SFUD 提示闪存超过32g
发布于 2020-12-03 14:29:20 浏览:2958
使用官方提供潘多拉开发板IoT_Board-1.2.0的实例程序19_iot_mqtt(应该很多示例程序都会这样),下载后重启板子就出现闪存大小超过32g的错误,导致挂在不上 ``` \ | / - RT - Thread Operating System / | \ 4.0.1 build Dec 3 2020 2006 - 2019 Copyright by rt-thread team lwIP-2.0.2 initialized! [32m[I/sal.skt] Socket Abstraction Layer initialize success.[0m [SFUD] Error: The flash capacity is grater than 32 Gb/ 4 GB! Not Supported. [SFUD] Warning: This flash device is not found or not support. [SFUD] Error: w25q128 flash device is initialize fail. ERROR: SPI flash probe failed by SPI device qspi10. ```
木又寸
2022-07-17
板载FLASH: NM25Q128EV 在sfud_flash_def.h添加相关信息,参考:https://github.com/armink/SFUD/blob/master/sfud/inc/sfud_flash_def.h 已经正常挂载了。
zhd
2023-05-27
sfud_sfdp.c文件中,read_basic_table函数负责解析读取到的JECED闪存基本参数表,打开sfud调试带打印可以看到从NM25Q128的参数表: ```c [175] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:203) JEDEC basic flash parameter table info: [186] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [197] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0001] 0xFF 0xF9 0x20 0xE5 [207] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0002] 0xFF 0xFF 0xFF 0x07 [217] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0003] 0x6B 0x08 0xEB 0x44 [228] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0004] 0xBB 0x84 0x3B 0x08 [238] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0005] 0xFF 0xFF 0xFF 0xFE [248] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0006] 0xFF 0x00 0xFF 0xFF [258] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0007] 0xEB 0x44 0xFF 0xFF [269] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0008] 0x52 0x0F 0x20 0x0C [279] D/SFUD: (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:206) [0009] 0xFF 0x00 0xD8 0x10 ```  表中第二行就是flash的容量大小,16M -> 0x07FFFFFF bit。而read_basic_table函数中解析该信息的代码是 ```c /* get flash memory capacity */ uint32_t table2_temp = ((long)table[7] << 24) | ((long)table[6] << 16) | ((long)table[5] << 8) | (long)table[4]; switch ((table[7] & (0x01 << 7)) >> 7) { case 0: sfdp->capacity = 1 + (table2_temp >> 3); break; case 1: table2_temp &= 0x7FFFFFFF; if (table2_temp > sizeof(sfdp->capacity) * 8 + 3) { sfdp->capacity = 0; SFUD_INFO("Error: The flash capacity is grater than 32 Gb/ 4 GB! Not Supported."); return false; } sfdp->capacity = 1L << (table2_temp - 3); break; } ``` 可以看到table2_temp拼接字节时,[4]作为最低字节,[7]作为最高字节,这和读出的表顺序相反,想要成功解析这张表,改一下这里就好了。 ```c /* get flash memory capacity */ // uint32_t table2_temp = ((long)table[7] << 24) | ((long)table[6] << 16) | ((long)table[5] << 8) | (long)table[4]; //对NM25Q128高低字节要反过来解析,芯片bug? uint32_t table2_temp = ((long)table[4] << 24) | ((long)table[5] << 16) | ((long)table[6] << 8) | (long)table[7]; // switch ((table[7] & (0x01 << 7)) >> 7) { switch ((table[4] & (0x01 << 7)) >> 7) { case 0: sfdp->capacity = 1 + (table2_temp >> 3); break; case 1: table2_temp &= 0x7FFFFFFF; if (table2_temp > sizeof(sfdp->capacity) * 8 + 3) { sfdp->capacity = 0; SFUD_INFO("Error: The flash capacity is grater than 32 Gb/ 4 GB! Not Supported."); return false; } sfdp->capacity = 1L << (table2_temp - 3); break; } ``` 猜测是NM25Q128的问题?
2020-12-03
学以致用
你这问题必现吗? 我的不会?需要更新下代码? ``` msh > \ | / - RT - Thread Operating System / | \ 4.0.0 build Dec 3 2020 2006 - 2018 Copyright by rt-thread team lwIP-2.0.2 initialized! [I/SAL_SOC] Socket Abstraction Layer initialize success. [SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [SFUD] w25q128 flash device is initialize success. msh />[I/FAL] RT-Thread Flash Abstraction Layer (V0.2.0) initialize success. ```
mijjjj
2020-12-03
刚才跟原子电子那边沟通了,可能是W25Q128有问题,需要回厂返修。 刚买的就遇到这种问题查了好几天资料,郁闷了
2020-12-03
可以拿着放大镜好好看看 FLASH 的丝印,确定一下是不是 W25Q128
xiaoyu
2020-12-30
我也遇到这个问题了
wsccyp
2021-05-23
我也遇到这个问题了,换了个winbond的w25Q128好了,单片机上的那个芯片是开发板上拆下来的。
3k
mijjjj
【分享】如何使用 SFUD 库来操作 SPI Flash 设备
SFUD怎么使用
请教大家一下关于 SFUD 的的问题
移植sfud
使用SFUD操作FLASH
env使用easyflash不是3.2.4版本,而且没有type插件?
新增了W25X32设备成功,无法格式化
easyflash随着数据存储量增加,耗费时间加长
关于SFDP的问题
spi nand flash 能使用SFUD驱动吗
RT Thread 块设备注册
睿擎工业开发平台--CanOpen示例测试
【深度剖析】RT-Thread 线程调度流程
Ryan_CW
chejia12
纯白酱
530china
rv666
