Cmake
编译
scons 编译的可以正常运行,cmake 的不行
发布于 2022-11-29 23:16:36 浏览:830
[tocm] 我用 scons 编译生成的可以正常运行,但是 scons --target=cmake 后,用 cmake 编译生成的不能正常运行 cmakelists 文件如下 ``` CMAKE_MINIMUM_REQUIRED(VERSION 3.10) SET(CMAKE_SYSTEM_NAME Generic) SET(CMAKE_SYSTEM_PROCESSOR cortex-m7) #SET(CMAKE_VERBOSE_MAKEFILE ON) SET(CMAKE_EXPORT_COMPILE_COMMANDS ON) SET(CMAKE_C_COMPILER "C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/arm-none-eabi-gcc.exe") SET(CMAKE_ASM_COMPILER "C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/arm-none-eabi-gcc.exe") SET(CMAKE_C_FLAGS " -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -ffunction-sections -fdata-sections -Dgcc --sysroot=C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/../arm-none-eabi -O0 -gdwarf-2 -g -std=gnu99") SET(CMAKE_ASM_FLAGS " -c -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -ffunction-sections -fdata-sections -x assembler-with-cpp -Wa,-mimplicit-it=thumb -gdwarf-2") SET(CMAKE_C_COMPILER_WORKS TRUE) SET(CMAKE_CXX_COMPILER "C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/arm-none-eabi-g++.exe") SET(CMAKE_CXX_FLAGS " -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -ffunction-sections -fdata-sections -Dgcc --sysroot=C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/../arm-none-eabi -O0 -gdwarf-2 -g -std=gnu++11") SET(CMAKE_CXX_COMPILER_WORKS TRUE) SET(CMAKE_OBJCOPY "C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/arm-none-eabi-objcopy.exe") SET(CMAKE_SIZE "C:/Users/liuya/MyApp/RT-ThreadStudio/platform/env_released/env/tools/ConEmu/ConEmu/../../../tools/gnu_gcc/arm_gcc/mingw/bin/arm-none-eabi-size.exe") SET(CMAKE_EXE_LINKER_FLAGS " -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -ffunction-sections -fdata-sections -Wl,--gc-sections,-Map=ZKY_CPC.map,-cref,-u,Reset_Handler -T ${CMAKE_SOURCE_DIR}/link_scripts/link.lds") SET(CMAKE_CXX_STANDARD 14) PROJECT(rtthread C CXX ASM) INCLUDE_DIRECTORIES( board board/cubemx/Core/Inc ../../../RTT/github/rt-thread/bsp/stm32/libraries/HAL_Drivers/CMSIS/include ../../../RTT/github/rt-thread/components/libc/compilers/common/include ../../../RTT/github/rt-thread/components/libc/compilers/newlib "C:/Users/liuya/work/LYFCU/src/model/controller", ../../../RTT/github/rt-thread/libcpu/arm/common ../../../RTT/github/rt-thread/libcpu/arm/cortex-m7 ../../../RTT/github/rt-thread/components/drivers/include ../../../RTT/github/rt-thread/components/drivers/spi ../../../RTT/github/rt-thread/components/drivers/spi/sfud/inc "C:/Users/liuya/work/LYFCU/src", ../../../RTT/github/rt-thread/components/dfs/include ../../../RTT/github/rt-thread/components/dfs/filesystems/elmfat ../../../RTT/github/rt-thread/components/dfs/filesystems/ramfs ../../../RTT/github/rt-thread/components/dfs/filesystems/romfs ../../../RTT/github/rt-thread/components/finsh "C:/Users/liuya/work/LYFCU/src/model/fms", hal_drivers hal_drivers/config "C:/Users/liuya/work/LYFCU/src/model/ins", . ../../../RTT/github/rt-thread/include ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Inc ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/CMSIS/Device/ST/STM32H7xx/Include ../../../RTT/github/rt-thread/components/libc/posix/delay ../../../RTT/github/rt-thread/components/libc/posix/io/poll ../../../RTT/github/rt-thread/components/libc/posix/io/stdio ../../../RTT/github/rt-thread/components/libc/posix/ipc ) ADD_DEFINITIONS( -DHAVE_CCONFIG_H -DRT_USING_LIBC -DRT_USING_NEWLIB -DSTM32H743xx -DUSE_HAL_DRIVER -D_POSIX_C_SOURCE=1 -D__RTTHREAD__ ) SET(PROJECT_SOURCES ../../src/lib/airspeed/airspeed.c board/board_test.c board/cubemx/Core/Src/stm32h7xx_hal_msp.