创建项目失败
新人求助----创建项目失败
发布于 2022-11-10 15:56:36 浏览:412
``` !SESSION 2022-11-10 15:32:58.794 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN Command-line arguments: -os win32 -ws win32 -arch x86_64 -clean !ENTRY org.eclipse.ui 2 0 2022-11-10 15:33:06.954 !MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point. !SUBENTRY 1 org.eclipse.ui 2 0 2022-11-10 15:33:06.954 !MESSAGE Cannot bind to an undefined command: plug-in='com.genuitec.eclipse.theming.ui', id='com.genuitec.myeclipse.help.darktheme.commandid' !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.837 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.838 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.843 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.844 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.845 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.847 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.848 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.850 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.851 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.997 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:11.998 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:12.034 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:12.035 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:12.036 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:12.038 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2022-11-10 15:33:12.039 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.rt-thread.studio.application 4 4 2022-11-10 15:33:54.000 !MESSAGE [ApplicationWorkbenchWindowAdvisor]getSystemInfo:null !ENTRY org.eclipse.egit.ui 2 0 2022-11-10 15:33:54.826 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\sm116'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:33:55.843 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:33:55.845 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:33:55.846 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.ui 4 0 2022-11-10 15:34:51.676 !MESSAGE Unhandled event loop exception !STACK 0 org.eclipse.swt.SWTException: Widget is disposed at org.eclipse.swt.SWT.error(SWT.java:4595) at org.eclipse.swt.SWT.error(SWT.java:4510) at org.eclipse.swt.SWT.error(SWT.java:4481) at org.eclipse.swt.widgets.Widget.error(Widget.java:451) at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:350) at org.eclipse.swt.widgets.Label.setImage(Label.java:353) at org.eclipse.jface.dialogs.TitleAreaDialog.setTitleImage(TitleAreaDialog.java:677) at org.eclipse.jface.wizard.WizardDialog.hardClose(WizardDialog.java:837) at org.eclipse.jface.wizard.WizardDialog.close(WizardDialog.java:462) at org.rtthread.studio.project.ui.wizard.BoardComposite$2.handleEvent(BoardComposite.java:415) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1060) at org.eclipse.swt.widgets.Combo.wmCommandChild(Combo.java:3202) at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:4917) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4771) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770) at org.eclipse.swt.internal.win32.OS.CallWindowProc(Native Method) at org.eclipse.swt.widgets.Combo.callWindowProc(Combo.java:478) at org.eclipse.swt.widgets.Control.windowProc(Control.java:4867) at org.eclipse.swt.widgets.Combo.windowProc(Combo.java:2807) at org.eclipse.swt.widgets.Display.windowProc(Display.java:4778) at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3545) at org.eclipse.jface.window.Window.runEventLoop(Window.java:822) at org.eclipse.jface.window.Window.open(Window.java:798) at org.rtthread.studio.application.intro.action.NewRTThreadProjectIntroAction$1.run(NewRTThreadProjectIntroAction.java:30) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:222) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !SESSION 2022-11-10 15:34:52.571 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN !ENTRY org.eclipse.osgi 4 0 2022-11-10 15:34:53.617 !MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: D:\RT-ThreadStudio\configuration\org.eclipse.osgi !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.470 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.472 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.473 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.474 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.474 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.476 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.478 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.479 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.480 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.551 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.553 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.563 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.564 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.565 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.567 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2022-11-10 15:35:05.568 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.eclipse.egit.ui 2 0 2022-11-10 15:35:11.024 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\sm116'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:35:18.192 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:35:18.194 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:35:18.195 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.project.ui 4 0 2022-11-10 15:35:42.198 !MESSAGE !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:35:42.211 !MESSAGE 'b#et' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:35:42.212 !MESSAGE D:\RT-ThreadStudio>b#et !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:35:42.212 !MESSAGE 或批处理文件。 !SESSION 2022-11-10 15:51:27.357 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN !ENTRY org.eclipse.osgi 4 0 2022-11-10 15:51:28.186 !MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: D:\RT-ThreadStudio\configuration\org.eclipse.osgi !