RT-Thread studio解析链接文件失败,在MDK正常?
发布于 2020-10-10 10:18:23 浏览:1071
使用官方代码:https://github.com/RT-Thread/rt-thread/tree/master/bsp/imxrt/imxrt1064-nxp-evk 在RT-Thread studio解析链接文件失败,导致下载代码到单片机运行不了,而在MDK IDE正常: ``` Failed to create the part's controls. java.lang.ArrayIndexOutOfBoundsException: 2 at org.rtthread.studio.lds.edit.LdsMutiForm.initLds(LdsMutiForm.java:85) at org.rtthread.studio.lds.edit.LdsMutiForm.addPages(LdsMutiForm.java:45) at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEditor.java:143) at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:351) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:156) at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:102) at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:367) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ``` link.lds内容: ```asm /* Entry Point */ ENTRY(Reset_Handler) HEAP_SIZE = DEFINED(__heap_size__) ? __heap_size__ : 0x0400; STACK_SIZE = DEFINED(__stack_size__) ? __stack_size__ : 0x0400; /* Specify the memory areas */ MEMORY { m_boot_data (RX) : ORIGIN = 0x70000000, LENGTH = 0x00001000 m_image_vertor_table (RX) : ORIGIN = 0x70001000, LENGTH = 0x00001000 m_interrupts (RX) : ORIGIN = 0x70002000, LENGTH = 0x00000400 m_text (RX) : ORIGIN = 0x70002400, LENGTH = 0x003FDC00 m_itcm (RW) : ORIGIN = 0x00000000, LENGTH = 0x00020000 m_dtcm (RW) : ORIGIN = 0x20000000, LENGTH = 0x00020000 m_ocram (RW) : ORIGIN = 0x20200000, LENGTH = 0x00040000 m_sdram (RW) : ORIGIN = 0x80000000, LENGTH = 0x01E00000 m_nocache (RW) : ORIGIN = 0x81E00000, LENGTH = 0x00200000 } /* Define output sections */ SECTIONS { .boot_data : { . = ALIGN(4); __FLASH_BASE = .; KEEP(* (.boot_hdr.conf)) /* flash config section */ . = ALIGN(4); } > m_boot_data ivt_begin= ORIGIN(m_boot_data) + LENGTH(m_boot_data); .image_vertor_table : AT(ivt_begin) { . = ALIGN(4); KEEP(*(.boot_hdr.ivt)) KEEP(*(.boot_hdr.boot_data)) KEEP(*(.boot_hdr.dcd_data)) . = ALIGN(4); } > m_image_vertor_table /* The startup code goes first into internal RAM */ .interrupts : { __VECTOR_TABLE = .; . = ALIGN(4); KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(4); } > m_interrupts __VECTOR_RAM = __VECTOR_TABLE; __RAM_VECTOR_TABLE_SIZE_BYTES = 0x0; /* The program code and other data goes into internal RAM */ .text : { . = ALIGN(4); *(.text) /* .text sections (code) */ *(.text*) /* .text* sections (code) */ *(.rodata) /* .rodata sections (constants, strings, etc.) */ *(.rodata*) /* .rodata* sections (constants, strings, etc.) */ *(.glue_7) /* glue arm to thumb code */ *(.glue_7t) /* glue thumb to arm code */ *(.eh_frame) KEEP (*(.init)) KEEP (*(.fini)) . = ALIGN(4); /* section information for finsh shell */ . = ALIGN(4); __fsymtab_start = .; KEEP(*(FSymTab)) __fsymtab_end = .; . = ALIGN(4); __vsymtab_start = .; KEEP(*(VSymTab)) __vsymtab_end = .; . = ALIGN(4); /* section information for initial. */ . = ALIGN(4); __rt_init_start = .; KEEP(*(SORT(.rti_fn*))) __rt_init_end = .; } > m_text .ARM.extab : { *(.ARM.extab* .gnu.linkonce.armextab.