[第二期 空气质量分析仪] 第二周作业
发布于 2019-09-06 23:01:47 浏览:960
+ RW007 连接 onenet 成功 ,但温湿度气压数据没配置上传   ```/* * Copyright (c) 2006-2018, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * */ #include
#include "sensor.h" #include
/* 使用BSD socket,需要包含sockets.h头文件 */ #include
#include "bme280.h" #define SENSOR_NAME "temp_bme" static char send_buf[100]; /* 发送用到的数据 */ #if 0 struct bme280_data { /*! Compensated pressure */ uint32_t pressure; /*! Compensated temperature */ int32_t temperature; /*! Compensated humidity */ uint32_t humidity; }; #endif uint8_t sensor_comp; struct bme280_data comp_data[1]; struct bme280_dev bme_dev[1]; void udp_update(int argc, char **argv) { int sock, port, count; struct hostent *host; struct sockaddr_in server_addr; const char *url; rt_device_t dev = RT_NULL; struct rt_sensor_data data; rt_size_t res, i; if (argc < 3) { rt_kprintf("Usage: udp_update URL PORT [COUNT = 10]
"); rt_kprintf("Like: udp_update 192.168.12.44 5000
"); return ; } url = argv[1]; port = strtoul(argv[2], 0, 10); if (argc > 3) count = strtoul(argv[3], 0, 10); else count = 10; /* 通过函数入口参数url获得host地址(如果是域名,会做域名解析) */ host = (struct hostent *) gethostbyname(url); /* 创建一个socket,类型是SOCK_DGRAM,UDP类型 */ if ((sock = socket(AF_INET, SOCK_DGRAM, 0)) == -1) { rt_kprintf("Socket error
"); return; } /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *)host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* dev = rt_device_find(SENSOR_NAME); if (dev == RT_NULL) { rt_kprintf("Can't find device:%s", SENSOR_NAME); return; } if (rt_device_open(dev, RT_DEVICE_FLAG_RDWR) != RT_EOK) { rt_kprintf("open device failed!"); return; } rt_device_control(dev, RT_SENSOR_CTRL_SET_ODR, (void *)100); */ /* 总计发送count次数据 */ for(i = 0; i < count; i ++) { //res = rt_device_read(dev, 0, &data, 1); //if (res != 1) // { // rt_kprintf("read data failed!size is %d", res); // } // else //{ // bme280_get_sensor_data(sensor_comp,comp_data,bme_dev); rt_sprintf(send_buf, "num:%3d, x:%5d, y:%5d, z:%5d, timestamp:%5d
" , i, data.data.mag.x, data.data.mag.y, data.data.mag.z, data.timestamp); // } /* 发送数据到服务远端 */ sendto(sock, send_buf, strlen(send_buf), 0, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)); /* 线程休眠一段时间 */ rt_thread_mdelay(100); } // rt_device_close(dev); /* 关闭这个socket */ closesocket(sock); } MSH_CMD_EXPORT(udp_update, a udp update sample); ```
960
beidou
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
