SPI从机
硬件spi
spi硬件主从机,从机接收失败
发布于 2025-02-13 16:15:04 浏览:100
```c #include "master_slave.h" #define MASTER_BUS_NAME "spi2" #define MASTER_DEVICE_NAME "spi20" #define MASTER_CS GET_PIN(B, 12) #define SLAVE_DEVICE_NAME "spi30" #define SLAVE_BUS_NAME "spi3" #define SLAVE_CS GET_PIN(A, 4) #define BUFFER_SIZE 32 struct rt_spi_device *slave_device; struct rt_spi_device *master_device; void master_send_slave_recv(const char *str) { rt_size_t len = strlen(str); rt_uint8_t tx_buf[len + 1],rx_buf[len + 1]; memcpy(tx_buf, str, len); tx_buf[len ] = '\0'; rt_ssize_t result = rt_device_write( (rt_device_t) master_device, 0, tx_buf, len); if(result > 0) LOG_D("SPI MASTER send successful!\n"); rt_device_read((rt_device_t) slave_device, 0, rx_buf, len); rt_kprintf("\n SPI rx_buf : %s\n",rx_buf); } /* 主从机初始化并配置 */ void master_slave_init() { rt_err_t result; // __HAL_RCC_GPIOA_CLK_ENABLE(); // __HAL_RCC_GPIOB_CLK_ENABLE(); rt_hw_spi_device_attach(MASTER_BUS_NAME, MASTER_DEVICE_NAME, MASTER_CS); rt_hw_spi_device_attach(SLAVE_BUS_NAME, SLAVE_DEVICE_NAME, SLAVE_CS); master_device = (struct rt_spi_device *)rt_device_find(MASTER_DEVICE_NAME); slave_device = (struct rt_spi_device *)rt_device_find(SLAVE_DEVICE_NAME); if (master_device == NULL || slave_device == NULL) { rt_kprintf("spi failed! can't find %s device!\n", MASTER_DEVICE_NAME); } { // 配置SPI2 master_device->bus->owner = master_device; struct rt_spi_configuration cfg; cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_0 | RT_SPI_MSB; cfg.max_hz = 1 * 1000 *1000; /* 1M */ result = rt_spi_configure(master_device, &cfg); if (result != RT_EOK) rt_kprintf("SPI2 configuration failed!\n"); } { // 配置SPI3 slave_device->bus->owner = slave_device; struct rt_spi_configuration cfg; cfg.data_width = 8; cfg.mode = RT_SPI_SLAVE | RT_SPI_MODE_0 | RT_SPI_MSB; cfg.max_hz = 1 * 1000 *1000; /* 1M */ result = rt_spi_configure(slave_device, &cfg); if (result != RT_EOK) rt_kprintf("SPI3 configuration failed!\n"); } rt_device_open( (rt_device_t) master_device, RT_DEVICE_FLAG_RDWR); rt_device_open( (rt_device_t) slave_device, RT_DEVICE_FLAG_RDWR); } //主函数 char tx_data[LEN] = "123456787654321"; int main(void) { master_slave_init(); master_send_slave_recv(tx_data); return RT_EOK; } ``` 串口打印报错: [2] D/NO_TAG: SPI MASTER send successful! [31m[1006] E/drv.spi: SPI transfer error: 3 [0m[31m[1010] E/spi.core: SPI device spi30 transfer failed [0m SPI rx_buf : ???????????????123456787654321
100
xu123456
rtt的SPI作从机怎么编程?我尝试了,收不到数据!
请问基于rt-thread的spi slave (从机)应该怎么做
spi dma 中断接收的问题
rt_thread_delay中,关/开中断,导致SPI从机接收时数据丢失
freemodbus 从机 运行过程中怎么修改从机地址呢?
RT-Thread如何开启SPI中断
SPI配置为从模式,设备下电再上电,不能触发SPI中断
MCU采用PSI从设备通讯,发送数据到主设备,出现数据重复
Gd32 SPI从设备中断,有时无法收到数据,原因不明确
rt-thread的spi框架,rt_spi_transfer的详细功能细节理解
RT-Thread离线包制作
RT-Thread 屏蔽在线软件包的方法
RT-Thread OS应用开发实战线上师资培训通知
【ci】【github】【bsp】RT-Thread仓库的CI自动编译测试
免费解锁MCU超能力!4月AIoT实战培训三城巡演
YZRD