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.094 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.096 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.098 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.099 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.101 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.103 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.104 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.106 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.108 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.188 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.191 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.210 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.212 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.213 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.215 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2022-11-10 15:51:43.216 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.eclipse.egit.ui 2 0 2022-11-10 15:51:48.783 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\sm116'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:51:53.428 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:51:53.430 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:51:53.431 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:53:58.973 !MESSAGE D:\RT-ThreadStudio>b#et !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:53:58.977 !MESSAGE 'b#et' 不是内部或外部命令,也不是可运行的程序 !ENTRY org.rt-thread.studio.common.ui 1 0 2022-11-10 15:53:58.978 !MESSAGE 或批处理文件。 !ENTRY org.rt-thread.studio.project.ui 4 0 2022-11-10 15:53:58.982 !MESSAGE !ENTRY org.eclipse.ui 4 0 2022-11-10 15:54:36.181 !MESSAGE Unhandled event loop exception !STACK 0 java.lang.NullPointerException at org.rtthread.studio.application.theme.ThemeToLightAction$1.run(ThemeToLightAction.java:59) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.jface.operation.ModalContext$ModalContextThread.block(ModalContext.java:168) at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372) at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:474) at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:240) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.disconnectFromWorkspace(ApplicationWorkbenchAdvisor.java:524) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.access$2(ApplicationWorkbenchAdvisor.java:501) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor$2.run(ApplicationWorkbenchAdvisor.java:342) at org.rtthread.studio.application.ApplicationWorkbenchAdvisor.postShutdown(ApplicationWorkbenchAdvisor.java:363) at org.eclipse.ui.internal.Workbench.shutdown(Workbench.java:3044) at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1232) at org.eclipse.ui.internal.Workbench.lambda$4(Workbench.java:1482) at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1482) at org.eclipse.ui.internal.Workbench.close(Workbench.java:1455) at org.rtthread.studio.application.theme.ThemeToLightAction$1.run(ThemeToLightAction.java:72) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:642) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:569) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151) at org.rtthread.studio.application.Application.start(Application.java:223) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595) at org.eclipse.equinox.launcher.Main.run(Main.java:1501) !SESSION 2022-11-10 15:54:37.340 ----------------------------------------------- eclipse.buildId=unknown java.version=1.8.0_144 java.vendor=Oracle Corporation BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN !ENTRY org.eclipse.osgi 4 0 2022-11-10 15:54:38.224 !MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: D:\RT-ThreadStudio\configuration\org.eclipse.osgi !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.639 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.Rename !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.641 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.HideMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.643 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ToggleFunction !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.644 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractMethod !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.645 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractConstant !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.646 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.ExtractLocalVariable !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.650 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.RefactoringHistory !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.652 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.createRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.653 !MESSAGE Plug-in 'org.eclipse.cdt.ui' contributed an invalid Menu Extension (Path: 'org.eclipse.jdt.ui.refactoring.menu' is invalid): org.eclipse.cdt.ui.actions.applyRefactoringScript !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.712 !MESSAGE Plugin 'org.eclipse.search' invalid Menu Extension (Path 'org.eclipse.search.menu' is invalid): textSearchSubMenu !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.715 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenFileSearchPage !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.728 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu' is invalid): org.eclipse.search.OpenSearchDialog !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.730 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkingSet !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.732 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchFile !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.733 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchProject !ENTRY org.eclipse.ui 4 4 2022-11-10 15:54:51.734 !MESSAGE Plug-in 'org.eclipse.search' contributed an invalid Menu Extension (Path: 'org.eclipse.search.menu/textSearchSubMenu' is invalid): org.eclipse.search.TextSearchWorkspace !ENTRY org.eclipse.egit.ui 2 0 2022-11-10 15:54:58.125 !MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git user global configuration and to define the default location to store repositories: 'C:\Users\sm116'. If this is not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and EGit might behave differently since they see different configuration options. This warning can be switched off on the Team > Git > Confirmations and Warnings preference page. !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:54:59.887 !MESSAGE Enablement expression is missing for descriptor type org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:54:59.889 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType !ENTRY org.eclipse.launchbar.core 2 0 2022-11-10 15:54:59.890 !MESSAGE Enablement expression is missing for config provider for org.eclipse.cdt.debug.core.coreBuildDescriptorType ```
2022-11-12
学以致用
工程存放的路径是什么?是不是有中文什么的?怎么有 `C:\Users\sm116` 的信息?
412
zhu123xxx
RT-Thread Studio创建项目失败
无法使用platformIO创建项目
RT-Thread创建项目总显示已存在,删了没用怎么办?
创建基于开发板的项目,创建失败。
RT-Thread BSP支持玄铁全系列RISC-V内核啦
ubuntu20搭建rtthead5.2.0开发环境
BitsButton嵌入式按键处理框架
art-pi2 上手记录(二)
