Network
关于RT-Thread+LWIP在STM32F4平台上的驱动
发布于 2017-06-27 11:31:51 浏览:3785
现在RT-Thread的BSP里包含了STM32F7的移植,但还没有网络功能,所以想参照之前RealTouch例程,将RT-Thread+LWIP移植到STM32F7平台上。 看了一下与以太网硬件驱动有关的代码,现在有个疑问, ```/* reception packet. */ struct pbuf *rt_stm32_eth_rx(rt_device_t dev) { struct pbuf* p; rt_uint32_t offset = 0, framelength = 0; /* init p pointer */ p = RT_NULL; /* Check if the descriptor is owned by the ETHERNET DMA (when set) or CPU (when reset) */ if(((DMARxDescToGet->Status & ETH_DMARxDesc_OWN) != (uint32_t)RESET)) return p; if (((DMARxDescToGet->Status & ETH_DMARxDesc_ES) == (uint32_t)RESET) && ((DMARxDescToGet->Status & ETH_DMARxDesc_LS) != (uint32_t)RESET) && ((DMARxDescToGet->Status & ETH_DMARxDesc_FS) != (uint32_t)RESET)) { /* Get the Frame Length of the received packet: substruct 4 bytes of the CRC */ framelength = ((DMARxDescToGet->Status & ETH_DMARxDesc_FL) >> ETH_DMARXDESC_FRAME_LENGTHSHIFT) - 4; /* allocate buffer */ p = pbuf_alloc(PBUF_LINK, framelength, PBUF_RAM); ......``` 该函数的功能将硬件接收到的Packet放到LWIP的pbuf中,其中 ```if (((DMARxDescToGet->Status & ETH_DMARxDesc_ES) == (uint32_t)RESET) && ((DMARxDescToGet->Status & ETH_DMARxDesc_LS) != (uint32_t)RESET) && ((DMARxDescToGet->Status & ETH_DMARxDesc_FS) != (uint32_t)RESET))``` if语句的功能好像是针对了一次接收到的数据只使用了一个以太网DMA传输的描述符(链表形式)。 有没有可能一次接收到的数据使用了一个以上的DMA描述符(就是一次接收到的数据超过一帧的长度)。 我看ST官方的LWIP例程里面,似乎有针对一次接收数据使用多个DMA描述符的处理。 ```HAL_StatusTypeDef HAL_ETH_GetReceivedFrame_IT(ETH_HandleTypeDef *heth) { uint32_t descriptorscancounter = 0U; /* Process Locked */ __HAL_LOCK(heth); /* Set ETH HAL State to BUSY */ heth->State = HAL_ETH_STATE_BUSY; /* Scan descriptors owned by CPU */ while (((heth->RxDesc->Status & ETH_DMARXDESC_OWN) == (uint32_t)RESET) && (descriptorscancounter < ETH_RXBUFNB)) { /* Just for security */ descriptorscancounter++; /* Check if first segment in frame */ /* ((heth->RxDesc->Status & ETH_DMARXDESC_FS) != (uint32_t)RESET) && ((heth->RxDesc->Status & ETH_DMARXDESC_LS) == (uint32_t)RESET)) */ if((heth->RxDesc->Status & (ETH_DMARXDESC_FS | ETH_DMARXDESC_LS)) == (uint32_t)ETH_DMARXDESC_FS) { heth->RxFrameInfos.FSRxDesc = heth->RxDesc; heth->RxFrameInfos.SegCount = 1U; /* Point to next descriptor */ heth->RxDesc = (ETH_DMADescTypeDef*) (heth->RxDesc->Buffer2NextDescAddr); } /* Check if intermediate segment */ /* ((heth->RxDesc->Status & ETH_DMARXDESC_LS) == (uint32_t)RESET)&& ((heth->RxDesc->Status & ETH_DMARXDESC_FS) == (uint32_t)RESET)) */ else if ((heth->RxDesc->Status & (ETH_DMARXDESC_LS | ETH_DMARXDESC_FS)) == (uint32_t)RESET) { /* Increment segment count */ (heth->RxFrameInfos.SegCount)++; /* Point to next descriptor */ heth->RxDesc = (ETH_DMADescTypeDef*)(heth->RxDesc->Buffer2NextDescAddr); } /* Should be last segment */ else { /* Last segment */ heth->RxFrameInfos.LSRxDesc = heth->RxDesc; /* Increment segment count */ (heth->RxFrameInfos.SegCount)++; /* Check if last segment is first segment: one segment contains the frame */ if ((heth->RxFrameInfos.SegCount) == 1U) { heth->RxFrameInfos.FSRxDesc = heth->RxDesc; } /* Get the Frame Length of the received packet: substruct 4 bytes of the CRC */ heth->RxFrameInfos.length = (((heth->RxDesc)->Status & ETH_DMARXDESC_FL) >> ETH_DMARXDESC_FRAMELENGTHSHIFT) - 4U; /* Get the address of the buffer start address */ heth->RxFrameInfos.buffer =((heth->RxFrameInfos).FSRxDesc)->Buffer1Addr; /* Point to next descriptor */ heth->RxDesc = (ETH_DMADescTypeDef*) (heth->RxDesc->Buffer2NextDescAddr); /* Set HAL State to Ready */ heth->State = HAL_ETH_STATE_READY; /* Process Unlocked */ __HAL_UNLOCK(heth); /* Return function status */ return HAL_OK; } } /* Set HAL State to Ready */ heth->State = HAL_ETH_STATE_READY; /* Process Unlocked */ __HAL_UNLOCK(heth); /* Return function status */ return HAL_ERROR; }``` 以上是ST官方的代码,针对一次接收到的数据可能使用了多个DMA描述符的情况作了处理。 现在想问一下, 1)是因为RT-Thread针对LWIP做了优化处理后,不会出现一次接收到的数据超过一个Frame(最长1524字节)的情况?还是说需要考虑这种情况。 2)p = pbuf_alloc(PBUF_LINK, framelength, PBUF_RAM),type是PBUF_RAM, RT-Thread用的是自己的内存管理,从系统HEAP上分配内存给pbuf,没有使用LWIP自己的mem.c? 3)从最底层接收到的数据,针对pbuf_alloc,RT-Thread用的是PBUF_LINK,ST官方例程用的是PBUF_RAW,有什么区别吗?
2017-06-27
默认分配了最大1500的空间给每个帧,就不必再分包了吧。 MCU上支持巨型帧必要性不大。
3.8k
softwind
42
154
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
STM32内存扩展,SRAM-RMC
