DIY综合交流区
RealTouch上错电悲剧了
发布于 2012-11-29 15:42:04 浏览:2882
拿错9V的适配器插到板子上了。没有反应了,初步查一下烧了U16(USBLC6-4);把U16拆了,上电串口有信息出来了;说明CPU 没有烧坏(因为CPU的供电是经过1117了)。 但是液晶显示不了,开始以为排线可能没有插好,重新拨出来,再插回去;来回几次结果把PIN1脚弄断了;赶快查原理图,还好是LED的。 重新上电还是不亮,而且L3(电感)很烫,还有附近的几个二极管也烫。 这样是不是液晶已经烧坏了?
lindabell
2012-11-29
我把pin1脚接上了,finsh打印如下,但是L3电感还是发烫 >| / >- RT - Thread Operating System > / | 1.1.0 build Nov 24 2012 > 2006 - 2012 Copyright by rt-thread team >lwip_sanity_check: WARNING: MEMP_NUM_TCP_SEG should be at least as big as TCP_SND_QUEUELEN >lwip_sanity_check: WARNING: TCP_SND_BUF must be at least as much as (2 * TCP_MSS) for things to work smoothly >TCP/IP initialized! >W25Q64BV or W25Q64CV detection >finsh />error detected and set to -2/0 (cmd = 5),0x00000004 >SD card capacity 1931264 KB >found part[0], begin: 1048576, size: 1.861GB >flash0 mount to / >Unable to open GBK to Unicode look up table. >Unable to open Unicode to GBK look up table. >sd0 mount to /SD >stat -> stopped >97%setup_load >97% ---
2012-11-29
还是发回来吧。地址已PM。
2.9k
lindabell
93
[项目]搞个开源的硬件项目
硬件计划贴,及时更新,欢迎提意见
MMS协议
定点的wma解压库-libwma
QQ群记录 [20090821]
STM32网络收音机PCB报名征集
第一版调试记录
第二版硬件讨论
art-pi2 上手记录(二)
STM32内存扩展,SRAM-RMC
