STM32H743
求一个stm32h743的flash驱动
发布于 2021-01-24 14:32:38 浏览:1796
本人现在在开发stm32h743的bootloader,现在遇到的问题是下载固件到download分区后,写入app分区出错。后来问了大佬之后,说是flash驱动有问题,我自己看了之后没找到问题在哪,所以求一份stm32h743的flash驱动![QQ图片20210124143119.png](https://oss-club.rt-thread.org/uploads/20210124/4a53fcdf35fbcf8a69a79d15b4e1c8f0.png)
红枫
2021-01-25
```c /* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2018-12-5 SummerGift first version * 2019-3-2 jinsheng add Macro judgment * 2020-1-6 duminmin support single bank mode * 2020-5-17 yufanyufan77 support support H7 */ #include "board.h" #ifdef BSP_USING_ON_CHIP_FLASH #include "drv_config.h" #include "drv_flash.h" #if defined(PKG_USING_FAL) #include "fal.h" #endif //#define DRV_DEBUG #define LOG_TAG "drv.flash" #include
/** * @brief Gets the Sector of a given address * @param Addr: Address of the FLASH Memory * @retval The page of a given address */ static uint32_t GetSector(uint32_t Addr) { uint32_t Sector = 0; if (Addr < (FLASH_BASE + FLASH_BANK_SIZE)) { /* Bank 1 */ Sector = (Addr - FLASH_BASE) / FLASH_SECTOR_SIZE; } else { /* Bank 2 */ Sector = (Addr - (FLASH_BASE + FLASH_BANK_SIZE)) / FLASH_SECTOR_SIZE; } return Sector; } /** * @brief Gets the bank of a given address * @param Addr: Address of the FLASH Memory * @retval The bank of a given address */ static uint32_t GetBank(uint32_t Addr) { uint32_t bank = 0; #ifndef FLASH_BANK_2 bank = FLASH_BANK_1; #else //if (READ_BIT(SYSCFG->MEMRMP, SYSCFG_MEMRMP_FB_MODE) == 0) //{ /* No Bank swap */ if (Addr < (FLASH_BASE + FLASH_BANK_SIZE)) { bank = FLASH_BANK_1; } else { bank = FLASH_BANK_2; } //} //else //{ /* Bank swap */ // if (Addr < (FLASH_BASE + FLASH_BANK_SIZE)) // { // bank = FLASH_BANK_2; // } // else // { // bank = FLASH_BANK_1; // } //} #endif return bank; } /** * Read data from flash. * @note This operation's units is word. * * @param addr flash address * @param buf buffer to store read data * @param size read bytes size * * @return result */ int stm32_flash_read(rt_uint32_t addr, rt_uint8_t *buf, size_t size) { size_t i; if ((addr + size) > STM32_FLASH_END_ADDRESS) { LOG_E("read outrange flash size! addr is (0x%p)", (void *)(addr + size)); return -1; } for (i = 0; i < size; i++, buf++, addr++) { *buf = *(rt_uint8_t *) addr; } return size; } /** * Write data to flash. * @note This operation's units is word. * @note This operation must after erase. @see flash_erase. * * @param addr flash address * @param buf the write data buffer * @param size write bytes size * * @return result */ int stm32_flash_write(rt_uint32_t addr, const rt_uint8_t *buf, size_t size) { rt_err_t result = RT_EOK; rt_uint32_t end_addr = addr + size; if ((end_addr) > STM32_FLASH_END_ADDRESS) { LOG_E("write outrange flash size! addr is (0x%p)", (void *)(addr + size)); return -RT_EINVAL; } if (size < 1) { return -RT_EINVAL; } /* Unlock the Flash to enable the flash control register access */ HAL_FLASH_Unlock(); __HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR ); while(addr < end_addr) { /* write data to flash */ if (HAL_FLASH_Program(FLASH_TYPEPROGRAM_FLASHWORD, addr, (uint32_t)buf) != HAL_OK) { result = -RT_ERROR; break; } addr += 32; buf += 32; } HAL_FLASH_Lock(); if (result != RT_EOK) { return result; } return size; } /** * Erase data on flash. * @note This operation is irreversible. * @note This operation's units is different which on many chips. * * @param addr flash address * @param size erase bytes size * * @return result */ int stm32_flash_erase(rt_uint32_t addr, size_t size) { rt_err_t result = RT_EOK; rt_uint32_t FirstSector = 0, NbOfSectors = 0; rt_uint32_t SECTORError = 0; rt_uint32_t bank = 0; if ((addr + size) > STM32_FLASH_END_ADDRESS) { LOG_E("ERROR: erase outrange flash size! addr is (0x%p)\n", (void *)(addr + size)); return -RT_EINVAL; } /*Variable used for Erase procedure*/ FLASH_EraseInitTypeDef EraseInitStruct; /* Unlock the Flash to enable the flash control register access */ HAL_FLASH_Unlock(); /* Get the 1st sector to erase */ bank = GetBank(addr); FirstSector = GetSector(addr); NbOfSectors = GetSector(addr + size - 1); NbOfSectors = NbOfSectors - FirstSector + 1; /* Fill EraseInit structure */ EraseInitStruct.TypeErase = FLASH_TYPEERASE_SECTORS; EraseInitStruct.VoltageRange = FLASH_VOLTAGE_RANGE_3; EraseInitStruct.Sector = FirstSector; EraseInitStruct.NbSectors = NbOfSectors; EraseInitStruct.Banks = bank; if (HAL_FLASHEx_Erase(&EraseInitStruct, &SECTORError) != HAL_OK) { result = -RT_ERROR; goto __exit; } __exit: HAL_FLASH_Lock(); if (result != RT_EOK) { return result; } LOG_D("erase done: addr (0x%p), size %d", (void *)addr, size); return size; } #if defined(PKG_USING_FAL) static int fal_flash_read_128k(long offset, rt_uint8_t *buf, size_t size); static int fal_flash_write_128k(long offset, const rt_uint8_t *buf, size_t size); static int fal_flash_erase_128k(long offset, size_t size); const struct fal_flash_dev stm32_onchip_flash_128k = { "onchip_flash_128k", STM32_FLASH_START_ADRESS, STM32_FLASH_SIZE, FLASH_SECTOR_SIZE, {NULL, fal_flash_read_128k, fal_flash_write_128k, fal_flash_erase_128k} }; static int fal_flash_read_128k(long offset, rt_uint8_t *buf, size_t size) { return stm32_flash_read(stm32_onchip_flash_128k.addr + offset, buf, size); } static int fal_flash_write_128k(long offset, const rt_uint8_t *buf, size_t size) { return stm32_flash_write(stm32_onchip_flash_128k.addr + offset, buf, size); } static int fal_flash_erase_128k(long offset, size_t size) { return stm32_flash_erase(stm32_onchip_flash_128k.addr + offset, size); } #endif #endif /* BSP_USING_ON_CHIP_FLASH */ ```
2021-01-24
①②③
去下个H743的官方BSP看看
1.8k
link11
OTA 片上FLASH擦除失败
请问 怎么实现flash的FIFO存储呢
FAL初始化输出调试信息bug
spi1挂载w25q32失败
SD卡与外置flash(dg25q32)一起应用,挂载spi2总线上
w25q128 flash 怎么在电脑和开发板上切换挂载
RTT没有对FLASH进行操作的指令吗
使用FAL接口写的片内flash的擦除函数会死掉
关于潘多拉flash操作例程的
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
zhuzhuzhu
YDPB_5935
aeniac
