开机时出现SPI初始化错误是怎么回事?
发布于 2024-11-06 15:09:17 浏览:550
刚开始初始化了三个通道的adc模拟输入,第一个初始化的时候出现期望的值和读到的值不同,但是第二个第三个没问题,下面是具体代码和报错信息   初始化实现代码 ```c int ads114s08_spi_device_init(struct rt_spi_device **spi_chip, const char *spi_name, const char *dev_name,GPIO_TypeDef *cs_gpiox, uint16_t cs_gpio_pin) { ads114s08_device_t dev; rt_err_t res; dev = rt_calloc(1, sizeof(struct ads114s08_device)); if (dev == RT_NULL) { LOG_E("Can't allocate memory for ads114s08 device on '%s' ", dev_name); rt_free(dev); return RT_NULL; } res = rt_hw_spi_device_attach(spi_name, dev_name, cs_gpiox, cs_gpio_pin); if (res != RT_EOK) { LOG_E("ads114s08 failed to attach device %s\n", dev_name); return res; } *spi_chip = (struct rt_spi_device *)rt_device_find(dev_name); if (!*spi_chip) { LOG_E("spi find run failed! cant't find %s device!\n", dev_name); return RT_NULL; } dev->spi = *spi_chip; //Set device SPI Mode (*spi_chip)->bus->owner = *spi_chip; struct rt_spi_configuration cfg; cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_1 | RT_SPI_MSB; cfg.max_hz = 1 * 1000 * 1000; /* 1M */ rt_spi_configure(dev->spi, &cfg); if (ads114s08_chip_init(dev) != RT_EOK) { LOG_E("chip init error"); rt_free(dev); return RT_NULL; } return res; } static rt_err_t ads114s08_chip_init (ads114s08_device_t dev) { bool status; status = adcStartupRoutine( dev->spi ); if (status == false) { LOG_E("ads114s08 chip init error"); return RT_ERROR; } writeSingleRegister(dev->spi, REG_ADDR_GPIOCON, 0x0F); //Config gpio to output sendSTART( dev->spi ); return RT_EOK; } 在 writeSingleRegister函数中,把registerMap[i]的值赋给initRegisterMap[i] 但在readMultipleRegisters函数里,读取到的registerMap[i]发生了改变 writeSingleRegister( dev, REG_ADDR_STATUS, 0x00 ); // Reset POR event // Create temporary array based on desired configuration for( i = 0 ; i < NUM_REGISTERS ; i++) { initRegisterMap[i] = registerMap[i]; } // Read back all registers, except for status register. readMultipleRegisters( dev, REG_ADDR_ID, NUM_REGISTERS ); for ( i = REG_ADDR_STATUS; i < REG_ADDR_SYS - REG_ADDR_STATUS + 1; i++ ) { if ( i == REG_ADDR_STATUS ) continue; if ( initRegisterMap[i] != registerMap[i] ) return( false ); } return( true ); 下面是 readMultipleRegisters具体的实现 void readMultipleRegisters( struct rt_spi_device *dev, uint8_t startAddress, uint8_t count ) { rt_err_t ret = 0; uint8_t DataTx[COMMAND_LENGTH + NUM_REGISTERS] = { 0 }; uint8_t DataRx[COMMAND_LENGTH + NUM_REGISTERS] = { 0 }; uint8_t i; /* Check that the register address and count are in range */ assert( startAddress + count <= NUM_REGISTERS ); // Read register data bytes DataTx[0] = OPCODE_RREG | (startAddress & OPCODE_RWREG_MASK); DataTx[1] = count - 1; // spiSendReceiveArrays( dev, DataTx, DataRx, COMMAND_LENGTH + count); //TODO_ADS ret = rt_spi_transfer(dev, DataTx, DataRx, COMMAND_LENGTH + count); if (ret == 0) { LOG_E("ads114S08 rt_spi_transfer failed!\r\n"); } for ( i = 0; i < count; i++ ) { // Store received register data into internal registerMap copy registerMap[i+startAddress] = DataRx[COMMAND_LENGTH + i]; } } 主要不理解为什么只有第一个通道的初始化报错,到底为什么读到的值发生了改变,希望有大佬能帮忙解答一下疑惑 ```
2024-11-14
试试操作spi10前,把3个设备的片选设置下 操作spi10时,其他设备的片选如果没有失能,相当于同时挂在spi总线上了
兜兜里有啥
2024-11-14
用逻辑分析仪抓一下吧
2024-11-14
adcStartupRoutine 看看这函数为啥返回false吧,这属于驱动内部实现了
550
cccc12234
BBB的SPI驱动
求个SPI上挂两个或多个设备的使用例子
SPI设备有个bug
SPI驱动
请教rt_spi_configure函数理解
SPI FLASH挂载的问题
SPI-FLASH 文件系统 SPIFFS
求助一个完整的 spi flash 驱动
关于同时使用文件系统与SPI FLASH的问题
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
D1sguIse_
Ryan_CW
