ringbuffer_环形缓冲区
RINGBUFF里镜像索引取反是为什么?
发布于 2021-10-16 22:45:30 浏览:702
请教一下,环形队列里 为什么函数中让镜像索引按位取反不是一个很大的值吗? 比如 read_mirror =8,取反的值不是65527吗 这个值和镜像有什么关系? ```c rt_size_t rt_ringbuffer_put_force(struct rt_ringbuffer *rb, const rt_uint8_t *ptr, rt_uint16_t length) { rt_uint16_t space_length; RT_ASSERT(rb != RT_NULL); space_length = rt_ringbuffer_space_len(rb); if (length > rb->buffer_size) { ptr = &ptr[length - rb->buffer_size]; length = rb->buffer_size; } if (rb->buffer_size - rb->write_index > length) { /* read_index - write_index = empty space */ memcpy(&rb->buffer_ptr[rb->write_index], ptr, length); /* this should not cause overflow because there is enough space for * length of data in current mirror */ rb->write_index += length; if (length > space_length) rb->read_index = rb->write_index; return length; } memcpy(&rb->buffer_ptr[rb->write_index], &ptr[0], rb->buffer_size - rb->write_index); memcpy(&rb->buffer_ptr[0], &ptr[rb->buffer_size - rb->write_index], length - (rb->buffer_size - rb->write_index)); /* we are going into the other side of the mirror */ rb->write_mirror = ~rb->write_mirror; rb->write_index = length - (rb->buffer_size - rb->write_index); if (length > space_length) { rb->read_mirror = ~rb->read_mirror; rb->read_index = rb->write_index; } return length; } ```
2021-10-18
对楼上大佬做一个补充,大佬有一个很重要的地方遗漏了。环形缓冲区空满状态的识别。 ``` rt_inline enum rt_ringbuffer_state rt_ringbuffer_status(struct rt_ringbuffer *rb) { if (rb->read_index == rb->write_index) { if (rb->read_mirror == rb->write_mirror) return RT_RINGBUFFER_EMPTY; else return RT_RINGBUFFER_FULL; } return RT_RINGBUFFER_HALFFULL; } ``` `read_mirror` `write_mirror` 分别是两个 1bit 的值,也就是只能是 bool 型,要么0 要么1。 源码中所有其它地方的位翻转也只能在 0 1 之间翻转。 首先,环形缓冲区是一种逻辑数据结果,物理上仍然是一个普通的线性数组。 当写索引超过环形缓冲器(数组)长度时,将从数组 0 索引开始继续写。这时候 `write_mirror` 翻转。 写的情况是一样的,只不过是 `read_mirror` 翻转。这样从 0 到结尾然后又回到0 所以可以认为是个环形缓存。 由上面的函数可以看出来,mirror 只用于判断区分空满两种状态了。
2021-10-17
[RT-Thread 隐藏的宝藏之ringbuff](https://club.rt-thread.org/ask/article/2642.html)
chenyingchun
2021-10-18
可以参考官方文档,是否可以解决你的疑惑: https://www.rt-thread.org/document/site/#/rt-thread-version/rt-thread-standard/programming-manual/device-ipc/ringbuffer/ringbuffer
702
allen752
大量接收数据 如何处理能减少丢包率
有没有一种实现类似 ringbuffer, 但返回数据长度 和传入时候一样
使用ringbuffer时,自检到thread的type不匹配
对ringbuffer中rt_ringbuffer_put_force函数的疑问
系统提供环形FIFO写入重载时可能存在数据错乱问题
rt_ringbuffer_peak疑问
串口DMA接收回调函数不起作用
串口 DMA ringbuffer 接收有可能覆盖数据
rt_ringbuffer_init在buffer_size赋值是否有问题?
rtthread 中的ringbuff是线程安全的吗?
rt-thread 挂载romfs与ramfs
smart启动流程详解
小内存管理(1)--- 内存初始化
spi自动初始化程序
aeniac
zhuzhuzhu
YDPB_5935
