软定时器
_timer_start()函数功能虽然正常,但实现是否未达预期
发布于 2024-12-25 17:29:26 浏览:177
有疑问代码如下: ```c static rt_err_t _timer_start(rt_list_t *timer_list, rt_timer_t timer) { unsigned int row_lvl; rt_list_t *row_head[RT_TIMER_SKIP_LIST_LEVEL]; unsigned int tst_nr; static unsigned int random_nr; /* remove timer from list */ _timer_remove(timer); /* change status of timer */ timer->parent.flag &= ~RT_TIMER_FLAG_ACTIVATED; RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(timer->parent))); timer->timeout_tick = rt_tick_get() + timer->init_tick; row_head[0] = &timer_list[0]; for (row_lvl = 0; row_lvl < RT_TIMER_SKIP_LIST_LEVEL; row_lvl++) { for (; row_head[row_lvl] != timer_list[row_lvl].prev; row_head[row_lvl] = row_head[row_lvl]->next) { struct rt_timer *t; rt_list_t *p = row_head[row_lvl]->next; /* fix up the entry pointer */ t = rt_list_entry(p, struct rt_timer, row[row_lvl]); /* If we have two timers that timeout at the same time, it's * preferred that the timer inserted early get called early. * So insert the new timer to the end the the some-timeout timer * list. */ if ((t->timeout_tick - timer->timeout_tick) == 0) { continue; } else if ((t->timeout_tick - timer->timeout_tick) < RT_TICK_MAX / 2) { break; } } if (row_lvl != RT_TIMER_SKIP_LIST_LEVEL - 1) row_head[row_lvl + 1] = row_head[row_lvl] + 1; } /* Interestingly, this super simple timer insert counter works very very * well on distributing the list height uniformly. By means of "very very * well", I mean it beats the randomness of timer->timeout_tick very easily * (actually, the timeout_tick is not random and easy to be attacked). */ random_nr++; tst_nr = random_nr; rt_list_insert_after(row_head[RT_TIMER_SKIP_LIST_LEVEL - 1], &(timer->row[RT_TIMER_SKIP_LIST_LEVEL - 1])); for (row_lvl = 2; row_lvl <= RT_TIMER_SKIP_LIST_LEVEL; row_lvl++) { if (!(tst_nr & RT_TIMER_SKIP_LIST_MASK)) rt_list_insert_after(row_head[RT_TIMER_SKIP_LIST_LEVEL - row_lvl], &(timer->row[RT_TIMER_SKIP_LIST_LEVEL - row_lvl])); else break; /* Shift over the bits we have tested. Works well with 1 bit and 2 * bits. */ tst_nr >>= (RT_TIMER_SKIP_LIST_MASK + 1) >> 1; } timer->parent.flag |= RT_TIMER_FLAG_ACTIVATED; return RT_EOK; } ``` 虽然功能都正常,但在双层循环中查找新节点插入节点时,代码中没有利用跳表的优势呀。如果将跳表设置为多层的话,里层的循环(低层的比较)未给外层循环(高层的比较)留线索呀。高层的循环每次必须从头开始比较,如果这样的话还不如直接就用单链表实现更简洁一些。
177
jxh_gogo
KEIL环境开启3级优化,连续启动两个软件定时器,后启动的定时器无法正常运行
MSH命令创建定时器,使用完成后删除,再次使用MSH命令创建无法运行
软定时器开启导致栈溢出
软定时器的回调会比所有线程都优先执行吗?
睿擎工业开发平台---文件系统测试使用
睿擎工业开发平台--SPI使用和测四
睿擎工业开发平台--can总线使用测试
睿擎工业开发平台--如何将i2c1的引脚用于串口4
