注释
为什么rtt设备框架的源码注释好少?
发布于 2021-10-10 21:41:43 浏览:766
```c /* * Serial DMA routines */ rt_inline int _serial_dma_rx(struct rt_serial_device *serial, rt_uint8_t *data, int length) { rt_base_t level; RT_ASSERT((serial != RT_NULL) && (data != RT_NULL)); level = rt_hw_interrupt_disable(); if (serial->config.bufsz == 0) { int result = RT_EOK; struct rt_serial_rx_dma *rx_dma; rx_dma = (struct rt_serial_rx_dma*)serial->serial_rx; RT_ASSERT(rx_dma != RT_NULL); if (rx_dma->activated != RT_TRUE) { rx_dma->activated = RT_TRUE; RT_ASSERT(serial->ops->dma_transmit != RT_NULL); serial->ops->dma_transmit(serial, data, length, RT_SERIAL_DMA_RX); } else result = -RT_EBUSY; rt_hw_interrupt_enable(level); if (result == RT_EOK) return length; rt_set_errno(result); return 0; } else { struct rt_serial_rx_fifo *rx_fifo = (struct rt_serial_rx_fifo *) serial->serial_rx; rt_size_t recv_len = 0, fifo_recved_len = rt_dma_calc_recved_len(serial); RT_ASSERT(rx_fifo != RT_NULL); if (length < (int)fifo_recved_len) recv_len = length; else recv_len = fifo_recved_len; if (rx_fifo->get_index + recv_len < serial->config.bufsz) rt_memcpy(data, rx_fifo->buffer + rx_fifo->get_index, recv_len); else { rt_memcpy(data, rx_fifo->buffer + rx_fifo->get_index, serial->config.bufsz - rx_fifo->get_index); rt_memcpy(data + serial->config.bufsz - rx_fifo->get_index, rx_fifo->buffer, recv_len + rx_fifo->get_index - serial->config.bufsz); } rt_dma_recv_update_get_index(serial, recv_len); rt_hw_interrupt_enable(level); return recv_len; } } ``` ```c /** * @brief Handles DMA interrupt request. * @param hdma pointer to a DMA_HandleTypeDef structure that contains * the configuration information for the specified DMA Stream. * @retval None */ void HAL_DMA_IRQHandler(DMA_HandleTypeDef *hdma) { uint32_t tmpisr; __IO uint32_t count = 0U; uint32_t timeout = SystemCoreClock / 9600U; /* calculate DMA base and stream number */ DMA_Base_Registers *regs = (DMA_Base_Registers *)hdma->StreamBaseAddress; tmpisr = regs->ISR; /* Transfer Error Interrupt management ***************************************/ if ((tmpisr & (DMA_FLAG_TEIF0_4 << hdma->StreamIndex)) != RESET) { if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_TE) != RESET) { /* Disable the transfer error interrupt */ hdma->Instance->CR &= ~(DMA_IT_TE); /* Clear the transfer error flag */ regs->IFCR = DMA_FLAG_TEIF0_4 << hdma->StreamIndex; /* Update error code */ hdma->ErrorCode |= HAL_DMA_ERROR_TE; } } /* FIFO Error Interrupt management ******************************************/ if ((tmpisr & (DMA_FLAG_FEIF0_4 << hdma->StreamIndex)) != RESET) { if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_FE) != RESET) { /* Clear the FIFO error flag */ regs->IFCR = DMA_FLAG_FEIF0_4 << hdma->StreamIndex; /* Update error code */ hdma->ErrorCode |= HAL_DMA_ERROR_FE; } } /* Direct Mode Error Interrupt management ***********************************/ if ((tmpisr & (DMA_FLAG_DMEIF0_4 << hdma->StreamIndex)) != RESET) { if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_DME) != RESET) { /* Clear the direct mode error flag */ regs->IFCR = DMA_FLAG_DMEIF0_4 << hdma->StreamIndex; /* Update error code */ hdma->ErrorCode |= HAL_DMA_ERROR_DME; } } /* Half Transfer Complete Interrupt management ******************************/ if ((tmpisr & (DMA_FLAG_HTIF0_4 << hdma->StreamIndex)) != RESET) { if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_HT) != RESET) { /* Clear the half transfer complete flag */ regs->IFCR = DMA_FLAG_HTIF0_4 << hdma->StreamIndex; /* Multi_Buffering mode enabled */ if(((hdma->Instance->CR) & (uint32_t)(DMA_SxCR_DBM)) != RESET) { /* Current memory buffer used is Memory 0 */ if((hdma->Instance->CR & DMA_SxCR_CT) == RESET) { if(hdma->XferHalfCpltCallback != NULL) { /* Half transfer callback */ hdma->XferHalfCpltCallback(hdma); } } /* Current memory buffer used is Memory 1 */ else { if(hdma->XferM1HalfCpltCallback != NULL) { /* Half transfer callback */ hdma->XferM1HalfCpltCallback(hdma); } } } else { /* Disable the half transfer interrupt if the DMA mode is not CIRCULAR */ if((hdma->Instance->CR & DMA_SxCR_CIRC) == RESET) { /* Disable the half transfer interrupt */ hdma->Instance->CR &= ~(DMA_IT_HT); } if(hdma->XferHalfCpltCallback != NULL) { /* Half transfer callback */ hdma->XferHalfCpltCallback(hdma); } } } } /* Transfer Complete Interrupt management ***********************************/ if ((tmpisr & (DMA_FLAG_TCIF0_4 << hdma->StreamIndex)) != RESET) { if(__HAL_DMA_GET_IT_SOURCE(hdma, DMA_IT_TC) != RESET) { /* Clear the transfer complete flag */ regs->IFCR = DMA_FLAG_TCIF0_4 << hdma->StreamIndex; if(HAL_DMA_STATE_ABORT == hdma->State) { /* Disable all the transfer interrupts */ hdma->Instance->CR &= ~(DMA_IT_TC | DMA_IT_TE | DMA_IT_DME); hdma->Instance->FCR &= ~(DMA_IT_FE); if((hdma->XferHalfCpltCallback != NULL) || (hdma->XferM1HalfCpltCallback != NULL)) { hdma->Instance->CR &= ~(DMA_IT_HT); } /* Clear all interrupt flags at correct offset within the register */ regs->IFCR = 0x3FU << hdma->StreamIndex; /* Process Unlocked */ __HAL_UNLOCK(hdma); /* Change the DMA state */ hdma->State = HAL_DMA_STATE_READY; if(hdma->XferAbortCallback != NULL) { hdma->XferAbortCallback(hdma); } return; } if(((hdma->Instance->CR) & (uint32_t)(DMA_SxCR_DBM)) != RESET) { /* Current memory buffer used is Memory 0 */ if((hdma->Instance->CR & DMA_SxCR_CT) == RESET) { if(hdma->XferM1CpltCallback != NULL) { /* Transfer complete Callback for memory1 */ hdma->XferM1CpltCallback(hdma); } } /* Current memory buffer used is Memory 1 */ else { if(hdma->XferCpltCallback != NULL) { /* Transfer complete Callback for memory0 */ hdma->XferCpltCallback(hdma); } } } /* Disable the transfer complete interrupt if the DMA mode is not CIRCULAR */ else { if((hdma->Instance->CR & DMA_SxCR_CIRC) == RESET) { /* Disable the transfer complete interrupt */ hdma->Instance->CR &= ~(DMA_IT_TC); /* Process Unlocked */ __HAL_UNLOCK(hdma); /* Change the DMA state */ hdma->State = HAL_DMA_STATE_READY; } if(hdma->XferCpltCallback != NULL) { /* Transfer complete callback */ hdma->XferCpltCallback(hdma); } } } } ``` 如题,如代码段,rtt的函数51行,只右一行的注释。 hal库的函数216行,几乎是隔一行或者一个条件语句就有注释。 本人新手,想借着rtt学习学习。总体感觉看rtt像是在崇山峻岭里冒险,而看hal库是在平原里奔驰。 虽然我没有很多的项目经验,但个人感觉一个代码规范良好的项目不该是这个样子呀,难道是我切入的角度不对吗?
mysterywolf
2021-10-10
这是个问题,在4.0.5版本会有改善,4.0.4版本主要是将内核的注释补充的比较完整了。没有注释确实对初学者不友好。感谢反馈。
766
小号的高速
如何配置koro1FileHeader使注释与RT-Thread 注释风格一致?
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
zhuzhuzhu
YDPB_5935
aeniac
