【已解决】使用邮箱时遇到的问题
发布于 2013-06-01 21:05:53 浏览:3257
我建立一个动态邮箱mb_key用来传送键值,是在rt_application_init()里创建的,创建完成的时候mb_key是0x20001BA4,但是jlink调试发现,执行完rt_application_init()后mb_key的就变为0x00000000了,向大侠请教下这是这么回事?
2013-06-01
内存被覆盖、改写、栈撤销。。。 上你的代码
rtthsl
2013-06-03
>内存被覆盖、改写、栈撤销。。。 > >上你的代码 --- 声明的 ``` #ifndef _KEY_H #define _KEY_H #include
void key_thread_entry(void *para); static rt_mailbox_t mb_key; #endif ``` 创建的,在rt_application_init里创建的 ``` //init key mb and thread mb_key = rt_mb_create("mb_key",8,RT_IPC_FLAG_FIFO); if (mb_key != RT_NULL) rt_kprintf("mb ok! "); init_thread = rt_thread_create("key",key_thread_entry,RT_NULL,2048,7,10); rt_thread_startup(init_thread); init_thread = RT_NULL; ``` 接收的 ``` void beep_thread_entry(void *para) { rt_uint32_t tmp = 0; beep_init(); while (1) { if (rt_mb_recv(mb_key,&tmp,50)==RT_EOK){ rt_kprintf("tmp=%d ",tmp); rt_thread_delay(RT_TICK_PER_SECOND/2); GPIOB->ODR |= 1<<8; rt_thread_delay(RT_TICK_PER_SECOND/2); GPIOB->ODR &= ~(1<<8); } else rt_kprintf("recv key error! "); } } ``` 发送的 ``` void key_thread_entry(void *para) { static rt_uint8_t key_state = 0; static rt_uint32_t key_var = 0; key_init(); while (1) { switch (key_state) { case 0: if (PRESSED){ key_state = 1; } break; case 1: if (PRESSED){ if (KEY0==0) key_var = KEY_RIGHT; if (KEY1==0) key_var = KEY_DOWN; if (KEY2==0) key_var = KEY_LEFT; if (KEY3==1) key_var = KEY_UP; key_state = 2; } else{ key_state = 0; } break; case 2: if (PRESSED){ key_state = 2; } else{ key_state = 0; } break; default:break; } if (key_var > 0){ if (rt_mb_send_wait(mb_key,(rt_uint32_t)key_var,10)==RT_EOK){ rt_kprintf("key send ok! "); key_var = 0; } else rt_kprintf("key send error! "); } rt_thread_delay(RT_TICK_PER_SECOND/50); } } ```
rtthsl
2013-06-03
这是rt_application_init完整的代码 ``` int rt_application_init() { rt_thread_t init_thread; rt_err_t result; //init key mb and thread mb_key = rt_mb_create("mb_key",8,RT_IPC_FLAG_FIFO); if (mb_key != RT_NULL) rt_kprintf("mb ok! "); init_thread = rt_thread_create("key",key_thread_entry,RT_NULL,2048,7,10); rt_thread_startup(init_thread); init_thread = RT_NULL; //init beep thread init_thread = rt_thread_create("beep",beep_thread_entry,RT_NULL,2048,9,10); rt_thread_startup(init_thread); init_thread = RT_NULL; /* init led thread */ result = rt_thread_init(&led_thread, "led", led_thread_entry, RT_NULL, (rt_uint8_t*)&led_stack[0], sizeof(led_stack), 20, 5); if (result == RT_EOK) { rt_thread_startup(&led_thread); } #if (RT_THREAD_PRIORITY_MAX == 32) init_thread = rt_thread_create("init", rt_init_thread_entry, RT_NULL, 2048, 8, 20); #else init_thread = rt_thread_create("init", rt_init_thread_entry, RT_NULL, 2048, 80, 20); #endif if (init_thread != RT_NULL) rt_thread_startup(init_thread); return 0; } ```
rtthsl
2013-06-03
>内存被覆盖、改写、栈撤销。。。 > >上你的代码 --- 突然想起一个问题,我的邮箱名字和邮箱控制块指针的名字相同,这个有问题吗?因为对邮箱处理细节还未完全清楚,所以有此问
2013-06-03
在头文件中声明: static rt_mailbox_t mb_key; 这个会是什么,看看C语言中如何描述static关键字的。
rtthsl
2013-06-03
>在头文件中声明: >static rt_mailbox_t mb_key; > >这个会是什么,看看C语言中如何描述static关键字的。 --- 呃。。c没学到家。。。见笑了
3.3k
rtthsl
22
Wireshark抓包EtherCAT报文
RT-Thread studio的驱动5.1.0报错修改
818
