文件系统学习营
【文件系统学习】+小燕+开发板跑fs将romfs中tar文件解压到fa...
发布于 2018-07-29 00:54:30 浏览:2705
```#define STK_UNTAR_SIZE 1024 #define TASK_UNTAR_PRIORITY 1 #define UNTAR_TARGET_DIR "sdcard/untar" #define TAR_FILE "/untar_test.tar" #define TAR_FILE_BLOCK_SIZE 512 #define TAR_FILE_TYPE_FILE '0' // linkflag是'5'表示这个文件是目录,那么这个文件块将没有数据 #define TAR_FILE_TYPE_DIR '5' /* * standard archive format - standard tar - ustar */ #define recordsize 512 #define namsiz 100 #define tunmlen 32 #define tgnmlen 32 typedef struct { char name[namsiz]; char mode[8]; char uid[8]; char gid[8]; char size[12]; char mtime[12]; char chksum[8]; char linkflag; char linkname[namsiz]; char magic[8]; char uname[tunmlen]; char gname[tgnmlen]; char devmajor[8]; char devminor[8]; }_tar_header; // 这个方法是从学习营其他人那看到的,非常好,借用 typedef union { rt_uint8_t buffer[TAR_FILE_BLOCK_SIZE]; _tar_header header; }_tar_block; // romfs extern const struct romfs_dirent romfs_root; // 解压任务 rt_thread_t s_untar_thread = RT_NULL; //八进制转十进制 int convertOctalToDecimal(int octalNumber) { int decimalNumber = 0, i = 0; while (octalNumber != 0) { decimalNumber += (octalNumber%10) * pow(8, i); ++i; octalNumber /= 10; } return decimalNumber; } // 解析tar文件 void untar_function(int argc, char **argv) { // tar文件句柄 struct dfs_fd tar_fd; // tar中的文件的句柄 struct dfs_fd fd; // tar文件信息 struct stat tar_file_stat; // 用来解析读取数据是否是文件头 _tar_block *pblock; int size, block_num = 0, i, j, k; char target_dir[128] = {0}, file_dir[128] = {0}; rt_uint8_t block_data[TAR_FILE_BLOCK_SIZE] = {0}; int file_total_size; // 打开文件 if (dfs_file_open(&tar_fd, TAR_FILE, O_RDONLY)) { rt_kprintf("open failed.
"); return; } // 获取tar文件信息 if (dfs_file_stat(TAR_FILE, &tar_file_stat)) { dfs_file_close(&tar_fd); return; } rt_kprintf("untar_test.tar file size = %d block %d
", tar_file_stat.st_size, tar_file_stat.st_size / 512); rt_kprintf("tar_header size %d
", sizeof(_tar_header)); block_num = tar_file_stat.st_size / 512; for (i = 0; i <= block_num; i++) { // 读文件 size = dfs_file_read(&tar_fd, block_data, TAR_FILE_BLOCK_SIZE); pblock = (_tar_block *)block_data; // 文件头 if ((size == TAR_FILE_BLOCK_SIZE) && !(strcmp(pblock->header.magic, "ustar"))) { if (pblock->header.linkflag == TAR_FILE_TYPE_DIR)// 目录 { // 将读到的目录创建出来 rt_memset(target_dir, 0, sizeof(target_dir)); strcat(target_dir, UNTAR_TARGET_DIR); strcat(target_dir, pblock->header.name); if (mkdir(target_dir, 0x777) < 0) { rt_kprintf("creat dir err.
"); return; } } else if (pblock->header.linkflag == TAR_FILE_TYPE_FILE)// 文件 { // 先创建文件目录 rt_memset(file_dir, 0, sizeof(file_dir)); strcat(file_dir, UNTAR_TARGET_DIR); strcat(file_dir, pblock->header.name); for (j = (rt_strlen(file_dir) - 1); j>= 0; j--) if (file_dir[j] == '/') file_dir[j + 1] = 0; //截断 mkdir(file_dir, 0x777); // 创建文件 rt_memset(file_dir, 0, sizeof(file_dir)); strcat(file_dir, UNTAR_TARGET_DIR); strcat(file_dir, pblock->header.name); if (dfs_file_open(&fd, file_dir, O_RDWR | O_CREAT | O_APPEND)) rt_kprintf("open %s failed
", pblock->header.name); file_total_size = convertOctalToDecimal(atoi(pblock->header.size)); j = 0; } } // 文件内容 else { for (k = 0; k < TAR_FILE_BLOCK_SIZE; k++) { dfs_file_write(&fd, &block_data[k], 1); j++; //读取数据结束 if (j >= file_total_size) dfs_file_close(&fd); } } } dfs_file_close(&tar_fd); } MSH_CMD_EXPORT(untar_function, untar file to sdcard); // user main int main(void) { // 挂载romfs if (dfs_mount(RT_NULL, "/", "rom", 0, &(romfs_root)) == 0) { rt_kprintf("ROM System initialized!
"); } else { rt_kprintf("ROM System init failed!
"); } // 挂载fatfs到sd卡 if (dfs_mount("sd0", "/sdcard", "elm", 0, 0) == 0) { rt_kprintf("file system initialization done!
"); } else { rt_kprintf("file system initialization failed!
"); } return 0; } ``` 下载附件 [第二周:开发板跑fs将romfs中tar文件解压到fatfs中.docx](https://oss-club.rt-thread.org/uploads/201807/29/005252sizo9ixcludio81l.attach)
lillian
2018-07-29
有个疑问,我本来不是通过MSH调用这个解tar文件的接口的,是在main里面创建了一个untar任务去执行相关操作,但是在untar任务中执行到创建目录的时候(即调用mkdir()接口的时候)会assert,提示的错误如下: (rt_object_get_type((rt_object_t)thread) == RT_Object_Class_Thread) assertion failed at function:rt_thread_control, line number:581
2.7k
lillian
49
【文件系统学习】+DMY+任务1sample例程
【文件系统学习】skawu的文件系统跑起来了
【文件系统学习】skawu之文件匹配学习
【文件系统学习】+清石+运行文件系统sample例程
【文件系统学习】+小燕+运行文件系统sample例程
【文件系统学习】+阿暖+运行文件系统 sample 例程
【文件系统学习】+小燕+一系列文件中找出指定文件
【文件系统学习】+小燕+文件数据替换
新版OneNet的星火1号开发板例程适配(下)
重磅预售!RT-Trace调试工具
yans
tjrong
miandian_7
Pai同学
Rick98
河南理工大学恁带劲儿
