WDT
看门狗不能关闭,STOP控制字没有实现
发布于 2021-08-18 20:08:01 浏览:929
RTT看门狗驱动里面不支持停止吗,control里面没有STOP的相关控制字 ```c static rt_err_t wdt_control(rt_watchdog_t *wdt, int cmd, void *arg) { switch (cmd) { /* feed the watchdog */ case RT_DEVICE_CTRL_WDT_KEEPALIVE: if(HAL_IWDG_Refresh(&stm32_wdt.hiwdg) != HAL_OK) { LOG_E("watch dog keepalive fail."); } break; /* set watchdog timeout */ case RT_DEVICE_CTRL_WDT_SET_TIMEOUT: #if defined(LSI_VALUE) if(LSI_VALUE) { stm32_wdt.hiwdg.Init.Reload = (*((rt_uint32_t*)arg)) * LSI_VALUE / 256 ; } else { LOG_E("Please define the value of LSI_VALUE!"); } if(stm32_wdt.hiwdg.Init.Reload > 0xFFF) { LOG_E("wdg set timeout parameter too large, please less than %ds",0xFFF * 256 / LSI_VALUE); return -RT_EINVAL; } #else #error "Please define the value of LSI_VALUE!" #endif if(stm32_wdt.is_start) { if (HAL_IWDG_Init(&stm32_wdt.hiwdg) != HAL_OK) { LOG_E("wdg set timeout failed."); return -RT_ERROR; } } break; case RT_DEVICE_CTRL_WDT_GET_TIMEOUT: #if defined(LSI_VALUE) if(LSI_VALUE) { (*((rt_uint32_t*)arg)) = stm32_wdt.hiwdg.Init.Reload * 256 / LSI_VALUE; } else { LOG_E("Please define the value of LSI_VALUE!"); } #else #error "Please define the value of LSI_VALUE!" #endif break; case RT_DEVICE_CTRL_WDT_START: if (HAL_IWDG_Init(&stm32_wdt.hiwdg) != HAL_OK) { LOG_E("wdt start failed."); return -RT_ERROR; } stm32_wdt.is_start = 1; break; default: LOG_W("This command is not supported."); return -RT_ERROR; } return RT_EOK; } ``` 而且看门狗的rt_watchdog_stop也没用,底层还是调用的control函数 ```c static rt_err_t rt_watchdog_close(struct rt_device *dev) { rt_watchdog_t *wtd; RT_ASSERT(dev != RT_NULL); wtd = (rt_watchdog_t *)dev; if (wtd->ops->control(wtd, RT_DEVICE_CTRL_WDT_STOP, RT_NULL) != RT_EOK) { rt_kprintf(" This watchdog can not be stoped\n"); return (-RT_ERROR); } return (RT_EOK); } ``` 请教各位大佬。
123
2021-08-19
楼主很细心,点个赞。下面解释下问题,纯属个人理解: 假如有个 寄存器值 可以通过 软件触发的方式 关闭看门狗功能,那是否意味着程序意外跑飞的时候有可能刚好修改了这个寄存器值,导致看门狗功能关闭,从而使得咬狗的动作失败?进一步讲,是否意味着程序跑飞,看门狗仍然无法起到作用?引申出来,既然看门狗开启后功能无法得到有效保证,那么设计硬件看门狗的初衷也就违背了。 所以编程的时候一再强调,知其然更要知其所以然,要不然做出来的东西永远都是demo或者玩具,不是一个合格的产品。
2021-08-19
被你发现了,如有需要,你可以自己添加。 但是,看门狗,没有关闭的理念,要么不用,想用就是本着无人值守自我恢复考虑的,不能关闭,又要有关闭的需求,需求逻辑自相矛盾。
929
wqwang
24
RT-Thread Studio 开启WDT编译出错
stm32g0 设备驱动框架 wdt adc 报错
使用看门狗时有while(1)线程,程序运行就卡死
为什么rt-thread没有看门狗服务?
创建开门狗时出现系统卡死
21
rvcore
