GUI
链接命令行太长
RT-Thread增加一个emWin GUI组件编译不过,求帮助
发布于 2022-05-25 22:56:21 浏览:712
**RT-Thread增加一个GUI组件编译不过,求帮助**      https://github.com/bomingfeng/RT-Thread_nk-980iot/tree/master/rt-thread/components/GUI
2022-05-26
980 能用 emwin ?你破解过了?
FLBF_5496
2022-05-27
You can make emwin library first and select library to link. There are a Makefile and SConscript example. You can execute 'make' command using env to build your library. For example. ``` TARGET ?= libstddriver_gcc ################################# # GNU ARM Embedded Toolchain ################################# CC=arm-none-eabi-gcc CXX=arm-none-eabi-g++ LD=arm-none-eabi-ld AR=arm-none-eabi-ar AS=arm-none-eabi-as CP=arm-none-eabi-objcopy OD=arm-none-eabi-objdump NM=arm-none-eabi-nm SIZE=arm-none-eabi-size A2L=arm-none-eabi-addr2line ################################# # Working directories ################################# STDDRIVER_DIR = ../ ROOT = ../Library OBJECT_DIR = $(ROOT)/build/gcc BIN_DIR = $(ROOT)/build/gcc ################################# # Source Files ################################# # Search path and source files CSOURCES = $(notdir $(wildcard $(STDDRIVER_DIR)/Source/*.c)) INCLUDE_DIRS = -I$(ROOT) INCLUDE_DIRS += -I$(STDDRIVER_DIR)/Include INCLUDE_DIRS += -I$(DEVICE_DIR) ################################# # Object List ################################# OBJECTS= ################################# # Target Output Files ################################# TARGET_A=$(TARGET).a ################################# # Flags ################################# MCFLAGS= -mcpu=arm926ej-s OPTIMIZE = -O0 -gdwarf-2 DEFS= CFLAGS=-c $(MCFLAGS) $(DEFS) $(OPTIMIZE) $(addprefix -I,$(INCLUDE_DIRS)) -std=c99 CXXFLAGS=-c $(MCFLAGS) $(DEFS) $(OPTIMIZE) $(addprefix -I,$(INCLUDE_DIRS)) -std=c++11 LDSCRIPT= LDFLAGS = ################################# # Build ################################# all: clean $(TARGET_A) $(TARGET_A): @echo -n "Build $@ ..." @cd $(STDDRIVER_DIR)/Source && \ $(CC) -c $(INCLUDE_DIRS) $(CFLAGS) $(CSOURCES) $(AR) cr -o $@ \ $(STDDRIVER_DIR)/Source/*.o $(SIZE) $(TARGET_A) ################################# # Recipes ################################# .PHONY: all clean clean: rm -f $(STDDRIVER_DIR)/Source/*.o $(TARGET_A) ``` SConscript ```python # RT-Thread building script for component Import('rtconfig') from building import * cwd = GetCurrentDir() libs = [] src = Glob('Source/*.c') + Glob('Source/*.cpp') cpppath = [cwd + '/Include'] libpath = [cwd + '/Library'] if not GetDepend('BSP_USE_STDDRIVER_SOURCE'): if rtconfig.CROSS_TOOL == 'keil': if GetOption('target') == 'mdk4' and os.path.isfile('./Library/libstddriver_keil4.lib'): libs += ['libstddriver_keil4'] if GetOption('target') == 'mdk5' and os.path.isfile('./Library/libstddriver_keil.lib'): libs += ['libstddriver_keil'] elif rtconfig.CROSS_TOOL == 'gcc' and os.path.isfile('./Library/libstddriver_gcc.a'): libs += ['libstddriver_gcc'] if not libs: group = DefineGroup('Libraries', src, depend = [''], CPPPATH = cpppath) else: src = [] group = DefineGroup('Libraries', src, depend = [''], CPPPATH = cpppath, LIBS = libs, LIBPATH = libpath) Return('group') ```
boming
2022-05-31
谢谢!不会写SConscript。最后用Linux开发环境ENV就OK了。Windows开发环境ENV还是不好用。
712
boming
[已解决]创建GUI显示线程,出现bus fault错误应该怎么解?
移植RTGUI后,使用RealBoard4088的按键驱动切换画面,出现一次按键,触发两次事件的异常
【已解决】keil中添加rtgui的demo程序的问题
RT-GUI触摸BUG?
【已解决】请问:如何把example目录下rtgui的例子添加到工程中
RT-GUI不需要开辟一块和屏尺寸相同的存储空间记录屏幕上的数据吗?
RT-GUI开发疑问?
RTGUI 发送消息队列失败
gui的汉字字库能只挑出自己使用的汉字编译吗?
建议RTGUI的汉字和BMP等方框绘图增加窗口支持
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
