RTT串口驱动的RX缓存区申请对应代码
发布于 2022-07-07 17:27:12 浏览:753
针对stm32的drv_usart驱动库,有以下初始化内容 `````c int rt_hw_usart_init(void) { rt_size_t obj_num = sizeof(uart_obj) / sizeof(struct stm32_uart); struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; rt_err_t result = 0; stm32_uart_get_dma_config(); for (int i = 0; i < obj_num; i++) { uart_obj[i].config = &uart_config[i]; uart_obj[i].serial.ops = &stm32_uart_ops; uart_obj[i].serial.config = config; /* register UART device */ result = rt_hw_serial_register(&uart_obj[i].serial, uart_obj[i].config->name, RT_DEVICE_FLAG_RDWR | RT_DEVICE_FLAG_INT_RX | RT_DEVICE_FLAG_INT_TX | uart_obj[i].uart_dma_flag , NULL); RT_ASSERT(result == RT_EOK); } return result; } ````` 其中以下默认配置,包含了串口的接收缓冲区应申请的buffer大小,不知道RTT哪一部分代码进行了内存申请,赋值到了串口对应rt_serial_device结构体的void *serial_rx指针 `````c /* Default config for serial_configure structure */ #define RT_SERIAL_CONFIG_DEFAULT \ { \ BAUD_RATE_115200, /* 115200 bits/s */ \ DATA_BITS_8, /* 8 databits */ \ STOP_BITS_1, /* 1 stopbit */ \ PARITY_NONE, /* No parity */ \ BIT_ORDER_LSB, /* LSB first sent */ \ NRZ_NORMAL, /* Normal mode */ \ RT_SERIAL_RB_BUFSZ, /* Buffer size */ \ RT_SERIAL_FLOWCONTROL_NONE, /* Off flowcontrol */ \ 0 \ } struct rt_serial_device { struct rt_device parent; const struct rt_uart_ops *ops; struct serial_configure config; void *serial_rx; void *serial_tx; }; ````` 在串口中断处理函数里面,使用到了serial_rx指向的串口接收缓存区地址,猜测是哪里有代码动态申请了一个内存。 rx_fifo = (struct rt_serial_rx_fifo*)serial->serial_rx; 希望有大佬指点下,RTT哪一部分代码对这个指针赋值了地址,谢谢! `````c /* ISR for serial interrupt */ void rt_hw_serial_isr(struct rt_serial_device *serial, int event) { switch (event & 0xff) { case RT_SERIAL_EVENT_RX_IND: { int ch = -1; rt_base_t level; struct rt_serial_rx_fifo* rx_fifo; /* interrupt mode receive */ rx_fifo = (struct rt_serial_rx_fifo*)serial->serial_rx; RT_ASSERT(rx_fifo != RT_NULL); while (1) { ch = serial->ops->getc(serial); if (ch == -1) break; /* disable interrupt */ level = rt_hw_interrupt_disable(); rx_fifo->buffer[rx_fifo->put_index] = ch; rx_fifo->put_index += 1; if (rx_fifo->put_index >= serial->config.bufsz) rx_fifo->put_index = 0; /* if the next position is read index, discard this 'read char' */ if (rx_fifo->put_index == rx_fifo->get_index) { rx_fifo->get_index += 1; rx_fifo->is_full = RT_TRUE; if (rx_fifo->get_index >= serial->config.bufsz) rx_fifo->get_index = 0; _serial_check_buffer_size(); } /* enable interrupt */ rt_hw_interrupt_enable(level); } /* invoke callback */ if (serial->parent.rx_indicate != RT_NULL) { rt_size_t rx_length; /* get rx length */ level = rt_hw_interrupt_disable(); rx_length = (rx_fifo->put_index >= rx_fifo->get_index)? (rx_fifo->put_index - rx_fifo->get_index): (serial->config.bufsz - (rx_fifo->get_index - rx_fifo->put_index)); rt_hw_interrupt_enable(level); if (rx_length) { serial->parent.rx_indicate(&serial->parent, rx_length); } } break; } case RT_SERIAL_EVENT_TX_DONE: { struct rt_serial_tx_fifo* tx_fifo; tx_fifo = (struct rt_serial_tx_fifo*)serial->serial_tx; rt_completion_done(&(tx_fifo->completion)); break; } } } `````
lchnu
2022-07-07
Witness, Understand, Skill
在components/drivers/serial/serial.c中的`rt_serial_open`函数中,有对serial_rx赋值的操作,缓冲区的来源就是rt_malloc处理的。
2022-07-08
搜 `serial_rx`,看它在哪儿初始化的呗。
753
YUNLE
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
820
