SD卡动态的mount和unmount问题
发布于 2013-12-18 10:48:23 浏览:3330
版本:RTT-1.2.0RC stm32f407VG 情景: 系统使用双文件系统,w25q64作为"/", sd卡作为"/SD" 需要的功能: 1)系统上电后先挂w25q64,然后读取sd的cd脚,如果检测到sd卡插入,就挂载sd卡。如果没有,则忽略。 2)配置sd的cd脚为中断,双边沿方式。插入和拔掉sd卡,会触发中断,中断进入后,立即关闭中断使能,清楚标志,发送信号量给sd卡的监控线程,在线程里面延时50ms,然后读取cd脚的状态,判别是插入了sd卡,还是移除了卡。如果拔出了,则dfs_unmount("/SD"),如果插入,则dfs_mount("sd0", "/SD", "elm", 0, 0)。 问题: 1)老是在线程里面dfs_mount失败 sd_mount_flag sd卡是否挂载的标志位 1,已经挂载;0,没有挂载过 g_sdcard_flag sd卡是否插入的标志位,1检测到sd卡,0无sd卡插入 初始化部分 初始化的代码系统上电后先挂w25q64,然后读取sd的cd脚,如果检测到sd卡插入,就挂载sd卡。如果没有,则忽略。 中断里面的代码 ```void EXTI9_5_IRQHandler(void) { NVIC_InitTypeDef NVIC_InitStructure; rt_kprintf("sdcard detected interrupt handling. "); if(EXTI_GetITStatus(EXTI_Line6) == SET) { NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE; NVIC_Init(&NVIC_InitStructure); EXTI_ClearITPendingBit(EXTI_Line6); //rt_timer_start(&timer_sdmon); rt_sem_release(&sdmon_sem); } }``` 线程里面的代码 ```void thread_entry_sdmon(void* parameter) { rt_err_t result; NVIC_InitTypeDef NVIC_InitStructure; result = rt_sem_init(&sdmon_sem, "sdmon_sem", 0, RT_IPC_FLAG_FIFO); if (result != RT_EOK) { DEBUG("sdmon_sem init failed. "); } while(1) { rt_sem_take(&sdmon_sem, RT_WAITING_FOREVER); rt_thread_delay(20); //?ò???±?°?????? EXTI_ClearITPendingBit(EXTI_Line6); NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); //detect sdcart is exist. if(GPIO_ReadInputDataBit(SD_DETECT_GPIO_PORT, SD_DETECT_PIN) != Bit_RESET) g_sdcard_flag = 0; else g_sdcard_flag = 1; //sdcard???????? if(g_sdcard_flag == 0) { if(sd_mount_flag == RT_TRUE) { if(dfs_unmount("/SD") < 0) rt_kprintf("unmount /SD failed. "); else { rt_kprintf("sdcard unmounted! "); sd_mount_flag = RT_FALSE; } } } //sdcard???????? else if(g_sdcard_flag == 1) { rt_kprintf("sdcard detected! "); if(sd_mount_flag == RT_FALSE) { if (dfs_mount("sd0", "/SD", "elm", 0, 0) == 0) { rt_kprintf("sdcard mounted! "); sd_mount_flag = RT_TRUE; } else { rt_kprintf("sdcard mount failed. "); //sd_mount_flag = RT_FALSE; } } } } }``` 出现的错误: finsh /> sdcard detected interrupt handling. sdcard unmounted! sdcard detected interrupt handling. sdcard detected! error detected and set to -2/0 (cmd = 17) mmcsd request blocks error -2,0,0, 0x00000002,0x00000000 sdcard mount failed.
gongjian32
2013-12-18
追踪了一下代码: 在dfs_elm.c里面这里出现了错误,result = f_opendir(dir, drive);返回错误 ``` /* open the root directory to test whether the fatfs is valid */ result = f_opendir(dir, drive); if (result != FR_OK) goto __err; /* mount succeed! */ fs->data = fat; rt_free(dir); return 0; } __err: f_mount((BYTE)index, RT_NULL); disk[index] = RT_NULL; rt_free(fat); return elm_result_to_dfs(result); } ```
2013-12-18
用的MMC框架吧,MMC/SD框架自己有个自动挂载线程,你需要用这个。
gongjian32
2013-12-18
1)里面却是有个线程 ``` void mmcsd_detect(void *param) { struct rt_mmcsd_host *host; rt_uint32_t ocr; rt_int32_t err; while (1) { if (rt_mb_recv(&mmcsd_detect_mb, (rt_uint32_t*)&host, RT_WAITING_FOREVER) == RT_EOK) { if (1)//host->card == RT_NULL) { mmcsd_host_lock(host); mmcsd_power_up(host); mmcsd_go_idle(host);] ``` 我在中断里面发送sem到一个线程,然后再这个线程里面 发送 mmcsd_change(host); 我自己构造了1个函数 ``` void send_sd_change(void) { mmcsd_change(stm32f4_sdio->host); } ``` 问题是在mmcsd_detect函数里,要判断host->card是否为RT_NULL 我改成了if(1)就可以正常的挂载了。实际上host->card不是RT_NULL. if (1)//host->card == RT_NULL) 难道我需要在拔出卡的时候除了,dfs_unmount("/SD"),还要将host->card=RT_NULL,清空host->card. realtouch里面没有找到热拔插的相关代码啊? 请问,如何实现sd卡的动态热拔插? sd卡是挂载"/SD"下面的。
prife
2013-12-18
粗看了下代码。逻辑上没发现啥严重问题。 请问楼主,你的问题是否是: dfs_umount之后再重新dfs_mount挂载,每次都会失败? 楼主需要先验证这个问题,可以通过在finsh中手动执行umount以及mount的方式测试。
3.3k
gongjian32
浅谈国产加密芯片的选择
[Vision Board创客营] PWM模块实践
1506
339
1423
281
741
540
157
1218
146