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/CMSIS/Device/ST/STM32H7xx/Source/Templates/gcc/startup_stm32h743xx.s board/board_device.c board/board.c board/can_service.c ../../../RTT/github/rt-thread/components/libc/compilers/common/cctype.c ../../../RTT/github/rt-thread/components/libc/compilers/common/cstdio.c ../../../RTT/github/rt-thread/components/libc/compilers/common/cstdlib.c ../../../RTT/github/rt-thread/components/libc/compilers/common/cstring.c ../../../RTT/github/rt-thread/components/libc/compilers/common/ctime.c ../../../RTT/github/rt-thread/components/libc/compilers/common/cwchar.c ../../../RTT/github/rt-thread/components/libc/compilers/newlib/syscalls.c ../../src/model/controller/params_define.c ../../src/model/controller/controller_mc.c ../../src/model/controller/controller_fw.c ../../../RTT/github/rt-thread/libcpu/arm/common/backtrace.c ../../../RTT/github/rt-thread/libcpu/arm/common/div0.c ../../../RTT/github/rt-thread/libcpu/arm/common/showmem.c ../../../RTT/github/rt-thread/libcpu/arm/cortex-m7/context_gcc.S ../../../RTT/github/rt-thread/libcpu/arm/cortex-m7/cpu_cache.c ../../../RTT/github/rt-thread/libcpu/arm/cortex-m7/cpuport.c ../../../RTT/github/rt-thread/components/drivers/can/can.c ../../../RTT/github/rt-thread/components/drivers/hwtimer/hwtimer.c ../../../RTT/github/rt-thread/components/drivers/i2c/i2c-bit-ops.c ../../../RTT/github/rt-thread/components/drivers/i2c/i2c_core.c ../../../RTT/github/rt-thread/components/drivers/i2c/i2c_dev.c ../../../RTT/github/rt-thread/components/drivers/ipc/completion.c ../../../RTT/github/rt-thread/components/drivers/ipc/dataqueue.c ../../../RTT/github/rt-thread/components/drivers/ipc/pipe.c ../../../RTT/github/rt-thread/components/drivers/ipc/ringblk_buf.c ../../../RTT/github/rt-thread/components/drivers/ipc/ringbuffer.c ../../../RTT/github/rt-thread/components/drivers/ipc/waitqueue.c ../../../RTT/github/rt-thread/components/drivers/ipc/workqueue.c ../../../RTT/github/rt-thread/components/drivers/misc/adc.c ../../../RTT/github/rt-thread/components/drivers/misc/pin.c ../../../RTT/github/rt-thread/components/drivers/mtd/mtd_nor.c ../../../RTT/github/rt-thread/components/drivers/rtc/rtc.c ../../../RTT/github/rt-thread/components/drivers/serial/serial_v2.c ../../../RTT/github/rt-thread/components/drivers/spi/qspi_core.c ../../../RTT/github/rt-thread/components/drivers/spi/sfud/src/sfud.c ../../../RTT/github/rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c ../../../RTT/github/rt-thread/components/drivers/spi/spi_core.c ../../../RTT/github/rt-thread/components/drivers/spi/spi_dev.c ../../../RTT/github/rt-thread/components/drivers/spi/spi_flash_sfud.c ../../src/drivers/airspeed/ms4525/drv_ms4525.c ../../src/drivers/mag/vcm5883/drv_vcm5883.c ../../src/startup.c ../../../RTT/github/rt-thread/components/dfs/filesystems/elmfat/dfs_elm.c ../../../RTT/github/rt-thread/components/dfs/filesystems/elmfat/ff.c ../../../RTT/github/rt-thread/components/dfs/filesystems/elmfat/ffunicode.c ../../../RTT/github/rt-thread/components/dfs/filesystems/ramfs/dfs_ramfs.c ../../../RTT/github/rt-thread/components/dfs/filesystems/romfs/dfs_romfs.c ../../../RTT/github/rt-thread/components/dfs/filesystems/romfs/romfs.c ../../../RTT/github/rt-thread/components/dfs/src/dfs.c ../../../RTT/github/rt-thread/components/dfs/src/dfs_file.c ../../../RTT/github/rt-thread/components/dfs/src/dfs_fs.c ../../../RTT/github/rt-thread/components/dfs/src/dfs_posix.c ../../../RTT/github/rt-thread/components/finsh/shell.c ../../../RTT/github/rt-thread/components/finsh/msh.c ../../../RTT/github/rt-thread/components/finsh/msh_parse.c ../../../RTT/github/rt-thread/components/finsh/cmd.c ../../../RTT/github/rt-thread/components/finsh/msh_file.c ../../src/hal/airspeed/airspeed.c ../../src/hal/serialX/serialX.c ../../src/hal/mag/mag.c ../../src/hal/hrt/hrt.c ../../src/hal/gps/gps.c ../../src/hal/gyro/gyro.c ../../src/hal/actuator/actuator.c ../../src/hal/serialX/serial_rs485.c hal_drivers/drv_gpio.c hal_drivers/drv_mpu.c hal_drivers/drv_uartX.c hal_drivers/drv_qspi.c hal_drivers/drv_spi.c hal_drivers/drv_adc.c hal_drivers/drv_soft_i2c.c hal_drivers/drv_fdcan.c hal_drivers/drv_hrt.c hal_drivers/drv_qspi_flash.c hal_drivers/drv_rtc.c hal_drivers/drv_common.c hal_drivers/drv_hwtimer.c ../../../RTT/github/rt-thread/src/clock.c ../../../RTT/github/rt-thread/src/components.c ../../../RTT/github/rt-thread/src/device.c ../../../RTT/github/rt-thread/src/idle.c ../../../RTT/github/rt-thread/src/ipc.c ../../../RTT/github/rt-thread/src/irq.c ../../../RTT/github/rt-thread/src/kservice.c ../../../RTT/github/rt-thread/src/mem.c ../../../RTT/github/rt-thread/src/memheap.c ../../../RTT/github/rt-thread/src/mempool.c ../../../RTT/github/rt-thread/src/object.c ../../../RTT/github/rt-thread/src/scheduler.c ../../../RTT/github/rt-thread/src/thread.c ../../../RTT/github/rt-thread/src/timer.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_adc.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_rcc.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_tim.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_spi.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_pwr.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_tim_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_rcc_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_sram.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_rtc.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_cortex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_i2c_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_cryp_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_dma_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_rtc_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_i2c.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_fdcan.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_cryp.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_usart.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_lptim.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_crc_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_gpio.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_adc_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_uart_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_nor.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_mdma.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_dma.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_uart.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_comp.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_rng.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_crc.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_cec.