FSMC_FMC_外扩总线
stm32 f407ZGTx 外扩外部SRAM IS62WV51216 奇数地址读取为0
发布于 2023-04-10 10:54:26 浏览:456
rt-thread studio 外扩内存使用,初始化成功,偶数位单字节可写可读,奇数位单字节读出来是0 ``` msh />sram_test 11111 : 9 22222 : 0 ``` ```c #include
#define BSP_USING_SRAM #ifdef BSP_USING_SRAM #include "sdram_port.h" #define DRV_DEBUG #define DBG_LVL DBG_LOG #define LOG_TAG "drv.sram" #include
#ifdef RT_USING_MEMHEAP_AS_HEAP struct rt_memheap ex_heap; #endif SRAM_HandleTypeDef SRAM_Handler; int FSMC_SRAM_Init(void) { GPIO_InitTypeDef GPIO_Initure; FSMC_NORSRAM_TimingTypeDef FSMC_ReadWriteTim; __HAL_RCC_FSMC_CLK_ENABLE() ; __HAL_RCC_GPIOD_CLK_ENABLE() ; __HAL_RCC_GPIOE_CLK_ENABLE() ; __HAL_RCC_GPIOF_CLK_ENABLE() ; __HAL_RCC_GPIOG_CLK_ENABLE() ; //PD0,1,4,5,8~15 GPIO_Initure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15; GPIO_Initure.Mode = GPIO_MODE_AF_PP; GPIO_Initure.Pull = GPIO_PULLUP; GPIO_Initure.Speed = GPIO_SPEED_HIGH; GPIO_Initure.Alternate = GPIO_AF12_FSMC; HAL_GPIO_Init(GPIOD, &GPIO_Initure); //PE0,1,7~15 GPIO_Initure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_7 | GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15; HAL_GPIO_Init(GPIOE, &GPIO_Initure); //PF0~5,12~15 GPIO_Initure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_12 | GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15; HAL_GPIO_Init(GPIOF, &GPIO_Initure); //PG0~5,10 GPIO_Initure.Pin = GPIO_PIN_0 | GPIO_PIN_1 | GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5 | GPIO_PIN_10; HAL_GPIO_Init(GPIOG, &GPIO_Initure); SRAM_Handler.Instance = FSMC_NORSRAM_DEVICE; SRAM_Handler.Extended = FSMC_NORSRAM_EXTENDED_DEVICE; SRAM_Handler.Init.NSBank = FSMC_NORSRAM_BANK3; SRAM_Handler.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE; SRAM_Handler.Init.MemoryType = FSMC_MEMORY_TYPE_SRAM; SRAM_Handler.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16; SRAM_Handler.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_DISABLE; SRAM_Handler.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW; SRAM_Handler.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS; SRAM_Handler.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE; SRAM_Handler.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE; SRAM_Handler.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE; SRAM_Handler.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE; SRAM_Handler.Init.WriteBurst = FSMC_WRITE_BURST_DISABLE; SRAM_Handler.Init.ContinuousClock = FSMC_CONTINUOUS_CLOCK_SYNC_ASYNC; FSMC_ReadWriteTim.AddressSetupTime = 0x00; FSMC_ReadWriteTim.AddressHoldTime = 0x00; FSMC_ReadWriteTim.DataSetupTime = 0x018; FSMC_ReadWriteTim.BusTurnAroundDuration = 0X00; FSMC_ReadWriteTim.AccessMode = FSMC_ACCESS_MODE_A; HAL_StatusTypeDef status = HAL_SRAM_Init(&SRAM_Handler, &FSMC_ReadWriteTim, &FSMC_ReadWriteTim); if (status != HAL_OK) { rt_kprintf("SRAM init failed!\n"); return -RT_ERROR; } else { rt_kprintf("SRAM init Success\n"); #ifdef RT_USING_MEMHEAP_AS_HEAP /* If RT_USING_MEMHEAP_AS_HEAP is enabled, SRAM is initialized to the heap */ // rt_memheap_init(&ex_heap, "sram_ex", (void *) SRAM_BANK_ADDR, SRAM_SIZE); #endif } return RT_EOK; } INIT_BOARD_EXPORT(FSMC_SRAM_Init); #define Bank1_SRAM3_ADDR ((u32)(0x68000000)) typedef __IO uint32_t vu32; typedef __IO uint16_t vu16; typedef __IO uint8_t vu8; typedef uint32_t u32; typedef uint16_t u16; typedef uint8_t u8; void FSMC_SRAM_WriteBuffer(u8* pBuffer, u32 WriteAddr, u32 n) { for (; n != 0; n--) { *(vu8*) (Bank1_SRAM3_ADDR + WriteAddr) = *pBuffer++; WriteAddr++; } } void FSMC_SRAM_ReadBuffer(u8* pBuffer, u32 ReadAddr, u32 n) { for (; n != 0; n--) { *pBuffer++ = *(vu8*) (Bank1_SRAM3_ADDR + ReadAddr); ReadAddr++; } } #ifdef DRV_DEBUG #ifdef FINSH_USING_MSH static int sram_test(void) { u8 temp = 9; u8 sval = 0; FSMC_SRAM_WriteBuffer(&temp, 100, 1); FSMC_SRAM_ReadBuffer(&sval, 100, 1); rt_kprintf("11111 : %d \r\n", sval); temp = 10; FSMC_SRAM_WriteBuffer(&temp, 101, 1); FSMC_SRAM_ReadBuffer(&sval, 101, 1); rt_kprintf("22222 : %d \r\n", sval); return RT_EOK; } MSH_CMD_EXPORT(sram_test, sram test); void* rt_sk_memheap_alloc(rt_size_t size) { void *new_ptr_t = rt_memheap_alloc(&ex_heap, size); if (new_ptr_t) { return new_ptr_t; } else { rt_kprintf("rt_sk_memheap_alloc fail, size=%d\n", size); } return NULL; } #endif /* FINSH_USING_MSH */ #endif /* DRV_DEBUG */ #endif /* BSP_USING_SRAM */ ```
2023-04-10
小睿手办 https://item.taobao.com/item.htm?id=674889867009
建议检查硬件上的字节选择引脚是否虚焊短路。
456
zsy_1张
SRAM进行初始化,找不到这三个函数(已解决)
rtthread fsmc驱动LCD代码无错误,且背光显示,但是无现象
rtthread操作LCD异常,不知道是哪里错误
undefined symbol FSMC_NORSRAM是什么错误?怎么修改?
RTT有没有关于FSMC的资料?
求助STM32 FSMC如何使用
工程缺少是stm32F1xx_ll_fsmc.c文件
STM32F103VE指南者使用ILI9341求助
RT-Thread如何能完全运行在片外NorFlash
RT-Thread Studio移植TFTLCD(FSMC)
RT-Thread studio的驱动5.1.0报错修改
基于RT-Thread的STM32开发第一讲——USART
pkgs --upgrade报错SSL未验证问题解决记录
818
