There is a tutorial in RT-Thread page talking about some eclipse plugins to make easy the RTT build, but when I try to donwload it fail.
http://www.rt-thread.org/dokuwiki/doku. … 3%E8%AF%95
This topic show how to configure and the plugin
This is the repositore that I’ve found
https://github.com/RT-Thread/eclipse
Is the plugins in RTT page available? How to install the plugins in the GitHub repository?
Thanks.
The repo is the source code. You need compile it to jar in Eclipse, and then place it under plugins directory.
Actually, the Eclipse is so heavy and slowly.