*) } > m_text .ARM : { __exidx_start = .; *(.ARM.exidx*) __exidx_end = .; } > m_text .ctors : { PROVIDE(__ctors_start__ = .); /* __CTOR_LIST__ = .; */ /* gcc uses crtbegin.o to find the start of the constructors, so we make sure it is first. Because this is a wildcard, it doesn't matter if the user does not actually link against crtbegin.o; the linker won't look for a file to match a wildcard. The wildcard also means that it doesn't matter which directory crtbegin.o is in. */ KEEP (*crtbegin.o(.ctors)) KEEP (*crtbegin?.o(.ctors)) /* We don't want to include the .ctor section from from the crtend.o file until after the sorted ctors. The .ctor section from the crtend file contains the end of ctors marker and it must be last */ KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)) KEEP (*(SORT(.ctors.*))) KEEP (*(.ctors)) /* __CTOR_END__ = .; */ PROVIDE(__ctors_end__ = .); } > m_text .dtors : { PROVIDE(__dtors_start__ = .); /* __DTOR_LIST__ = .; */ KEEP (*crtbegin.o(.dtors)) KEEP (*crtbegin?.o(.dtors)) KEEP (*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)) KEEP (*(SORT(.dtors.*))) KEEP (*(.dtors)) /* __DTOR_END__ = .; */ PROVIDE(__dtors_end__ = .); } > m_text .preinit_array : { PROVIDE_HIDDEN (__preinit_array_start = .); KEEP (*(.preinit_array*)) PROVIDE_HIDDEN (__preinit_array_end = .); } > m_text .init_array : { PROVIDE_HIDDEN (__init_array_start = .); KEEP (*(SORT(.init_array.*))) KEEP (*(.init_array*)) PROVIDE_HIDDEN (__init_array_end = .); } > m_text .fini_array : { PROVIDE_HIDDEN (__fini_array_start = .); KEEP (*(SORT(.fini_array.*))) KEEP (*(.fini_array*)) PROVIDE_HIDDEN (__fini_array_end = .); } > m_text __etext = .; /* define a global symbol at end of code */ __DATA_ROM = .; /* Symbol is used by startup for data initialization */ .data : AT(__DATA_ROM) { . = ALIGN(4); __DATA_RAM = .; __data_start__ = .; /* create a global symbol at data start */ *(m_usb_dma_init_data) *(.data) /* .data sections */ *(.data*) /* .data* sections */ KEEP(*(.jcr*)) . = ALIGN(4); __data_end__ = .; /* define a global symbol at data end */ } > m_dtcm __NDATA_ROM = __DATA_ROM + (__data_end__ - __data_start__); .ncache.init : AT(__NDATA_ROM) { __noncachedata_start__ = .; /* create a global symbol at ncache data start */ *(NonCacheable.init) . = ALIGN(4); __noncachedata_init_end__ = .; /* create a global symbol at initialized ncache data end */ } > m_nocache . = __noncachedata_init_end__; .ncache : { *(NonCacheable) . = ALIGN(4); __noncachedata_end__ = .; /* define a global symbol at ncache data end */ } > m_nocache __DATA_END = __NDATA_ROM + (__noncachedata_init_end__ - __noncachedata_start__); text_end = ORIGIN(m_text) + LENGTH(m_text); ASSERT(__DATA_END <= text_end, "region m_text overflowed with text and data") /* Uninitialized data section */ .bss : { /* This is used by the startup in order to initialize the .bss section */ . = ALIGN(4); __START_BSS = .; __bss_start__ = .; *(m_usb_dma_noninit_data) *(.bss) *(.bss*) *(COMMON) . = ALIGN(4); __bss_end__ = .; __END_BSS = .; } > m_dtcm .stack : { . = ALIGN(8); stack_start = .; . += STACK_SIZE; stack_end = .; __StackTop = .; } > m_dtcm .RTT_HEAP : { heap_start = .; . = ALIGN(8); } > m_dtcm PROVIDE(heap_end = ORIGIN(m_dtcm) + LENGTH(m_dtcm)); .ARM.attributes 0 : { *(.ARM.attributes) } } ```
rcp
2020-10-10
看报错是,双击打开链接脚本文件的时候报错了,应该是图形界面解析的时候没考虑到你这样的格式 那换用文本编辑器打开吧,应该不影响工程构建以及下载运行,直接在文本编辑器里编辑了保存后,构建工程 ![image.png](/uploads/20201010/ab201b79b0756ca25244503eb91532c2.png)
1.1k
https://jswyll.com/
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
aeniac
zhuzhuzhu
