大佬,为什么我在studio创建的gd32303项目,它rt_device_read读不了,而且uart_rx_ind这个也没进去,用的是官方代码
发布于 2024-10-08 16:52:34 浏览:441
```c #include
#define SAMPLE_UART_NAME "uart3" #define DATA_CMD_END '!' /* 结束位设置为 \r,即回车符 */ #define ONE_DATA_MAXLEN 20 /* 不定长数据的最大长度 */ /* 用于接收消息的信号量 */ static struct rt_semaphore rx_sem; static rt_device_t serial; /* 接收数据回调函数 */ static rt_err_t uart_rx_ind(rt_device_t dev, rt_size_t size) { //rt_kprintf("44444"); /* 串口接收到数据后产生中断,调用此回调函数,然后发送接收信号量 */ if (size > 0) { rt_kprintf("44444"); rt_sem_release(&rx_sem); } return RT_EOK; } static char uart_sample_get_char(void) { char ch; rt_kprintf("22222222"); while (rt_device_read(serial, 0, &ch, 1) == 0) { rt_kprintf("333333"); rt_sem_control(&rx_sem, RT_IPC_CMD_RESET, RT_NULL); rt_sem_take(&rx_sem, RT_WAITING_FOREVER); } return ch; } /* 数据解析线程 */ static void data_parsing(void) { rt_kprintf("1111111"); char ch; char data[ONE_DATA_MAXLEN]; static char i = 0; while (1) { ch = uart_sample_get_char(); rt_device_write(serial, 0, &ch, 1); if(ch == DATA_CMD_END) { data[i++] = '\0'; rt_kprintf("data=%s\n",data); i = 0; continue; } i = (i >= ONE_DATA_MAXLEN-1) ? ONE_DATA_MAXLEN-1 : i; data[i++] = ch; } } struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; int main() { char ch; rt_err_t ret = RT_EOK; char str[] = "hello RT-Thread!\n"; /* 查找系统中的串口设备 */ serial = rt_device_find(SAMPLE_UART_NAME); if (!serial) { rt_kprintf("find failed!"); return RT_ERROR; } rt_device_control(serial, RT_DEVICE_CTRL_CONFIG, (void*)&config); /* 初始化信号量 */ rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及轮询发送模式打开串口设备 */ rt_device_open(serial, RT_DEVICE_FLAG_INT_RX|RT_DEVICE_OFLAG_RDWR); /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial, uart_rx_ind); /* 发送字符串 */ rt_device_write(serial, 0, str, (sizeof(str) )); /* 创建 serial 线程 */ rt_thread_t thread = rt_thread_create("serial", (void (*)(void *parameter))data_parsing, RT_NULL, 1024, 25, 10); // 创建成功则启动线程 if (thread != RT_NULL) { rt_thread_startup(thread); } else { ret = RT_ERROR; } return ret; } ```
zyy_
2024-10-08
2024-10-08
学以致用
uart3 需要先正确初始化好(引脚、串口配置),并注册为 "uart3" 设备
441
zyy_
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
睿擎工业开发平台--I2C1驱动AMP2301读取温湿度
睿擎平台RK3506使用总结
睿擎工业开发平台---文件系统测试使用
Ryan_CW
纯白酱
530china
rv666
Lipiah
