elm_fatfs_FAT文件系统
外部FLASH中的分区挂载FAT文件系统后,能创建删除文件夹,但是无法进行mkfs操作和读写文件操作
发布于 2023-10-16 15:52:46 浏览:559
如题,基本条件和官方例程中一致,W25Q128被切分成了几个区,我目标是将filesystem区挂载为文件为文件系统根目录,挂载成功后能创建删除文件夹,但是无法进行mkfs操作和读写文件操作。 芯片:STM32F407ZGT6 工具链:arm-none-eabi-gcc RT-Thread版本:RT-Thread v5.0.1 目前可以确认flash无硬件问题,我已测试从flash中读写数据和擦除flash操作。 控制台记录如下:  config如下:   代码如下: ```c #include
#if DFS_FILESYSTEMS_MAX < 4 #error "Please define DFS_FILESYSTEMS_MAX more than 4" #endif #if DFS_FILESYSTEM_TYPES_MAX < 4 #error "Please define DFS_FILESYSTEM_TYPES_MAX more than 4" #endif #define DBG_TAG "drv.fsystem" #define DBG_LVL DBG_LOG #include
#ifdef BSP_USING_SDCARD_FATFS static int onboard_sdcard_mount(void) { if (dfs_mount("sd0", "/sdcard", "elm", 0, 0) == RT_EOK) { LOG_D("SD card mount to '/sdcard'"); } else { LOG_E("SD card mount to '/sdcard' failed!"); } return RT_EOK; } #endif /* BSP_USING_SDCARD_FATFS */ #ifdef BSP_USING_SPI_FLASH_LITTLEFS #include
#define FS_PARTITION_NAME "spiflash0" static int onboard_spiflash_mount(void) { struct rt_device *mtd_dev = RT_NULL; fal_init(); mtd_dev = fal_mtd_nor_device_create(FS_PARTITION_NAME); if (!mtd_dev) { LOG_E("Can't create a mtd device on '%s' partition.", FS_PARTITION_NAME); } if (dfs_mount(FS_PARTITION_NAME, "/spiflash", "lfs", 0, 0) == RT_EOK) { LOG_D("spi flash mount to '/spiflash'"); } else { dfs_mkfs("lfs", FS_PARTITION_NAME); if (dfs_mount(FS_PARTITION_NAME, "/spiflash", "lfs", 0, 0) == RT_EOK) { LOG_D("spi flash mount to '/spiflash'"); } else { LOG_E("spi flash failed to mount to '/spiflash'"); } } return RT_EOK; } #endif /* BSP_USING_SPI_FLASH_LITTLEFS */ #ifdef BSP_USING_SPI_FLASH_FATFS #include
#define FS_PARTITION_NAME "filesystem" static int onboard_spiflash_mount(void) { struct rt_device *mtd_dev = RT_NULL; fal_init(); mtd_dev = fal_blk_device_create(FS_PARTITION_NAME); if (!mtd_dev) { LOG_E("Can't create a blk device on '%s' partition.", FS_PARTITION_NAME); } if (dfs_mount(FS_PARTITION_NAME, "/", "elm", 0, 0) == RT_EOK) { LOG_D("spi flash mount to '/'."); } else { dfs_mkfs("elm", FS_PARTITION_NAME); if (dfs_mount(FS_PARTITION_NAME, "/", "elm", 0, 0) == RT_EOK) { LOG_D("spi flash mount to '/'."); } else { LOG_E("spi flash failed to mount to '/'."); } } return RT_EOK; } #endif /* BSP_USING_SPI_FLASH_FATFS */ static const struct romfs_dirent _romfs_root[] = { #ifdef BSP_USING_SDCARD_FATFS {ROMFS_DIRENT_DIR, "sdcard", RT_NULL, 0}, #endif #ifdef BSP_USING_SPI_FLASH_LITTLEFS {ROMFS_DIRENT_DIR, "spiflash", RT_NULL, 0}, #endif #ifdef BSP_USING_SPI_FLASH_FATFS {ROMFS_DIRENT_DIR, "spiflash", RT_NULL, 0}, #endif }; const struct romfs_dirent romfs_root = { ROMFS_DIRENT_DIR, "/", (rt_uint8_t *)_romfs_root, sizeof(_romfs_root) / sizeof(_romfs_root[0])}; static int filesystem_mount(void) { // if (dfs_mount(RT_NULL, "/", "rom", 0, &(romfs_root)) != 0) // { // LOG_E("rom mount to '/' failed!"); // } #ifdef BSP_USING_SDCARD_FATFS onboard_sdcard_mount(); #endif #ifdef BSP_USING_SPI_FLASH_LITTLEFS onboard_spiflash_mount(); #endif #ifdef BSP_USING_SPI_FLASH_FATFS onboard_spiflash_mount(); #endif return RT_EOK; } // INIT_APP_EXPORT(filesystem_mount); MSH_CMD_EXPORT(filesystem_mount, filesystem mount); ```
2023-10-16
看起来是根目录挂载成了ROMFS的问题 mkfs要在挂载前调用
559
普普通通的叁金
请问谁有用过elm fatfs挂在 nand flash 的经验
STM32F413 SD 卡写入速度提升方法
W25Q128spi flash的elm挂载失败
为什么在DFS中管FATFS叫elm-fat文件系统?
W25Q128创建的ELM文件系统掉电丢失
初始化elm文件系统时报错空间不足,挂载片外flash文件系统时失败。
W25QXX挂载elm文件系统的分区小于512KB时你们成功了吗
dfs上打开文件 open 操作返回 -19
在rt-rthread v4.0.1版本中,读sd卡或u盘崩溃问题
elmfat写数据长度大于512字节,系统hard fault
新版OneNet的星火1号开发板例程适配(下)
重磅预售!RT-Trace调试工具
tjrong
yans
miandian_7
Pai同学
Rick98
河南理工大学恁带劲儿
