信号量_semaphore
内存访问断点_写断点
30
在使用sem时,sem_xx-parent-suspend_thread被改变,应该执行take线程的被改变成了指向了release线程
发布于 2024-07-11 23:27:52 浏览:282
在使用信号量时,一个线程release一个线程take,在某些特定时候,take线程永远不执行了,release线程确认一直有释放,sem下面的Value一直在增加, 详细追踪,发现在take的某个时候,sem信号量下的`semxx->parent.suspend_thread->next`的值发生了改变,本来应该指向take线程的地址,变成了指向release线程地址,导致sem下的supend_thread列表在release时恢复take线程. 代码如下 ```c #include "outunit.h" #include "app.h" #include "uhp.h" //ALIGN(RT_ALIGN_SIZE) #define OUTUNIT_UART_NAME "uart2" #define PARSE_DATA_HEAD 0 #define PARSE_DATA_BODY 1 #define PARSE_DATA_TAIL 2 #define PARSE_DATA_CHECK 3 #define DATA_LEN 19 rt_uint8_t frame_buf[20]; rt_uint8_t state = 0; rt_uint8_t frame_buf_offset = 0; rt_uint8_t outUnitConnectErr; rt_uint8_t *shiyuan_setHandler; typedef struct _shiyuan_format{ uint8_t head; uint8_t addr; uint8_t function; uint8_t len; uint8_t data[13]; uint8_t tail; uint8_t verify; }shiyuan_format, *shiyuan_format_t; struct rx_msg{ rt_device_t dev; // 设备句柄 rt_size_t receiveSize; // 接收数据尺寸 }; const char *uart_name; // 设备名字 struct rt_semaphore outUnitTxSem; //发送信号量 struct rt_messagequeue outUnitRxMq; // 消息队列 rt_device_t outUnitdev; typedef struct { SHIYUAN_OUTINFO sy_data; SHIYUAN_OUTSET sy_set; } OUT_UNIT; OUT_UNIT outUnit; /* * 函数名称: SUM_Check() */ rt_uint8_t SUM_Check(rt_uint8_t *buf, rt_uint8_t len) { rt_uint8_t temp_result = 0, cnt = 0; for (cnt = 0; cnt < len; cnt++) { temp_result += buf[cnt]; } temp_result = ~temp_result; return temp_result; } // 发送编码 static void OutUnit_ReplyCode(rt_uint8_t *tx_buf , rt_uint8_t com_len ) { rt_device_write(outUnitdev,0, tx_buf, com_len); } void shiyuan_send(void ) { static shiyuan_format sy_dev; sy_dev.head = 0xAA; sy_dev.addr =frame_buf[1]; sy_dev.len =13; sy_dev.function =frame_buf[2]+0x30; switch(frame_buf[2]) { case 0x11: rt_memcpy(sy_dev.data, (uint8_t*)&outUnit.sy_set.curIndoorMode,sy_dev.len); // 如果是41信息回复 sy_dev.data[sy_dev.len-1]= 0x06; // 湿度设置 50 // 最后一个字节是设置湿度 break; case 0x12: rt_memcpy(sy_dev.data,(uint8_t*)&outUnit.sy_set.curIndoorMode,sy_dev.len); break; case 0x13: case 0x14: rt_memset((uint8_t*)sy_dev.data,0,sy_dev.len); break; } sy_dev.tail =0xBB; sy_dev.verify = SUM_Check(&sy_dev.addr, DATA_LEN- 2); OutUnit_ReplyCode((uint8_t*)&sy_dev.head,DATA_LEN); // 发送数据 } //发送处理线程 static void OutUnit_TxThreadEntry(void *parameter) { (void ) *parameter; while(1) { if( RT_EOK == rt_sem_take(&outUnitTxSem,RT_WAITING_FOREVER))// 等待信号量释放 { shiyuan_send(); } else { rt_kprintf("out tx sem take Error!\n"); } } } /********************************************************************************/ // 接收回调函数 rt_err_t OutUnit_ReceiveCb(rt_device_t dev, rt_size_t size) { rt_err_t ret =0; struct rx_msg msg; msg.dev = dev; msg.receiveSize = size>DATA_LEN ? DATA_LEN : size; ret = rt_mq_send(&outUnitRxMq,&msg, sizeof(struct rx_msg)); //发送消息队列 return ret; } // 字节解析 static void OutUnit_ReceiveDecodeChar(rt_uint8_t ch ) { rt_uint8_t *temp_ptr = 0; switch(state) { case PARSE_DATA_HEAD: if (frame_buf_offset ==0)// 刚解析第一个 { if(ch == 0xAA) { frame_buf[0] = ch; frame_buf_offset =1; } } else if(frame_buf_offset == 1) // 解析第二个 { if (ch ==0x01) { frame_buf[1] = ch; frame_buf_offset =2; } } else if (frame_buf_offset ==2) // 第三字节 { if ((ch<=0x14)&&(ch>=0x11)) { frame_buf[2] = ch; frame_buf_offset =3; } } else if (frame_buf_offset ==3) // 第三字节 { if (ch==13) { frame_buf[3] = ch; frame_buf_offset =4; state = PARSE_DATA_BODY; } } else { frame_buf_offset =0; state = PARSE_DATA_HEAD; } break; case PARSE_DATA_BODY: frame_buf[frame_buf_offset] =ch; // 存储每个数据 frame_buf_offset++; if (frame_buf_offset > DATA_LEN-3) { state = PARSE_DATA_TAIL; } break; case PARSE_DATA_TAIL: if (ch == 0xBB) { frame_buf[frame_buf_offset++]=ch; state = PARSE_DATA_CHECK; } break; case PARSE_DATA_CHECK: if (SUM_Check(&frame_buf[1], DATA_LEN- 2) ==ch) { timeCnt.oduConnectCnt=0; frame_buf[frame_buf_offset]=ch; if (frame_buf[2]== 0x11) temp_ptr = &outUnit.sy_data.r0x11_curOutRunMode; else if (frame_buf[2]== 0x12) temp_ptr = &outUnit.sy_data.r0x12_acCurrent_H; else if (frame_buf[2]== 0x13) temp_ptr = &outUnit.sy_data.r0x13_codeIndex_HH; else if (frame_buf[2]== 0x14) temp_ptr = &outUnit.sy_data.r0x14_ctrlIndoorEnable1; rt_memcpy(temp_ptr,(rt_uint8_t*)(frame_buf +4),DATA_LEN- 6); rt_sem_release(&outUnitTxSem); // 释放一个发送信号量 ,怀疑释 } frame_buf_offset=0; state = PARSE_DATA_HEAD; break; } } #endif /* 1 */ //接收处理线程 static void OutUnit_RxThreadEntry(void *parameter) { struct rx_msg msg; rt_size_t len=0; rt_uint8_t rx_buf[RT_SERIAL_RB_BUFSZ ]={0}; (void ) *parameter; while(1) { rt_memset(&msg, 0, sizeof(msg)); if ( RT_EOK == rt_mq_recv(&outUnitRxMq, &msg, sizeof(msg), RT_WAITING_FOREVER)) //获取 消息队列 移植等待 { len = rt_device_read(msg.dev,0, &rx_buf,msg.receiveSize); // for(uint8_t cnt=0; cnt< len ;cnt++) { OutUnit_ReceiveDecodeChar(rx_buf[cnt]); } } } } // 初始化函数 static int OutUnit_Init(void) { static char msg_pool[256]; rt_memset(&outUnit.sy_data,0,sizeof(SHIYUAN_OUTINFO)); rt_memset(&outUnit.sy_set,0,sizeof(SHIYUAN_OUTSET)); rt_sem_init(&outUnitTxSem,"outtx",0,RT_IPC_FLAG_FIFO); // 创建发送信号量 rt_mq_init(&outUnitRxMq,"outrx",msg_pool,sizeof(struct rx_msg),sizeof(msg_pool),RT_IPC_FLAG_FIFO); // uart_name = OUTUNIT_UART_NAME ; static struct serial_configure cfg = { .baud_rate = 600, .data_bits = DATA_BITS_8, .stop_bits = STOP_BITS_2, .bit_order=BIT_ORDER_LSB, .bufsz = 256, .parity = PARITY_EVEN, // 偶校验 }; outUnitdev = rt_device_find(uart_name);// 获取设备 if (outUnitdev != RT_NULL) rt_device_control(outUnitdev,RT_DEVICE_CTRL_CONFIG,&cfg); // 初始化串口 rt_device_open(outUnitdev,RT_DEVICE_FLAG_DMA_RX|RT_DEVICE_FLAG_DMA_TX); // DMA读写打开 rt_device_set_rx_indicate(outUnitdev, OutUnit_ReceiveCb); // 设置接收回到函数 rt_thread_t rx_thread = rt_thread_create("rx", OutUnit_RxThreadEntry, RT_NULL, 1024, 12, 10); RT_ASSERT(rx_thread != RT_NULL); rt_thread_startup(rx_thread); rt_thread_t tx_thread = rt_thread_create("tx", OutUnit_TxThreadEntry, RT_NULL, 1024, 9,20); RT_ASSERT(tx_thread != RT_NULL); rt_thread_startup(tx_thread); return 0; } INIT_APP_EXPORT(OutUnit_Init); /***************************************************************************************/ // 读数据 void* OutUnit_GetOutUnitData(void) { return (SHIYUAN_OUTINFO*)&outUnit.sy_data; } // 写入更新数据 int OutUnit_WriteOutUnitData(rt_uint8_t *rData , rt_uint16_t offset, rt_uint16_t num) { if(offset +num >sizeof(SHIYUAN_OUTSET)) //超出范围 return -1; rt_memcpy((rt_uint8_t*)(&outUnit.sy_set.curIndoorMode+offset), rData , num); return num; } ```
miandain_7
2024-07-15
建议检查一下相关线程优先级,是不是某个状态一致在触发释放信号量的线程。
282
Chanted
怎样可以将信号量复位为初始值
rt_sem_take 引起段错误
生产者消费者中是否可以使用一个事件集来代替多个二值信号量?
看RTT文档,不太懂有关信号量的死锁问题
这样使用UART接收一帧数据的方法是否可行
一对多线程间通信的问题
二值信号量的使用问题
USART1_IRQHandler串口中断接收问题
开发文档semaphore_sample.c有问题
RT-Thread studio的驱动5.1.0报错修改
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
818
