基于潘多拉开发使用rt-thread studio 开发使用软件包AHT10遇到....
发布于 2020-05-26 18:00:10 浏览:2876
基于潘多拉开发板使用的问题: 配置了I2c总线和软件包,初始化也成功了,但是无法读取数据时怎么回事?有哪位大神帮忙看看? ```c #include
/* PLEASE DEFINE the LED0 pin for your board, such as: PA5 */ #define LED0_PIN GET_PIN(E, 7) #include "aht10.h" #include "sensor_asair_aht10.h" #define AHT10_I2C_BUS "i2c1" int rt_hw_aht10_port(void) { struct rt_sensor_config cfg; cfg.intf.dev_name = AHT10_I2C_BUS; cfg.intf.user_data = (void *)AHT10_I2C_ADDR; rt_hw_aht10_init("aht10", &cfg); LOG_D("aht10 is OK!"); return RT_EOK; } int main(void) { rt_err_t res; float humidity, temperature; int count = 1; aht10_device_t dev; rt_hw_aht10_port(); dev = aht10_init(AHT10_I2C_BUS); if (dev == RT_NULL) { LOG_E(" The sensor initializes failure"); return 0; } else { LOG_D(" The sensor initializes ok!"); } /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); while (count++) { humidity = aht10_read_humidity(dev); rt_kprintf("humidity : %d.%d %%
", (int)humidity, (int)(humidity * 10) % 10); /* former is integer and behind is decimal */ /* read temperature */ temperature = aht10_read_temperature(dev); rt_kprintf("temperature: %d.%d
", (int)temperature, (int)(temperature * 10) % 10); /* former is integer and behind is decimal */ rt_thread_mdelay(1000); /* set LED0 pin level to high or low */ rt_pin_write(LED0_PIN, count % 2); // LOG_D("Hello RT-Thread!"); rt_thread_mdelay(1000); } return RT_EOK; } ```
cgh198510
2020-05-26
[E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is
cgh198510
2020-06-08
>看下用这个例子能读取数据吗https://www.rt-thread.org/document/site/programming-manual/device/i2c/i2c/ ... --- 感谢恢复,是管脚接错了。
姜还是我辣
2020-06-10
楼主你好,我也遇到了相同的问题,同样的报错,请问你是怎么解决的?
姜还是我辣
2020-06-10
软件包中的内容: 注意事项 测试中发现传感器 aht10 为不标准 I2C 设备,总线上出现数据与该器件地址相同,即使没有开始信号,也会响应,导 SDA 死锁。所以,建议用户给 AHT10 独立一个 I2C 总线。 我在想是不是与这个有关系,,
2.9k
cgh198510
潘多拉开发板AP6181 外设支持报错
潘多拉wifi管理例程中ap模式未启动
潘多拉开发板上I2C设备驱动开发
潘多拉开发板 综合例程 调试报错
潘多拉开发板在VSCODE无法执行micropython
潘多拉添加freemodbus例子出现错误
潘多拉开发板OV2640拍摄JPEG格式的照片
SFUD 提示闪存超过32g
有谁用潘多拉开发过OV2640吗
请问潘多拉开发板怎么烧录micropython固件
基于RT-Thread的STM32F4开发第三讲——DAC
Wireshark抓包EtherCAT报文
