closesocket
Closesocket报错
发布于 2023-06-12 18:53:35 浏览:625
自己做了一个板子有三个网卡,ENC28J60、ESP8266、EC20,在使用TCP例程里,closesocket报错 ```c static void tcpclient_entry(void* parameter) { struct hostent *host; struct sockaddr_in server_addr; const char *url="dtu1.build110.com"; int port = 44015; /* 获取需要监听的描述符号最大值 */ //// const char *url="10.32.41.11"; //// int port = 8080; host = gethostbyname(url);/* 分配用于存放接收数据的缓冲 */ STEP1: /* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */ if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1) { /* 创建socket失败 */ sockstatus= 0; rt_kprintf("Socket error\n"); /* 释放接收缓冲 */ return ; } else { rt_kprintf("Socket ok\n"); } /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *)host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* 连接到服务端 */ if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) { sockstatus= 0; /* 连接失败 */ rt_kprintf("Connect fail!\r\n"); // lwip_close(sock); // closesocket(sock); rt_thread_mdelay(1000); goto STEP1; // return; } else { sockstatus =1; rt_kprintf("Connect ok\r\\n"); goto STEP2; /*释放接收缓冲 */ // return RT_ERROR; } STEP2: int ret; fd_set readset; int i, maxfdp1; maxfdp1 = sock + 1; // ret = send(sock, send_data, 13, 0); recv_data = rt_malloc(BUFSZ); if (recv_data == RT_NULL) { rt_kprintf("No memory\n"); return ; } while(1) { /* 清空可读事件描述符列表 */ FD_ZERO(&readset); /* 将需要监听可读事件的描述符加入列表 */ FD_SET(sock, &readset); /* 等待设定的网络描述符有事件发生 */ i = select(maxfdp1, &readset, RT_NULL, RT_NULL, RT_NULL); /* 至少有一个文件描述符有指定事件发生再向后运行 */ if (i != 0) { rt_kprintf("select have to be here %d\r\n",i); /* 查看 sock 描述符上有没有发生可读事件 */ if (FD_ISSET(sock, &readset)) { // rt_kprintf("\nhave get a sock event\r\n"); /* 从sock连接中接收最大BUFSZ - 1字节数据 */ bytes_received = recv(sock, recv_data, BUFSZ - 1, 0); if (bytes_received < 0) { goto STEP1; sockstatus = 0; /* 接收失败,关闭这个连接 */ closesocket(sock); // rt_kprintf("\nreceived error,close the socket.\r\n"); /* 释放接收缓冲 */ rt_free(recv_data); // break; } else if (bytes_received == 0) { goto STEP1; sockstatus= 0; /* 默认 recv 为阻塞模式,此时收到0认为连接出错,关闭这个连接 */ closesocket(sock); rt_kprintf("\nreceived error,close the socket.\r\n"); /* 释放接收缓冲 */ rt_free(recv_data); // break; } else { sockstatus = 1; /* 有接收到数据,把末端清零 */ // recv_data[bytes_received] = '\0'; // for(rt_uint8_t j=0;j
刘灵科
2023-07-19
我跟你一样的问题,最后我把closesocket()改成close就可以了,并且MQTT等用到LWIP的软件都会出问题,所有我把closesocket()里面直接改成调用功能close()
625
最佳听众
W5500 如何实现断开重连?
AT组件连接BC26并使用Webclient软件包GET方式请求失败
Posix Socket采用select机制最多能监听多少个Socket
socket第三个参数无效
添加SAL组件后socket相关函数均提示declared implicitly
mqtt pipe 里面使用到了dfs, socket 是怎么关联起来dfs的?
socket应用方案选择
closesocket函数调用会阻塞
基于AT Socket的测速工具
关于网络编程socket
STM32H723使用ETH使用记录
【GD32F527I-EVAL运行RTThread】使用Agile Button 处理按键输入
th-thread 源码学习-中断系统
【GD32F527I-EVAL运行RTThread】GPIO外设使用
庐山派K230 基于RT-Smart实现FOC云台控制并封装成micropython库与物体自动跟踪系统
QEMU
1532
346
822
180
super_gith
wdfk_prog
killer22
LoongYang
waner
