RT-Thread主线程进入不了?
发布于 2019-10-25 10:39:17 浏览:2439
为什么动态创建的函数进不了main_thread_entry()函数,仿真时打断点没有停下来,这个就是ENV自动生成的还没有修改过。。。
GOQP_7938
2021-07-08
我也遇到同样的问题,楼主解决了,教我一下,我用的STM32F103
wqzxy123
2019-10-25
>开了heap没有?这张图不能说明任何问题 --- #define STM32_FLASH_START_ADRESS ((uint32_t)0x08000000) #define STM32_FLASH_SIZE (128 * 1024) #define STM32_FLASH_END_ADDRESS ((uint32_t)(STM32_FLASH_START_ADRESS + STM32_FLASH_SIZE)) #define STM32_SRAM_SIZE (128) #define STM32_SRAM_END (0x20000000 + STM32_SRAM_SIZE * 1024) #if defined(__CC_ARM) || defined(__CLANG_ARM) extern int Image$$RW_IRAM1$$ZI$$Limit; #define HEAP_BEGIN (&Image$$RW_IRAM1$$ZI$$Limit) #elif __ICCARM__ #pragma section="CSTACK" #define HEAP_BEGIN (__segment_end("CSTACK")) #else extern int __bss_end; #define HEAP_BEGIN (&__bss_end) #endif #define HEAP_END STM32_SRAM_END void SystemClock_Config(void); 这个生成的不是有heap吗,前面board初始化里面有堆的初始化了
wqzxy123
2019-10-25
>开了heap没有?这张图不能说明任何问题 --- RT_WEAK void rt_hw_board_init() { #ifdef SCB_EnableICache /* Enable I-Cache---------------------------------------------------------*/ SCB_EnableICache(); #endif #ifdef SCB_EnableDCache /* Enable D-Cache---------------------------------------------------------*/ SCB_EnableDCache(); #endif /* HAL_Init() function is called at the beginning of the program */ HAL_Init(); /* enable interrupt */ __set_PRIMASK(0); /* System clock initialization */ SystemClock_Config(); /* disbale interrupt */ __set_PRIMASK(1); rt_hw_systick_init(); /* Heap initialization */ #if defined(RT_USING_HEAP) rt_system_heap_init((void *)HEAP_BEGIN, (void *)HEAP_END); #endif
wqzxy123
2019-10-25
>什么bsp?sram是128K?还是96+32? --- apollostm32f767
wqzxy123
2019-10-25
>什么bsp?sram是128K?还是96+32? --- rt_thread_t tid; #ifdef RT_USING_HEAP tid = rt_thread_create("main", main_thread_entry, RT_NULL, RT_MAIN_THREAD_STACK_SIZE, RT_MAIN_THREAD_PRIORITY, 20); RT_ASSERT(tid != RT_NULL); #else rt_err_t result; tid = &main_thread; result = rt_thread_init(tid, "main", main_thread_entry, RT_NULL, main_stack, sizeof(main_stack), RT_MAIN_THREAD_PRIORITY, 20); RT_ASSERT(result == RT_EOK); /* if not define RT_USING_HEAP, using to eliminate the warning */ (void)result; #endif rt_thread_startup(tid); 执行到了这里,而且tid也不是NULL,下面会继续执行,但是他不会进入线程里面执行
wqzxy123
2019-10-25
>就问你直接下载后,led灯亮了没有,闪不闪 --- 首先我的程序没有执行线程,灯是肯定不能亮的,虽然我的板子不是那个例程的对应的板子。我是在移植才出现的问题,所以我很好奇为什么会出现这种情况。谢谢!
wqzxy123
2019-10-25
>不是那个bsp对应的板子,直接在apollo上改的吗?不建议这样改,因为可能芯片有小差异,还有硬件上可能不 ... --- 那请问一下,我的是745的板子,但是如果自己写BSP的话,会导致.\build\keil\Obj\rt-thread.axf: Error: L6218E: Undefined symbol rt_hw_spi_device_attach (referred from rw007_stm32_port.o).请问一下这样子该怎么解决呢?我看了官方的746的例程说是目前不支持SPI,后续会增加。
wqzxy123
2019-10-25
>不是那个bsp对应的板子,直接在apollo上改的吗?不建议这样改,因为可能芯片有小差异,还有硬件上可能不 ... --- 但是程序当中是有这个函数的定义的,无论采取什么方法加入都不行,总是显示未定义这个,但是全局搜索能够搜索的到
wqzxy123
2019-10-26
>不是那个bsp对应的板子,直接在apollo上改的吗?不建议这样改,因为可能芯片有小差异,还有硬件上可能不 ... --- 请问一下,直接对main()函数里面定义的引脚用示波器看波形,也没有高低电平的变化。请问一下这个该怎么解决?方便的话可以加个QQ吗?1762698551.
wqzxy123
2019-10-28
>在rtthread_startup()里单步看一下,死在什么地方了?哪个函数? --- 我单步调试过了,没有死直到运行到最后。但是就是不进入线程执行函数,引脚电平也没有变化。这个线程创建完成之后,不需要自己再次调用了吧。。。
2.4k
wqzxy123
【RSOC25】Day5 课程笔记:软件包相关知识
RT-Thread 夏令营 第五天笔记
【RSOC25】Day5 课程笔记:软件包和网络组件
【RSOC25】Day4 课程笔记:I/O设备和驱动框架
【RSOC25】Day3 课程笔记:线程间同步和通信
Ryan_CW
D1sguIse_
