问题如图
* File : fal_cfg.h
* This file is part of FAL (Flash Abstraction Layer) package
* COPYRIGHT (C) 2006 - 2018, RT-Thread Development Team
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License along
* with this program; if not, write to the Free Software Foundation, Inc.,
* 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
* Change Logs:
* Date Author Notes
* 2018-05-17 armink the first version
#ifndef _FAL_CFG_H_
#define _FAL_CFG_H_
#include <rtconfig.h>
#include <board.h>
// #define NOR_FLASH_DEV_NAME "norflash0"
/* ===================== Flash device Configuration ========================= */
extern const struct fal_flash_dev stm32_onchip_flash;
// extern struct fal_flash_dev nor_flash0;
/* flash device table */
#define FAL_FLASH_DEV_TABLE \
&stm32_onchip_flash, \
/* ====================== Partition Configuration ========================== */
#ifdef FAL_PART_HAS_TABLE_CFG
/* partition table */
#define FAL_PART_TABLE \
{FAL_PART_MAGIC_WORD, "app", "onchip_flash", 0, 128*1024, 0}, \
{FAL_PART_MAGIC_WORD, "filesystem", "onchip_flash", 128*1024, 512*1024, 0}, \
#endif /* FAL_PART_HAS_TABLE_CFG */
#endif /* _FAL_CFG_H_ */
int main(void)
fal_init();
struct rt_device *flash_dev = fal_blk_device_create(FS_PARTITION_NAME);
if (flash_dev == NULL)
rt_kprintf("Can't create a block device on '%s' partition.\n", FS_PARTITION_NAME);
else
rt_kprintf("Create a block device on the %s partition of flash successful.\n", FS_PARTITION_NAME);
if(rt_device_find(FS_PARTITION_NAME) != RT_NULL)
dfs_mkfs("elm", FS_PARTITION_NAME);
if (dfs_mount(FS_PARTITION_NAME, "/", "elm", 0, 0) == RT_EOK)
rt_kprintf("onchip elm filesystem mount to '/'\n");
else
rt_kprintf("onchip elm filesystem mount to '/' failed!\n");
else
rt_kprintf("find filesystem portion failed\r\n");
while (1)
// LOG_D("Hello RT-Thread!");
rt_thread_mdelay(1000);
return RT_EOK;
VGT6,我也怀疑我分的有问题,我试了不同的分法,都是一样的
