嵌入式技术综合讨论
RT-Thread 自带 IAR 工程不能编译
发布于 2013-08-10 01:28:19 浏览:5833
我想在STM32F103RCT6上学习RT-Thread,可是系统自带的IAR工程我编译总是出错误,谁能告诉我是什么原因呢,或者能不能给我一个编译通过的IAR的工程,非常感谢.我的IAR版本是5.50.错误提示如下: ------------------------------------------------分隔线------------------------------------------------ ``` Changed settings forces a full rebuild... Building configuration: project - Debug Updating build tree... 62 file(s) deleted. Updating build tree... application.c Fatal Error[Pe005]: could not open source file "board.h" G:E diskRT-Thread_1.1.1spstm32f10xapplication.c 21 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler backtrace.c Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1libcpuarmcommonacktrace.c 15 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler board.c Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1spstm32f10xoard.c 15 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler clock.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcclock.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1srcclock.c 21 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler cmd.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshcmd.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1componentsfinshcmd.c 33 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler context_iar.S cpuport.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1libcpuarmcortex-m3cpuport.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1libcpuarmcortex-m3cpuport.c 19 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler device.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcdevice.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1srcdevice.c 19 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler div0.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1libcpuarmcommondiv0.c 1 finsh_compiler.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_compiler.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_compiler.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_error.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_error.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_error.h 17 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_heap.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_heap.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_heap.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_init.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_init.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_init.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_node.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_node.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_node.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_ops.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_ops.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_vm.h 17 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_parser.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_parser.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_parser.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_token.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_token.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_token.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_var.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_var.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_var.c 16 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler finsh_vm.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshfinsh_vm.c 1 Fatal Error[Pe005]: could not open source file "finsh.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh_vm.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler idle.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcidle.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1srcidle.c 17 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler ipc.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcipc.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1srcipc.c 40 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler irq.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcirq.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1srcirq.c 16 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler kservice.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srckservice.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1srckservice.c 23 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler led.c Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1spstm32f10xled.c 14 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler mem.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcmem.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1srcmem.c 52 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler mempool.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcmempool.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1srcmempool.c 23 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler misc.c Fatal Error[Pe005]: could not open source file "misc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcmisc.c 24 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler object.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcobject.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1srcobject.c 20 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler rtc.c Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1spstm32f10x tc.c 16 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler scheduler.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1srcscheduler.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1srcscheduler.c 29 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler serial.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1spstm32f10xserial.c 1 Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1spstm32f10xserial.h 18 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler shell.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshshell.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1componentsfinshshell.c 23 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler showmem.c Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1libcpuarmcommonshowmem.c 15 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler startup.c Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1spstm32f10xstartup.c 15 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler startup_stm32f10x_hd.s stm32f10x_adc.c Fatal Error[Pe005]: could not open source file "stm32f10x_adc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_adc.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_bkp.c Fatal Error[Pe005]: could not open source file "stm32f10x_bkp.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_bkp.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_can.c Fatal Error[Pe005]: could not open source file "stm32f10x_can.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_can.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_cec.c Fatal Error[Pe005]: could not open source file "stm32f10x_cec.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_cec.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_crc.c Fatal Error[Pe005]: could not open source file "stm32f10x_crc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_crc.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_dac.c Fatal Error[Pe005]: could not open source file "stm32f10x_dac.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_dac.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_dbgmcu.c Fatal Error[Pe005]: could not open source file "stm32f10x_dbgmcu.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_dbgmcu.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_dma.c Fatal Error[Pe005]: could not open source file "stm32f10x_dma.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_dma.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_exti.c Fatal Error[Pe005]: could not open source file "stm32f10x_exti.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_exti.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_flash.c Fatal Error[Pe005]: could not open source file "stm32f10x_flash.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_flash.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_fsmc.c Fatal Error[Pe005]: could not open source file "stm32f10x_fsmc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_fsmc.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_gpio.c Fatal Error[Pe005]: could not open source file "stm32f10x_gpio.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_gpio.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_i2c.c Fatal Error[Pe005]: could not open source file "stm32f10x_i2c.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_i2c.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_it.c Fatal Error[Pe005]: could not open source file "stm32f10x.h" G:E diskRT-Thread_1.1.1spstm32f10xstm32f10x_it.h 30 searched: "G:E diskRT-Thread_1.1.1spstm32f10x" searched: "G:E diskRT-Thread_1.1.1spstm32f10x" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_iwdg.c Fatal Error[Pe005]: could not open source file "stm32f10x_iwdg.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_iwdg.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_pwr.c Fatal Error[Pe005]: could not open source file "stm32f10x_pwr.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_pwr.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_rcc.c Fatal Error[Pe005]: could not open source file "stm32f10x_rcc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_rcc.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_rtc.c Fatal Error[Pe005]: could not open source file "stm32f10x_rtc.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_rtc.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_sdio.c Fatal Error[Pe005]: could not open source file "stm32f10x_sdio.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_sdio.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_spi.c Fatal Error[Pe005]: could not open source file "stm32f10x_spi.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_spi.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_tim.c Fatal Error[Pe005]: could not open source file "stm32f10x_tim.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_tim.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_usart.c Fatal Error[Pe005]: could not open source file "stm32f10x_usart.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_usart.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler stm32f10x_wwdg.c Fatal Error[Pe005]: could not open source file "stm32f10x_wwdg.h" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrcstm32f10x_wwdg.c 23 searched: "G:E diskRT-Thread_1.1.1spstm32f10xLibrariesSTM32F10x_StdPeriph_Driversrc" searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler symbol.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1componentsfinshsymbol.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1componentsfinshfinsh.h 17 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler system_stm32f10x.c Fatal Error[Pe035]: #error directive: "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)" G:E diskRT-Thread_1.1.1spstm32f10xLibrariesCMSISCM3DeviceSupportSTSTM32F10xstm32f10x.h 96 Error while running C/C++ Compiler thread.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1src hread.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1src hread.c 30 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler timer.c Warning[Pa050]: non-native end of line sequence detected (this diagnostic is only issued once) G:E diskRT-Thread_1.1.1src imer.c 1 Fatal Error[Pe005]: could not open source file "rtthread.h" G:E diskRT-Thread_1.1.1src imer.c 23 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler usart.c Fatal Error[Pe005]: could not open source file "rthw.h" G:E diskRT-Thread_1.1.1spstm32f10xusart.h 18 searched: "D:Program FilesIAR SystemsEmbedded Workbench 5.4 EvaluationarmINC" Error while running C/C++ Compiler Total number of errors: 60 Total number of warnings: 28```
hexboot
2013-09-02
文件缺失,你得自己找文件....
5.8k
yinyanqing
开新板块了! 迅速占领第一帖!
有想玩点阵做电子钟的没?手上有屏
LED点阵屏硬件保护研究笔记
USB相关、Android、Arduino
Arduino即将发布ARM平台新产品
关于开关电源的同步整流技术
rt_thread_wizard使用教程
[转]开源如何盈利
FM3系列MCU的IO操作笔记。
转一个xoolhaha 的寻一起开发的帖子
【基于HPM6750+RW007的网页服务器】---SD卡文件系统
有关RT_thread studio使用WDT的一点经验
ART-PI2 上手记录(一)
【基于HPM6750+RW007的网页服务器】---rw007软件包添加
【FRDM-MCXA156 评测】RW007
1521
814
554
