onenet
STM32H7板子RTT上Mqtt连接OneNet云发数据失败
发布于 2023-10-11 21:50:36 浏览:915
1. 在mqtt start函数中配置如下 ```c int mqtt_start(void) { /* init condata param by using MQTTPacket_connectData_initializer */ MQTTPacket_connectData condata = MQTTPacket_connectData_initializer; if (is_started) { DEBUG_PRINT("mqtt client is already connected."); return -1; } /* config MQTT context param */ { client.isconnected = 0; client.uri = MQTT_SERVER_URI; /* generate the random client ID */ /* config connect param */ rt_memcpy(&client.condata, &condata, sizeof(condata)); client.condata.clientID.cstring = MQTT_CLIENTID; client.condata.keepAliveInterval = 60; client.condata.cleansession = 1; client.condata.username.cstring = MQTT_USERNAME; client.condata.password.cstring = MQTT_PASSWORD; /* config MQTT will param. */ client.condata.willFlag = 0; // client.condata.will.qos = 1; // client.condata.will.retained = 0; // client.condata.will.topicName.cstring = MQTT_PUBTOPIC; // client.condata.will.message.cstring = MQTT_WILLMSG; /* rt_malloc buffer. */ client.buf_size = client.readbuf_size = 1024 * 2; client.buf = rt_calloc(1, client.buf_size); client.readbuf = rt_calloc(1, client.readbuf_size); if (!(client.buf && client.readbuf)) { DEBUG_PRINT("no memory for MQTT client buffer!"); return -1; } /* set event callback function */ client.connect_callback = mqtt_connect_callback; client.online_callback = mqtt_online_callback; client.offline_callback = mqtt_offline_callback; /* set subscribe table and event callback */ client.messageHandlers[0].topicFilter = rt_strdup(MQTT_SUBTOPIC); client.messageHandlers[0].callback = mqtt_sub_callback; client.messageHandlers[0].qos = QOS1; /* set default subscribe event callback */ client.defaultMessageHandler = mqtt_sub_default_callback; } /* run mqtt client */ paho_mqtt_start(&client); is_started = 1; mapp_mqtt_subscribe(); return 0; } ``` 其中 ```c #define MQTT_SERVER_URI "tcp://mqtts.heclouds.com:1883" //#define MQTT_SERVER_URI "tcp://183.230.40.96:1883" #define MQTT_CLIENTID "mCtrl_Device" #define MQTT_USERNAME "q03px7K8O9" #define MQTT_PASSWORD "version=2018-10-31&res=products%2Fq03px7K8O9%2Fdevices%2FmCtrl_Device&et=1924833600&method=md5&sign=j2Nrp%2FoZSqHQAR%2F%2FlZ5lQw%3D%3D" #define MQTT_SUBTOPIC "$sys/q03px7K8O9/mCtrl_Device/thing/property/set" //#define MQTT_PUBTOPIC "$sys/q03px7K8O9/mCtrl_Device/thing/property/set_reply" #define MQTT_PUBTOPIC "$sys/q03px7K8O9/mCtrl_Device/thing/property/post" #define MQTT_WILLMSG "Willexit" ``` 设备start后没啥问题,后台也显示在线   而且订阅的消息也是可以收到:  一发数据就会掉线,数据发不上去:  打印上显示这里直接跳出去了
stdu_rtthread
2023-11-12
我和你一样,只是显示在线,不能publish数据。 兄弟,连接新版的onenet成功了吗?我折腾了7天都不行,希望得到你的帮助。
懿忆_forever
2023-11-30
我看有提到message.id不能为0的,你可以手动改成1试试。或者也叫msg.id
CrazyH
2023-11-30
单步调试下,看看cycle哪里报错
2023-12-02
①②③
onenet组件更新了?
小手凉凉
2023-12-21
后面解决了,onenet应该是更新导致,最新的需要按官网takon工具计算密码,板子才能登进去
915
小手凉凉
mqtt软件包,不支持直接关闭?
kawaii_mqtt 申请内存崩溃
paho_mqtt线程相关疑问
睿擎工业开发平台rk3506常用外设功能评测
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
