导入MDK文件有问题
发布于 2023-07-28 09:07:45 浏览:300
 log: ``` !SESSION 2023-07-28 08:37:00.852 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 -clean !ENTRY org.eclipse.ui 2 0 2023-07-28 08:37:14.419 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2023-07-28 08:37:14.419 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.004 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.064 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.064 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.094 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.094 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.094 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.094 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:17.094 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:37:17.204 !MESSAGE ------------>>>>D:\RT-ThreadStudio\workspace/.metadata/Temp/ !ENTRY org.eclipse.ui 4 0 2023-07-28 08:37:27.593 !MESSAGE Unhandled event loop exception !STACK 0 java.lang.NullPointerException at com.genuitec.eclipse.core.util.PlatformUIUtil.getActivePage(PlatformUIUtil.java:68) at com.genuitec.eclipse.startup.workspace.WorkspaceTracker.lambda$1(WorkspaceTracker.java:193) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:168) at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372) at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:474) at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:240) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.disconnectFromWorkspace(ApplicationWorkbenchAdvisor.java:524) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.access$2(ApplicationWorkbenchAdvisor.java:501) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor$2.run(ApplicationWorkbenchAdvisor.java:342) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.postShutdown(ApplicationWorkbenchAdvisor.java:363) at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3044) at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1232) at org.eclipse.ui.internal.Workbench.lambda$4(Workbench.java:1482) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1482) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1455) at org.rtthread.studio.application.ApplicationWorkbenchWindowAdvisor$11.run(ApplicationWorkbenchWindowAdvisor.java:1072) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:223) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !SESSION 2023-07-28 08:37:29.375 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 -clean !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.870 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.890 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.890 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.900 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.900 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.900 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.900 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2023-07-28 08:37:33.900 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:37:33.970 !MESSAGE ------------>>>>D:\RT-ThreadStudio\workspace/.metadata/Temp/ !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:39:41.077 !MESSAGE start pkgs upgrade...... !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:39:45.362 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:39:45.362 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:39:45.362 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:40:11.979 !MESSAGE end pkgs upgrade...... !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.271 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.272 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.274 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.276 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.280 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.283 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.283 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.293 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.293 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.293 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.303 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:55.303 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:57.126 !MESSAGE Send or Reveive Pin Name is Null !ENTRY org.rt-thread.studio.project.ui 4 0 2023-07-28 08:42:57.133 !MESSAGE Send or Reveive Pin Name is Null !SESSION 2023-07-28 08:44:54.920 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Framework arguments: E:\桌面\STM32_UART_0722\Project\RVMDK(uv5)\BH-F407.uvprojx Command-line arguments: -os win32 -ws win32 -arch x86_64 -clean E:\桌面\STM32_UART_0722\Project\RVMDK(uv5)\BH-F407.uvprojx !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.581 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.611 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.621 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.621 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.621 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.621 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.621 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2023-07-28 08:44:59.631 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:44:59.710 !MESSAGE ------------>>>>D:\RT-ThreadStudio\workspace/.metadata/Temp/ !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:45:08.112 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:45:08.112 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2023-07-28 08:45:08.112 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:45:10.937 !MESSAGE start pkgs upgrade...... !ENTRY org.rt-thread.studio.application 4 4 2023-07-28 08:45:15.156 !MESSAGE end pkgs upgrade...... !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE C:\Windows\system32>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 'RTT_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 'ENV_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 'RTT_EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>KCONF_EXEC_PATH=\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.785 !MESSAGE 'KCONF_EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'RTT_CC' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTTS_PLATFORM=STUDIO !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'RTTS_PLATFORM' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>SCONS=\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'SCONS' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PKGS_ROOT=\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'PKGS_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\qemu\qemu32;;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PYTHONPATH=\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'PYTHONPATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\qemu\qemu32;;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32;; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk/studio-mdk-bridge.exe" --import BH-F407 E:\program\STM32_UART_0722\Project\RVMDK锛坲v5锛塡BH-F407.uvprojx !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 'RT-ThreadStudio' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:50:13.795 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.965 !MESSAGE C:\Windows\system32>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.965 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.965 !MESSAGE 'ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.965 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>F_EXEC_PATH=\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'F_EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'CC' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>_PLATFORM=STUDIO !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE '_PLATFORM' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>S=\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'S' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>_ROOT=\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE '_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>\tools\Python27;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>\tools\Python27\Scripts;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 系统找不到指定的路径。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 系统找不到指定的路径。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>\tools\bin;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 系统找不到指定的路径。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 系统找不到指定的路径。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'D:/RT-ThreadStudio/jre/bin/server' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 'D:/RT-ThreadStudio/jre/bin/server' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.975 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>\tools\qemu\qemu32;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 系统找不到指定的路径。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>ONPATH=\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 'ONPATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32;; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 'D:/RT-ThreadStudio/jre/bin/server' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>hreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk/studio-mdk-bridge.exe" --import RVMDK锛坲v5锛?E:\program\STM32_UART_0722\Project\RVMDK锛坲v5锛塡BH-F407.uvprojx !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 'hreadStudio' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:51:01.985 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.038 !MESSAGE C:\Windows\system32>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_ROOT= !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'RTT_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>ENV_ROOT=D:/RT-ThreadStudio/platform/env_released/env !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'ENV_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_EXEC_PATH=D:/RT-ThreadStudio/repo/Extract/ToolChain_Support_Packages/ARM/GNU_Tools_for_ARM_Embedded_Processors/5.4.1/bin !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'RTT_EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>KCONF_EXEC_PATH=\tools\exec !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'KCONF_EXEC_PATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTT_CC=gcc !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'RTT_CC' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RTTS_PLATFORM=STUDIO !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'RTTS_PLATFORM' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>SCONS=\tools\Python27\Scripts !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'SCONS' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PKGS_ROOT=\packages !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 'PKGS_ROOT' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.048 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\qemu\qemu32;;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PYTHONPATH=\tools\Python27; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE 'PYTHONPATH' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>PATH=\tools\qemu\qemu32;;;\tools\bin;\tools\Python27\Scripts;\tools\Python27;\tools\MinGit-2.25.1-32-bit\cmd;D:/RT-ThreadStudio/jre/bin/server;D:/RT-ThreadStudio/jre/bin;D:/RT-ThreadStudio/jre/lib/amd64;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;F:\eLinx2.0_Setup_x86\eLinx2.0\bin\Passkey\bin;F:\MATLAB2018b\runtime\win64;F:\MATLAB2018b\bin;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft DNX\Dnvm\;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\openaccess\bin\win32\opt;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\capture;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pspice;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\specctra\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\fet\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\libutil\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\bin;F:\Cadence17.2\Cadence\Cadence_SPB_17.2-2016\tools\pcb\bin;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;F:\modelsim-win64-10.2-se\win64;C:\Windows\system32;; !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE D:\RT-ThreadStudio\plugins\org.rt-thread.studio.project.gener_1.0.30\mdk>RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/mdk/studio-mdk-bridge.exe" --import STM32_UART_0722 E:\program\STM32_UART_0722\Project\RVMDK锛坲v5锛塡BH-F407.uvprojx !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE 'RT-ThreadStudio' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:52:44.058 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.common.ui 1 0 2023-07-28 08:53:08.951 !MESSAGE C:\Windows\system32>cd /d D:/RT-ThreadStudio/plugins/org.rt-thread.studio.project.gener_1.0.30/md ```
2023-07-28
工程名有中文了吧 studio的文件名和路径不允许有中文等非法字符。
300
ly_0825
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
Wireshark抓包EtherCAT报文
RT-Thread studio的驱动5.1.0报错修改
818
