gcc
[bsp][lpc55sxx] scons 编译不过
发布于 2021-10-20 16:45:16 浏览:1576
进入到 https://github.com/RT-Thread/rt-thread/tree/master/bsp/lpc55sxx/lpc55s69_nxp_evk 目录,然后用scons 编译,编译的时候编译不过, 修改board.h 为如下代码 ``` #if defined(__CC_ARM) || defined(__CLANG_ARM) extern int Image$$ARM_LIB_HEAP$$ZI$$Base; extern int Image$$ARM_LIB_STACK$$ZI$$Base; #define HEAP_BEGIN ((void *)&Image$$ARM_LIB_HEAP$$ZI$$Base) #define HEAP_END ((void*)&Image$$ARM_LIB_STACK$$ZI$$Base) #elif defined(__ICCARM__) #pragma section="HEAP" #define HEAP_BEGIN (__segment_end("HEAP")) #elif defined(__GNUC__) extern int __HeapBase; extern int __HeapLimit; #define HEAP_BEGIN ((void *)&__HeapBase) #define HEAP_END ((void *)&__HeapLimit) #endif ``` 修改文件bsp\lpc55sxx\Libraries\LPC55S6X\LPC55S6X\gcc\startup_LPC55S69_cm33_core0.S 这里的main改为entry 再编译scons 出现如下log ``` LINK rtthread.elf c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-abort.o): In function `abort': abort.c:(.text.abort+0xa): undefined reference to `_exit' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-signalr.o): In function `_kill_r': signalr.c:(.text._kill_r+0x10): undefined reference to `_kill' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-signalr.o): In function `_getpid_r': signalr.c:(.text._getpid_r+0x0): undefined reference to `_getpid' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-writer.o): In function `_write_r': writer.c:(.text._write_r+0x12): undefined reference to `_write' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-closer.o): In function `_close_r': closer.c:(.text._close_r+0xc): undefined reference to `_close' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-fstatr.o): In function `_fstat_r': fstatr.c:(.text._fstat_r+0x10): undefined reference to `_fstat' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-isattyr.o): In function `_isatty_r': isattyr.c:(.text._isatty_r+0xc): undefined reference to `_isatty' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-lseekr.o): In function `_lseek_r': lseekr.c:(.text._lseek_r+0x12): undefined reference to `_lseek' c:/h414630/01_project/01_x1000/env_released_1.2.0/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/lib/armv7e-m/fpu\libc.a(lib_a-readr.o): In function `_read_r': readr.c:(.text._read_r+0x12): undefined reference to `_read' collect2.exe: error: ld returned 1 exit status scons: *** [rtthread.elf] Error 1 scons: building terminated because of errors. ``` 大伙有没有人遇到这个问题?有没有什么好的解决办法?KEIL工程是可以正常运行和使用的。
李肯陪你玩赚嵌入式
2021-10-20
“KEIL工程是可以正常运行和使用的” -》 KEIL环境是不是配置了不使用标准C库? 如果是,使用gcc编译环境,可以在LDFLAGS 加上 -nostdlib 试试看? 看你的编译log,虽然你上次没有显式依赖libc(-lc),但是最后还是去链接了标准c库。
2021-10-20
libc.a 不用它就好了
2021-10-21
@recan @出出啊 大佬们,可否帮忙复现一下,看看如何解决呢?看上去简单操作一下就能很容易复现。这边我已经把libc.a相关的编译选项去掉了。
1.6k
545
82
scons不支持python3吗?
编译又出现问题
BSP目录下做好一个项目后,怎么把发给别人的包裁剪的小...
为什么重新scons --target=mdk 后,以前在MDK工程里保存的C文
Scons 添加Group,SConscript已经执行,源码却没有添加进工程
scons如何指定输出目录?
新人求助。
想用env 工具自己构建编译环境想用vscode 进行一些简单程序
关于scons脚本问题
使用scons --target=makefile的问题
STM32内存扩展,SRAM-RMC
新版OneNet的星火1号开发板例程适配(下)
tjrong
yans
alight
Pai同学
Rick98
WenShan
