使用设备驱动uart数据丢帧
发布于 2025-04-03 21:41:06 浏览:194
我使用官方提供的GD32H759bsp移植到GD32H757Z单片机上时发现在finsh命令行输入上下左右键时会卡死,初步调试发现是串口发生了ORE溢出中断,而驱动未对ORE溢出中断清除标志导致卡死在中断里,中断处理代码如下 ```C static void GD32_UART_IRQHandler(struct rt_serial_device *serial) { struct gd32_uart *uart = (struct gd32_uart *) serial->parent.user_data; RT_ASSERT(uart != RT_NULL); /* UART in mode Receiver -------------------------------------------------*/ if ((usart_interrupt_flag_get(uart->uart_periph, USART_INT_FLAG_RBNE) != RESET) && (usart_flag_get(uart->uart_periph, USART_FLAG_RBNE) != RESET)) { rt_hw_serial_isr(serial, RT_SERIAL_EVENT_RX_IND); /* Clear RXNE interrupt flag */ usart_flag_clear(uart->uart_periph, USART_FLAG_RBNE); } } ``` 于是我在中断处理里加入清除ORE标志 ```c else if((usart_flag_get(uart->uart_periph, USART_FLAG_ORERR) != RESET)) { usart_flag_clear(uart->uart_periph, USART_FLAG_ORERR); } ``` 这时发现finsh不会卡死,但是出现了新的问题:使用上下键时会出现字母AB  我研究了一下方向键是会下发多个字节,最后一个字节就是字母的ASCII码,如下是上下键下发的数据  这么看来应该是串口数据丢帧导致的,我对串口中断进行修改,打开空闲中断,屏蔽中断处理中rt_hw_serial_isr函数,并定义一个数据接收数据,在空闲中断处理中把接收到数据发送出去 ```c static void GD32_UART_IRQHandler(struct rt_serial_device *serial) { struct gd32_uart *uart = (struct gd32_uart *) serial->parent.user_data; RT_ASSERT(uart != RT_NULL); // /* UART in mode Receiver -------------------------------------------------*/ if ((usart_interrupt_flag_get(uart->uart_periph, USART_INT_FLAG_RBNE) != RESET) && (usart_flag_get(uart->uart_periph, USART_FLAG_RBNE) != RESET)) { //rt_hw_serial_isr(serial, RT_SERIAL_EVENT_RX_IND); uart_rec_buff[count++] = (uint8_t)(usart_data_receive(uart->uart_periph)&0xff); /* Clear RXNE interrupt flag */ usart_flag_clear(uart->uart_periph, USART_FLAG_RBNE); } else if((usart_flag_get(uart->uart_periph, USART_FLAG_ORERR) != RESET)) { usart_flag_clear(uart->uart_periph, USART_FLAG_ORERR); } else if((usart_flag_get(uart->uart_periph, USART_FLAG_IDLE) != RESET)) { for(uint8_t i = 0;i
uart_periph, uart_rec_buff[i]); while((usart_flag_get(uart->uart_periph, USART_FLAG_TBE) == RESET)); uart_rec_buff[i] = 0; } count = 0; usart_flag_clear(uart->uart_periph, USART_FLAG_IDLE); } } ``` 果然接收的数据会丢失一点,如下图  结合溢出中断我觉得可能是串口中断处理的时间太长导致的,为了验证猜想,将波特率从115200改为9600,这时发送上来的数据是完整的,很奇怪,中断中的代码很少,600M的主频不应该会出现这个问题。我又在裸机上试了一下,115200的波特率下并没有出现这个问题。之后我又将设备驱动接口几个函数中的代码注释,在rt_hw_usart_init手动初始化串口 ```c rcu_periph_clock_enable(RCU_GPIOA); rcu_periph_clock_enable(RCU_USART0); gpio_af_set(GPIOA, GPIO_AF_7,GPIO_PIN_9); gpio_af_set(GPIOA, GPIO_AF_7,GPIO_PIN_10); gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9); gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_9); gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10); gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_100_220MHZ, GPIO_PIN_10); usart_baudrate_set(USART0, 115200U); usart_word_length_set(USART0, USART_WL_8BIT); usart_stop_bit_set(USART0, USART_STB_1BIT); usart_parity_config(USART0, USART_PM_NONE); usart_receive_config(USART0, USART_RECEIVE_ENABLE); usart_transmit_config(USART0, USART_TRANSMIT_ENABLE); usart_interrupt_enable(USART0, USART_INT_RBNE); usart_interrupt_enable(USART0, USART_INT_IDLE); nvic_irq_enable(USART0_IRQn, 0, 0); usart_enable(USART0); ``` 问题依旧。 所以有没有好心的大佬知道什么原因啊
194
天上飘着棉花糖
RT-THREAD shell无反应呢?
板子上只有485接口,能把FINSH改造成485的么?
finsh最大字符问题
finsh命令个数是不是有限制啊
finsh支持转义字符吗
不用finsh如何知道堆栈使用量
强烈建议 RT-Thread下finsh原理深入分析
finsh输入命令全部返回null node
睿擎工业开发平台rk3506常用外设功能评测
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
