nuc980
NUC980IOT开发板rt工程创建文件
发布于 2022-03-04 10:18:43 浏览:1119
[tocm] 把程序NUC980iot开发板下入SPI NAND中运行,运行后在SPI NAND的文件系统挂载点`/mnt/filesystem`下采用mkdir命令创建目录后,系统重启出现死机程序不能运行现象; ``` NUC980 IBR 20180813 Boot from SPI-NAND DDR-OK finish SPI dow▒load SPL load main U-Boot from SPI NAND Flash! (Jan 19 2021 19:07:08) U-Boot 2016.11-g95c6ee8 (Jan 19 2021 - 19:07:08 +0800) CPU: NUC980 Board: NUC980 DRAM: 64 MiB NAND: NAND Flash not found ! NUC980 NAND CONTROLLER IS NOT SUPPORT THE PAGE SIZE. (0, 0) 0 MiB SF: Detected W25N01GV with page size 2 KiB, erase size 128 KiB, total 128 MiB ## Baudrate 11520 bps not supported himport_r: can't insert "baudrate=11520" into hash table In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x200000, size 0x100000 1048576 bytes read: OK ## Starting application at 0x00000000 ... \ | / - RT - Thread Operating System / | \ 4.0.4 build Mar 3 2022 17:45:31 2006 - 2021 Copyright by rt-thread team lwIP-2.0.2 initialized! [I/I2C] I2C bus [i2c0] registered [I/I2C] I2C bus [i2c2] registered [I/spinand_flash] Found: [00EFAA21] Winbond 128MB: 2048+64@64@1024. [I/spinand_flash] Enabled BUF, HWECC. Unprotected. [I/sal.skt] Socket Abstraction Layer initialize success. [I/utest] utest is initialize success. [I/utest] total utest testcase num: (0) os : system memory alloc 320 bytes flsh: UFFS consume spare data size 49 os : system memory alloc 83520 bytes os : system memory alloc 52400 bytes os : system memory alloc 16000 bytes [PDMA-W] cb_len error cb_len error Execption: r00:0xe56296cb r01:0x0011c380 r02:0x00000004 r03:0x00000020 r04:0x00d27d80 r05:0x00c0ba00 r06:0x00d27d50 r07:0x00d27d60 r08:0x00086d98 r09:0x00000000 r10:0x00d27ccc fp :0x001017dc ip :0x00d27d83 sp :0x0011a738 lr :0x00025490 pc :0x00025490 cpsr:0xa0000013 data abort thread - ▒▒▒▒▒▒▒▒@ stack: thread pri status sp stack size max used left tick error ---------------- --- ------- ---------- ---------- ------ ---------- --- hotplug 30 suspend 0x000000a0 0x00000400 15% 0x0000000a 000 ntp-sync 30 running 0x00000070 0x000005dc 23% 0x00000014 000 usbh_drv 8 suspend 0x00000070 0x00000800 05% 0x00000014 000 usbh 8 suspend 0x000000b4 0x00001000 04% 0x00000014 000 vcom 16 suspend 0x00000118 0x00000800 13% 0x00000014 000 usbd 8 suspend 0x000000bc 0x00001000 07% 0x0000000e 000 tcpip 10 suspend 0x000000d4 0x00001000 05% 0x00000014 000 etx 12 suspend 0x000000a4 0x00000400 16% 0x00000010 000 erx 12 suspend 0x000000a0 0x00000400 15% 0x00000010 000 sys_work 23 suspend 0x00000060 0x00000800 04% 0x0000000a 000 alarmsvc 10 suspend 0x000000a4 0x00000800 08% 0x00000005 000 tidle0 31 ready 0x00000044 0x00000800 04% 0x0000001e 000 main 10 suspend 0x00000410 0x00000800 56% 0x00000007 000 shutdown... machine_shutdown... ```
andychen
2022-03-04
波特率:115200啊 你是11520
FLBF_5496
2022-03-09
Hi, Sorry, I can't reproduce the issue on my side. Checkpoint: (1) Did erase all blocks on SPI NAND flash using NuWriter utility before accessing it in RTT system?  (2) For 11520 issue, I guess it is u-boot parsing issue. Could you replace latest env.txt to avoid?
1.1k
lifumin_2011
ENV下的NUC980能移动到RT STUDIO上吗?
NUC980 生成 UFFS 文件系统镜像
怎样生成基于NUC980、rt_thread系统的板级支持包(MDK开发环境)
这个接口在哪个文件里面的。
NUC980之EMAC功能模块的硬件介绍
nuc980DDR和MDK的IRAM是怎样的映射关系
ncu977 跑rtthread 操作io没有反应
NUC980开发板生成Keil工程找不到Device和编译出错
rtthread studio创建NUC980工程无法设置RTC日期和时间
NUC980烧录RT-Thread bsp后卡死,程序不能运行现象
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
1527
344
822