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_qspi.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_pwr_ex.c ../../../RTT/github/rt-thread/bsp/stm32/libraries/STM32H7xx_HAL/CMSIS/Device/ST/STM32H7xx/Source/Templates/system_stm32h7xx.c ../../src/module/sensor/sensor_baro.c ../../src/module/file_manager/file_ex_ops.c ../../src/module/workqueue/work_queue.c ../../src/module/ipc/uMCN.c ../../src/module/math/light_matrix.c ../../src/module/file_manager/yxml.c ../../src/module/workqueue/workqueue_manager.c ../../src/module/system/cpusage.c ../../src/module/system/systime.c ../../src/module/math/axis_angle.c ../../src/module/sensor/sensor_mag.c ../../src/module/file_manager/file_manager.c ../../src/module/sensor/sensor_airspeed.c ../../src/module/sensor/sensor_gps.c ../../src/module/math/quaternion.c ../../src/module/math/matrix.c ../../src/module/param/param.c ../../src/module/file_manager/rt_vsprintf.c ../../src/module/math/euler.c ../../src/module/sensor/sensor_imu.c ../../src/module/sensor/sensor_hub.c ../../src/module/system/sys_param.c ../../../RTT/github/rt-thread/components/libc/posix/delay/delay.c ../../src/protocol/vklink/vklink.c ) LINK_DIRECTORIES( ) LINK_LIBRARIES( c m ) ADD_EXECUTABLE(${CMAKE_PROJECT_NAME}.elf ${PROJECT_SOURCES}) ADD_CUSTOM_COMMAND(TARGET ${CMAKE_PROJECT_NAME}.elf POST_BUILD COMMAND ${CMAKE_OBJCOPY} -O binary ${CMAKE_PROJECT_NAME}.elf ${CMAKE_PROJECT_NAME}.bin COMMAND ${CMAKE_SIZE} ${CMAKE_PROJECT_NAME}.elf) ``` rtconfig.py 文件如下 ``` import os import sys import rtconfig # FMU path FMU_ROOT = os.path.normpath(os.getcwd() + '/../..') # RTOS path RTT_ROOT = 'C:/Users/liuya/work/RTT/github/rt-thread' sys.path = sys.path + [os.path.join(RTT_ROOT, 'tools')] try: from building import * except: print('Cannot found RT-Thread root directory, please check RTT_ROOT') print(RTT_ROOT) exit(-1) TARGET = 'build/ZKY_CPC.' + rtconfig.TARGET_EXT env = Environment(tools=['mingw'], AS=rtconfig.AS, ASFLAGS=rtconfig.AFLAGS, CC=rtconfig.CC, CFLAGS=rtconfig.CFLAGS, AR=rtconfig.AR, ARFLAGS='-rc', CXX=rtconfig.CXX, CXXFLAGS=rtconfig.CXXFLAGS, LINK=rtconfig.LINK, LINKFLAGS=rtconfig.LFLAGS) # Add sys execute PATH to env PATH env.PrependENVPath('PATH', os.getenv('PATH')) env.PrependENVPath('PATH', rtconfig.EXEC_PATH) if rtconfig.PLATFORM == 'iar': env.Replace( CCCOM=['$CC $CCFLAGS $CPPFLAGS $_CPPDEFFLAGS $_CPPINCFLAGS -o $TARGET $SOURCES']) env.Replace(ARFLAGS=['']) env.Replace( LINKCOM=['$LINK $SOURCES $LINKFLAGS -o $TARGET --map project.map']) Export('RTT_ROOT') Export('FMU_ROOT') Export('rtconfig') # prepare building environment objs = PrepareBuilding(env, RTT_ROOT, has_libcpu=False) cwd = str(Dir('#')) list = os.listdir(FMU_ROOT) vdir = 'build/fmu' for d in list: path = os.path.join(FMU_ROOT, d) if os.path.isfile(os.path.join(path, 'SConscript')): objs.extend(SConscript(os.path.join(path, 'SConscript'), variant_dir=vdir + '/' + d, duplicate=0)) # print env.get('CPPPATH', ['']) env.Tool('compilation_db') env.CompilationDatabase() # make a building DoBuilding(TARGET, objs) ``` 对比生成的二进制文件,确实有一点字节差异,请教一下是哪出了问题
2022-11-30
stm32h750-artpi,在linux下用scons生成cmake的文件,然后用cmake & make是可以的。
830
myLLgf
scons不支持python3吗?
编译又出现问题
BSP目录下做好一个项目后,怎么把发给别人的包裁剪的小...
为什么重新scons --target=mdk 后,以前在MDK工程里保存的C文
Scons 添加Group,SConscript已经执行,源码却没有添加进工程
scons如何指定输出目录?
新人求助。
想用env 工具自己构建编译环境想用vscode 进行一些简单程序
关于scons脚本问题
使用scons --target=makefile的问题
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
