arm-none-eabi ,cygwin 编译的一个问题
发布于 2012-12-03 11:48:30 浏览:9260
最近在windows7上编译rtt,考虑到用cygwin上的git,svn同步代码方便,希望把scons编译方式也加到cygwin上,遇到了一个 `sh: arm-none-eabi-gcc: command not found` 的问题 具体步骤如下: 1 安装cygwin,选择full install(带有python) 2 安装scons (python setup.py install) 3 安装arm-2012.09-63-arm-none-eabi-i686-mingw32.tar.bz2 (tar -jxvf arm-2012.09-63-arm-none-eabi-i686-mingw32.tar.bz2) 4 将arm-2012.09-63-arm-none-eabi-i686-mingw32解压后的路径export到PATH里 在wh44b0下做scons提示如下 ``` $ scons scons: Reading SConscript files ... /opt/CrossCompile/CodeSourcery/Sourcery_CodeBench_for_ARM_EABI/bin:/cygdrive/c/linux/rt-thread/tool/arm-2012.09/bin/:/home/dillon.min/bin:/cygdrive/c/software/jd-gui-0.3.5.windows:/usr/local/bin:/usr/bin:/cygdrive/c/Program Files (x86)/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_EABI/bin:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Old-Pc-bak/d/share/android-sdk_r10-windows/tools:/cygdrive/c/Old-Pc-bak/d/software/java反编译:/cygdrive/c/Program Files/7-Zip:/cygdrive/c/Python25:/cygdrive/c/Python25/Scripts:/cygdrive/c/Program Files (x86)/Beyond Compare 3:/usr/lib/lapack scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build arm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -D__FLASH_BUILD__ -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/linux/rt-thread/rt-2457-git/build -I/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/common application.c sh: arm-none-eabi-gcc: command not found scons: *** [build/application.o] Error 127 scons: building terminated because of errors. ``` 但是我手动执行 ``` arm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -D__FLASH_BUILD__ -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/linux/rt-thread/rt-2457-git/build -I/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/common application.c ``` 是可以把application.o生成到build下的 可能问题就出在scons里对`arm-none-eabi-gcc`查找上出了问题,在building.py里加了一个 `print os.environ['PATH']` 说明gcc的工具是在路径里的,就比较迷惑了
2012-12-03
scons用的路径是和系统中的PATH变量指向的路径是不一样的,需要在rtconfig.py中指定
bbstr
2012-12-03
`arm-none-eabi-gcc`找不到的问题解决了,但是又遇到一个问题 需要把CYGPATH这个环境变量设置进去,否则`arm-none-eabi-gcc`识别不了`cygwin`下的头文件路径 在bash下,做下列命令就可以了 `export CYGPATH=c:/cygwin/bin/cygpath` 再手动做编译 ``` arm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -D__FLASH_BUILD__ -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/linux/rt-thread/rt-2457-git/build -I/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/common application.c ``` 是可以编译 但是做scons就报错 ``` $ scons scons: Reading SConscript files ... scons: done reading SConscript files. scons: Building targets ... scons: building associated VariantDir targets: build arm-none-eabi-gcc -o build/application.o -c -mcpu=arm720t -D__FLASH_BUILD__ -O2 -Ibuild -I. -I/cygdrive/c/linux/rt-thread/rt-2457-git -I/cygdrive/c/l/cygdrive/c/linux/rt-thread/rt-2457-git/include -I/cygdrive/c/linux/rt-thread/rt-2457-git/libcpu/arm/s3c44b0 -I/cygdrive/c/linux/rt-thread/rt-2457-gi application.c:19:22: fatal error: rtthread.h: No such file or directory compilation terminated. scons: *** [build/application.o] Error 1 scons: building terminated because of errors. ``` 找不到`rtthread.h` 不知道怎么把`CYGPATH`这个环境变量和`scons`里调用`arm-none-eabi-gcc`这个过程糅合到一起?
2012-12-03
没弄明白lz为什么会纠缠在CYGPATH上。 rtconfig.py中,去修改EXEC_PATH路径去。
bbstr
2012-12-03
>没弄明白lz为什么会纠缠在CYGPATH上。 最近在windows7上编译rtt,考虑到用cygwin上的git,svn同步代码方便,希望把scons编译方式也加到cygwin上 主要是这个目的,修改,编译,上传,下载都在cygwin上干
2012-12-03
那么就在rtconfig.h中写入正确的工具链目录。 CYGPATH不知道用来干什么的
grissiom
2012-12-04
注意这是交叉编译,arm-none-eabi-gcc 不应该使用 cygwin下的头文件…… 如果用了,很有可能出错而且很难 debug…… 由此那个 CYGPATH 应该是无关的…… 我自己倒是没有在 cygwin 下用 scons 弄过,貌似 cygwin 自带的 python 版本比较老,用着不舒心……
bbstr
2012-12-10
>注意这是交叉编译,`arm-none-eabi-gcc` 不应该使用 `cygwin`下的头文件…… 如果用了,很有可能出错而且很难 debug…… 我觉得不是`arm-none-eabi-gcc`的问题,我试过在cygwin下单独编译一个c文件,只要设置了CYGPATH环境变量,就可以正常编译,但是到了scons里面,就不行了, 后来debug了一番,也没找到原因为什么scons调用的`arm-none-eabi-gcc`找不到头文件,就放弃了。 我觉得用Makfile方式编译linux应该是没有问题的话,一直没有实验过,回头有空试试看。
2012-12-10
cygpath到底是用来干什么的,难道类似path吗?
bbstr
2012-12-10
>cygpath到底是用来干什么的,难道类似path吗? http://doc.ironwoodlabs.com/arm-arm-none-eabi/html/getting-started/sec-setting-up-environment.htm 看这个里面有解释
2012-12-10
原来Code Sourcery会专门处理这个环境变量。 这个最本质的原因是: scons在进行编译时(例如调用编译器gcc或其它的编译器),它会把环境变量完全的重新创建一个,这个环境变量环境仅包含最最基本的配置。通过这样的方式,编译器将会得到一个最干净的环境变量环境。然后在这个环境下,scons会把脚本中配置的环境应用上去。 所以,你在外面设置的PATH、CYGPATH等等的,传递到编译器时,统统没有了。
9.3k
bbstr
29
scons不支持python3吗?
编译又出现问题
BSP目录下做好一个项目后,怎么把发给别人的包裁剪的小...
为什么重新scons --target=mdk 后,以前在MDK工程里保存的C文
Scons 添加Group,SConscript已经执行,源码却没有添加进工程
scons如何指定输出目录?
新人求助。
想用env 工具自己构建编译环境想用vscode 进行一些简单程序
关于scons脚本问题
使用scons --target=makefile的问题
RT-Thread studio的驱动5.1.0报错修改
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
818
