bus_device *i2c_bus = RT_NULL; /* I2C总线设备句柄 */
uint8_t addr =0;
uint8_t readbuf[20] ={0};
struct rt_i2c_bus_device *dev = RT_NULL;
dev = rt_i2c_bus_device_find("i2c1");
if(dev == RT_NULL)
LOG_E("cannot find i2c1 device!");
return RT_ERROR;
fm24clxx_write_page(dev,FM24CLXX_ADDR_7BIT,0,writebuf,sizeof(writebuf));
rt_thread_mdelay(100);
fm24clxx_read_page(dev,FM24CLXX_ADDR_7BIT,0,readbuf,sizeof(readbuf));
LOG_D("readbuf : %s",readbuf);
MSH_CMD_EXPORT(fm24cl16_test, fm24cl16 test);
最终测试结果:
裸机上用1052的官方库读写是没问题的,主要还是没理解rtt rt_i2c_transfer()函数的用法,所以请教大家问题可能在哪?
抱歉,没表达清楚,重新编辑了一下
参考链接
addr1 = msg->addr << 1;这个地方要重点注意一下,地址左移了一位
看下你的地址。
